只需一步,快速開(kāi)始
java代碼實(shí)現(xiàn)深度神經(jīng)網(wǎng)絡(luò)算法
查看數(shù): 7300 | 評(píng)論數(shù): 1 | 收藏 0
    組圖打開(kāi)中,請(qǐng)稍候......
發(fā)布時(shí)間: 2017-4-23 16:20
對(duì)于現(xiàn)在流行的深度學(xué)習(xí),保持學(xué)習(xí)精神是必要的——程序員尤其是架構(gòu)師永遠(yuǎn)都要對(duì)核心技術(shù)和關(guān)鍵算法保持關(guān)注和敏感,必要時(shí)要?jiǎng)邮謱?xiě)一寫(xiě)掌握下來(lái),先不用關(guān)心什么時(shí)候用到——用不用是管理問(wèn)題,會(huì)不會(huì)寫(xiě)是技術(shù)問(wèn)題 ...
ID:196521 發(fā)表于 2017-5-4 15:28
求指導(dǎo),我用你的代碼運(yùn)行一個(gè)不一樣的東西,結(jié)果很失望
import java.util.Random;
public class BpDeep{
    public double[][] layer;//神經(jīng)網(wǎng)絡(luò)各層節(jié)點(diǎn)
    public double[][] layerErr;//神經(jīng)網(wǎng)絡(luò)各節(jié)點(diǎn)誤差
    public double[][][] layer_weight;//各層節(jié)點(diǎn)權(quán)重
    public double[][][] layer_weight_delta;//各層節(jié)點(diǎn)權(quán)重動(dòng)量
    public double mobp;//動(dòng)量系數(shù)
    public double rate;//學(xué)習(xí)系數(shù)
    public BpDeep(int[] layernum, double rate, double mobp){
        this.mobp = mobp;
        this.rate = rate;
        layer = new double[layernum.length][];
        layerErr = new double[layernum.length][];
        layer_weight = new double[layernum.length][][];
        layer_weight_delta = new double[layernum.length][][];
        Random random = new Random();
        for(int l=0;l<layernum.length;l++){
            layer[l]=new double[layernum[l]];
            layerErr[l]=new double[layernum[l]];
            if(l+1<layernum.length){
                layer_weight[l]=new double[layernum[l]+1][layernum[l+1]];
                layer_weight_delta[l]=new double[layernum[l]+1][layernum[l+1]];
                for(int j=0;j<layernum[l]+1;j++)
                    for(int i=0;i<layernum[l+1];i++)
                        layer_weight[l][j][i]=random.nextDouble();//隨機(jī)初始化權(quán)重
    //逐層向前計(jì)算輸出
    public double[] computeOut(double[] in){
        for(int l=1;l<layer.length;l++){
            for(int j=0;j<layer[l].length;j++){
                double z=layer_weight[l-1][layer[l-1].length][j];
                for(int i=0;i<layer[l-1].length;i++){
                    layer[l-1][i]=l==1?in[i]:layer[l-1][i];
                    z+=layer_weight[l-1][i][j]*layer[l-1][i];
                layer[l][j]=1/(1+Math.exp(-z));
        return layer[layer.length-1];
    //逐層反向計(jì)算誤差并修改權(quán)重
    public void updateWeight(double[] tar){
        int l=layer.length-1;
        for(int j=0;j<layerErr[l].length;j++)
            layerErr[l][j]=layer[l][j]*(1-layer[l][j])*(tar[j]-layer[l][j]);
        while(l-->0){
            for(int j=0;j<layerErr[l].length;j++){
                double z = 0.0;
                for(int i=0;i<layerErr[l+1].length;i++){
                    z=z+l>0?layerErr[l+1][i]*layer_weight[l][j][i]:0;
                    layer_weight_delta[l][j][i]= mobp*layer_weight_delta[l][j][i]+rate*layerErr[l+1][i]*layer[l][j];//隱含層動(dòng)量調(diào)整
                    layer_weight[l][j][i]+=layer_weight_delta[l][j][i];//隱含層權(quán)重調(diào)整
                    if(j==layerErr[l].length-1){
                        layer_weight_delta[l][j+1][i]= mobp*layer_weight_delta[l][j+1][i]+rate*layerErr[l+1][i];//截距動(dòng)量調(diào)整
