LED Flasher for the Keil MCB950 Evaluation Board有關單片機的一個例子
查看數: 2481 | 評論數: 0 | 收藏 0
cow
發布時間: 2017-3-24 10:54
The BLINKY program is a very simple program that blinks the LED's on connected to Port 5 of the MCB950.  When you can successfully build and run this program, you have used the entire too ...
