電子表程序設(shè)計 帶實驗報告源程序等
查看數(shù): 6429 | 評論數(shù): 4 | 收藏 0
發(fā)布時間: 2017-2-26 11:21
大家一起學(xué)習(xí)學(xué)習(xí)吧 鍵盤功能控制鍵名KEY1秒表鍵KEY2模式鍵KEY3加鍵KEY4減鍵按  下  功  能顯示秒鐘調(diào)分分加,59后為0分減,0后59 調(diào)時時加,23后為0時減,0后23 鬧鐘分鐘分加,59后 ...
ID:169188 發(fā)表于 2017-3-22 23:10
感謝分享,謝謝了
ID:164834 發(fā)表于 2017-2-27 23:18
很好的教程!
ID:51533 發(fā)表于 2017-2-27 17:42
謝謝大師
ID:1 發(fā)表于 2017-2-27 00:40
樓主的程序源碼:
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. sbit w1=P2^0;
  5. sbit w2=P2^1;
  6. sbit w3=P2^2;
  7. sbit w4=P2^3;
  8. sbit key1=P3^2;
  9. sbit Mod_key=P3^3;
  10. sbit Up_key=P3^4;
  11. sbit Down_key=P3^5;
  12. sbit D1=P2^5;
  13. uchar flag,alarm_flag,Buzzer_flag,back,aa,bb,minutes,seconds,hours,hours_alarm,minutes_alarm,t0,Hourshi,Hourge,Minuteshi,Minutege,Secondshi,Secondge;
  14. uchar code table[]={
  15. 0xc0,0xf9,0xa4,0xb0,0x99,
  16. 0x92,0x82,0xf8,0x80,0x90,
  17. 0xbf,0xff};
  18. uchar code tablehours[]={          //小時的個位單獨一個數(shù)組,因為需要一直保持顯示小數(shù)點
  19. 0x40,0x79,0x24,0x30,0x19,
  20. 0x12,0x02,0x78,0x00,0x10};
  21. void init();                //初始化函數(shù)
  22. void delay(uint z);                 //延時函數(shù)
  23. void display(uchar hours,uchar minutes);                 //正常顯示函數(shù)
  24. void display_seconds(uchar aa,uchar Secondshi,uchar Secondge,uchar bb);                   //顯示秒鐘函數(shù)
  25. void keyscan();                           //鍵盤掃描函數(shù)
  26. void Buzzer();                           //蜂鳴器開關(guān)函數(shù)
  27. void main()
  28. {
  29.         init();
  30.         while(1)
  31.         {
  32.                 keyscan();
  33.                 Buzzer();
  34.                 if(flag==1)
  35.                         display_seconds(10,Secondshi,Secondge,10);
  36.                 if(alarm_flag==1)
  37.                         display(hours_alarm,minutes_alarm);
  38.                 if(flag!=1&&alarm_flag!=1)
  39.                         display(hours,minutes);
  40.         }
  41. }
  42. void init()                                //初始化函數(shù)
  43. {
  44.         flag=0;
  45.         alarm_flag=0;
  46.         Buzzer_flag=1;                 //蜂鳴器初始化時默認關(guān)閉
  47.         back=0;
  48.         hours_alarm=0;
  49.         minutes_alarm=0;
  50.         hours=0;
  51.         minutes=0;
  52.         seconds=0;
  53.         Hourshi=0;
  54.         Hourge=0;
  55.         Minuteshi=0;
  56.         Minutege=0;
  57.         Secondshi=0;
  58.         Secondge=0;
  59.         t0=0;
  60.         TMOD=0x01;
  61.         TH0=(65536-50000)/256;
  62.         TL0=(65536-50000)%256;
  63.         EA=1;
  64.         ET0=1;
  65.         TR0=1;
  66. }
  67. void delay(uint z)                  //延時函數(shù)
  68. {
  69.         uint x,y;
  70.         for(x=z;x>0;x--)
  71.                 for(y=110;y>0;y--);
  72. }
  73. void display(uchar hours,uchar minutes)                   //正常顯示函數(shù)
  74. {
  75.         P0=0xff;
  76.         w1=0;
  77.         P0=table[hours/10];
  78.         w1=1;
  79.         delay(1);
  80.         P0=0xff;
  81.         w2=0;
  82.         P0=tablehours[hours%10];
  83.         w2=1;
  84.         delay(1);
  85.         P0=0xff;
  86.         w3=0;
  87.         P0=table[minutes/10];
  88.         w3=1;
  89.         delay(1);
  90.         P0=0xff;
  91.         w4=0;
  92.         P0=table[minutes%10];
  93.         w4=1;
  94.         delay(1);
  95. }
  96. void display_seconds(uchar aa,uchar Secondshi,uchar Secondge,uchar bb)           //顯示秒鐘函數(shù)
  97. {
  98.         P0=0xff;
  99.         w1=0;
  100.         P0=table[aa];
  101.         w1=1;
  102.         delay(1);
  103.         P0=0xff;
  104.         w2=0;
  105.         P0=table[Secondshi];
  106.         w2=1;
  107.         delay(1);
  108.         P0=0xff;
  109.         w3=0;
  110.         P0=table[Secondge];
  111.         w3=1;
  112.         delay(1);
  113.         P0=0xff;
  114.         w4=0;
  115.         P0=table[bb];
  116.         w4=1;
  117.         delay(1);
  118. }
  119. void keyscan()                        //鍵盤掃描函數(shù)
  120. {
  121.         if(key1==0)
  122.                 flag=1;
  123.         else
  124.                 flag=0;
  125.         if(Up_key==0)
  126.                 alarm_flag=1;
  127.         else
  128.                 alarm_flag=0;
  129.         if(Down_key==0)
  130.         {
  131.                 while(!Down_key);
  132.                 Buzzer_flag=~Buzzer_flag;
  133.         }
  134.
