拆microByte
查看數: 792 | 評論數: 4 | 收藏 0
發布時間: 2026-1-28 19:24
好多年的玩具。開關居然壞了。這種側貼片開關的確很容易壞。剛好有剩下的開關,換上,又能工作了。 總結。調溫烙鐵290℃適合比較適合的,拆小零件沒問題,也好上錫。溫度工具依然是問題,沒有風槍。拆個零件只能暴 ...
ID:658914 發表于 2026-1-29 23:05
現在陷入編譯死循環 新版本不支持編譯 提供的固件不知道如何燒錄
ID:658914 發表于 2026-1-29 23:03
joyb 發表于 2026-1-29 16:45
都有什么游戲
全部模擬器游戲。紅白機,gb
還有doom
ID:1064915 發表于 2026-1-29 16:45
都有什么游戲
ID:658914 發表于 2026-1-28 21:28
Update: MicroByte will be available on a crowdfunding campaign at Crowsupply. Check the next link to know more: https://www.crowdsupply.com/byte-mix-labs/microbyte  This is an introduction video of microByte. MicroByte is an open source retro handheld console, with a high pixel density IPS screen of 1.3", SNES gamepad layout with rubber membrane and powered with an ESP32 microcontroller.  You can play with this device: - NES. - GameBoy - GameBoy Color - Sega Master System - GameGear.  I'm the future new emulators will be added, like one which starts with S...  You can find all the information and files in the next GitHub repository: https://github.com/jfm92/microByte  Disclaimer: The device show in this video is not a final version, some changes will be added during development process.