                        layer_weight[l][j+1][i]+=layer_weight_delta[l][j+1][i];//截距權(quán)重調(diào)整
                layerErr[l][j]=z*layer[l][j]*(1-layer[l][j]);//記錄誤差
    public void train(double[] in, double[] tar){
        double[] out = computeOut(in);
        updateWeight(tar);
import java.util.Arrays;
public class MyBPtest1{
    public static void main(String[] args){
        //初始化神經(jīng)網(wǎng)絡(luò)的基本配置
        //第一個(gè)參數(shù)是一個(gè)整型數(shù)組,表示神經(jīng)網(wǎng)絡(luò)的層數(shù)和每層節(jié)點(diǎn)數(shù),比如{3,10,10,10,10,2}表示輸入層是3個(gè)節(jié)點(diǎn),輸出層是2個(gè)節(jié)點(diǎn),中間有4層隱含層,每層10個(gè)節(jié)點(diǎn)
        /////////第二個(gè)參數(shù)是學(xué)習(xí)步長(zhǎng)(過(guò)小會(huì)使收斂速度太慢;過(guò)大則會(huì)使預(yù)測(cè)不準(zhǔn),跳過(guò)一些細(xì)節(jié)),
            /////////第三個(gè)參數(shù)是動(dòng)量系數(shù)(使波動(dòng)小的預(yù)測(cè)重新振蕩起來(lái))
        BpDeep bp = new BpDeep(new int[]{5,5,1}, 0.15, 0.9);
        ////////對(duì)于輸入樣本如果只有一個(gè)數(shù)。沒(méi)關(guān)系,大不了{(lán),}第二項(xiàng)里的data和target全為0,,,,!!!!這理解是錯(cuò)誤
        ////////因?yàn)槲覀冊(cè)O(shè)定了輸入層為2,才會(huì)有兩個(gè)輸入({,},{,}}這樣的東西;同理輸入層也為如此
        ////////所以說(shuō)如果是5個(gè)輸入,一個(gè)輸出對(duì)于data就{{,,,,},{,,,,}。。。。。。};;;;;對(duì)于target{,,,,}
        double[][] data = new double[][]{{192,195,194,193,193},
                        {195,194,193,193,195},{194,193,193,195,201},
                        {193,193,195,201,205},{193,195,201,205,205},
                        {195,201,205,205,203},{201,205,205,203,203},
                        {205,205,203,203,202},{205,203,203,202,206},
                        {203,203,202,206,204},{203,202,206,204,204},
                        {202,206,204,204,203},{206,204,204,203,199},
                        {204,204,203,199,195},{204,203,199,195,182},
                        {203,199,195,182,179},{199,195,182,179,178},
                        {195,182,179,178,176},{182,179,178,176,175},
                        {179,178,176,175,173},{178,176,175,173,175},
                        {176,175,173,175,182},{175,173,175,182,183},
                        {173,175,182,183,185},{175,182,183,185,179}};
        //設(shè)置目標(biāo)數(shù)據(jù),對(duì)應(yīng)4個(gè)坐標(biāo)數(shù)據(jù)的分類
        double[][] target = new double[][]{{195},{201},{205},{205},{203},
                        {203},{202},{206},{204},{204},{203},{199},{195},{182},{179},
                        {178},{176},{175},{173},{175},{182},{183},{185},{179},{182}};
        //迭代訓(xùn)練5000次
        ///////這里我們沒(méi)有設(shè)置訓(xùn)練到了某一精確度自動(dòng)停止,而是實(shí)打?qū)嵉挠?xùn)練這些次數(shù)
        for(int n=0;n<5000;n++)
            for(int i=0;i<data.length;i++)
                bp.train(data[i], target[i]);
        //根據(jù)訓(xùn)練結(jié)果來(lái)檢驗(yàn)樣本數(shù)據(jù)
        for(int j=0;j<data.length;j++){
            double[] result = bp.computeOut(data[j]);
            System.out.println(Arrays.toString(data[j])+":"+Arrays.toString(result));
        //根據(jù)訓(xùn)練結(jié)果來(lái)預(yù)測(cè)一條新數(shù)據(jù)的分類
        double[] x = new double[]{192,195,194,193,193};
        double[] result = bp.computeOut(x);
        System.out.println(Arrays.toString(x)+":"+Arrays.toString(result));