  135.         if(Mod_key==0)
  136.         {
  137.                 while(!Mod_key);
  138.                 while(1)
  139.                 {
  140.                         display(hours,minutes);
  141.                         delay(50);
  142.                         if(back==1)
  143.                         {
  144.                                 back=0;
  145.                                 break;
  146.                         }
  147.                         if(key1==0)
  148.                         {
  149.                                 while(!key1);
  150.                                 while(1)
  151.                                 {
  152.                                         display(hours,minutes);
  153.                                         if(Up_key==0)
  154.                                         {
  155.                                                 while(!Up_key);
  156.                                                 minutes++;
  157.                                                 if(minutes==60)
  158.                                                         minutes=0;
  159.                                         }
  160.
  161.                                         if(Down_key==0)
  162.                                         {
  163.                                                 while(!Down_key);
  164.                                                 minutes--;
  165.                                                 if(minutes==-1)
  166.                                                         minutes=59;
  167.                                         }
  168.                                         if(back==1)
  169.                                         {
  170.                                                 back==1;
  171.                                                 break;
  172.                                         }
  173.
  174.                                         if(Mod_key==0)
  175.                                         {
  176.                                                 while(!Mod_key);
  177.                                                 while(1)
  178.                                                 {
  179.                                                         display(hours,minutes);
  180.                                                         if(Up_key==0)
  181.                                                         {
  182.        while(!Up_key);
  183.        hours++;
  184.        if(hours==24)
  185.        hours=0;
  186.
  187.                                                         }
  188.                                                         if(Down_key==0)
  189.                                                         {
  190.        while(!Down_key);
  191.        hours--;
  192.        if(hours==-1)
  193.        hours=23;
  194.                                                         }
  195.                                                         if(key1==0)
  196.                                                         {
  197.        while(!key1);
  198.        back=1;
  199.        break;
  200.                                                         }
  201.                                                 }
  202.                                         }
  203.                                 }
  204.                         }
  205.                         if(Mod_key==0)
  206.                         {
  207.                                 while(!Mod_key);
  208.                                 while(1)
  209.                                 {
  210.                                         display(hours_alarm,minutes_alarm);
  211.                                         if(Up_key==0)
  212.                                         {
  213.                                                 while(!Up_key);
  214.                                                 minutes_alarm++;
  215.                                                 if(minutes_alarm==60)
  216.                                                         minutes_alarm=0;
  217.                                         }
  218.
  219.                                         if(Down_key==0)
  220.                                         {
  221.                                                 while(!Down_key)
  222.                                                 minutes_alarm--;
  223.                                                 if(minutes_alarm==-1)
  224.                                                         minutes_alarm=59;
  225.                                         }
  226.                                         if(back==1)
  227.                                         {
  228.                                                 back==1;
  229.                                                 break;
  230.                                         }
  231.
  232.                                         if(key1==0)
  233.                                         {
  234.                                                 while(!key1);
  235.                                                 while(1)
  236.                                                 {
  237.                                                         display(hours_alarm,minutes_alarm);
  238.                                                         if(Up_key==0)
  239.                                                         {
  240.        while(!Up_key);
  241.        hours_alarm++;
  242.        if(hours_alarm==24)
  243.        hours_alarm=0;
  244.                                                         }
  245.                                                         if(Down_key==0)
  246.                                                         {
  247.        while(!Down_key);
  248.        hours_alarm--;
  249.        if(hours_alarm==-1)
  250.        hours_alarm=23;
  251.                                                         }
  252.                                                         if(Mod_key==0)
  253.                                                         {
  254.        while(!Mod_key);
  255.        back=1;
  256.        Buzzer_flag=0;           //設(shè)定鬧鐘時間后自動開啟蜂鳴器
  257.        break;
  258.                                                         }
  259.
  260.                                                 }
  261.                                         }
  262.                                 }
  263.                         }
  264.                 }
  265.         }
  266. }
  267. void Buzzer()                         //蜂鳴器開關(guān)函數(shù)
  268. {
  269.         if(hours==hours_alarm&&minutes==minutes_alarm)
  270.         {
  271.                 if(Buzzer_flag==0)
  272.                         D1=0;
  273.                 else
  274.                         D1=1;
  275.         }
  276.         else
  277.                 D1=1;
  278. }
  279.
  280. void timer0() interrupt 1
  281. {
  282.         TH0=(65536-50000)/256;
  283.         TL0=(65536-50000)%256;
  284.         t0++;
  285.         if(t0==20)
  286.         {
  287.                 t0=0;
  288.                 seconds++;
  289.                 Secondshi=seconds/10;
  290.                 Secondge=seconds%10;
  291.                 if(seconds==60)
  292.                 {
  293.                         seconds=0;
  294.                         minutes++;
  295.                         Minuteshi=minutes/10;
  296.                         Minutege=minutes%10;
  297.                         if(minutes==60)
  298.                         {
  299.                                 minutes=0;
  300.                                 hours++;
  301.                                 Hourshi=hours/10;
  302.                                 Hourge=hours%10;
  303.                                 if(hours==24)
  304.                                         hours==0;
  305.                         }
  306.
  307.                 }
  308.
  309.         }
  310. }
復(fù)制代碼
