求大神幫忙點亮TFT彩屏
查看數: 2357 | 評論數: 7 | 收藏 2
發布時間: 2024-12-28 10:57
近日朋友送了個TFT3.5寸的彩屏,用的是ILI9488的驅動這個是屏的正面:
ID:61140 發表于 2024-12-30 20:03
angmall 發表于 2024-12-30 12:36
右邊這一排是你的TFT彩屏 初始化參數。他和我的彩屏初始化參數不一樣,你可以換一下。
算了,不搞了,我還是個菜鳥,對C語言一知半解,僅限于會弄個流水燈
ID:155507 發表于 2024-12-30 12:36
xiaoyuxinke 發表于 2024-12-30 10:06
我只是用了S2SPI_S的11,也就是第四組P7.4-P7.5-P7.6-P7.7
P_SW3 = 0x30;
但是無法顯示,只是白屏
void LCD_Init(void)
        SPI_init(); //初始化硬件SPI
        LCD_ResetFun(); //初始化之前復位
//************* ILI9488初始化**********//        //ILI9488+CTC3.5
        LCD_WR_REG(0XF7);                                        WriteComm(0XF7);
        LCD_WR_DATA(0xA9);                                        WriteData(0xA9);
        LCD_WR_DATA(0x51);                                        WriteData(0x51);
        LCD_WR_DATA(0x2C);                                        WriteData(0x2C);
        LCD_WR_DATA(0x82);                                        WriteData(0x82);
        LCD_WR_REG(0xC0);                                        WriteComm(0xC0);
        LCD_WR_DATA(0x11);                  WriteData(0x10);
        LCD_WR_DATA(0x09);                  WriteData(0x10);
        LCD_WR_REG(0xC1);                                        WriteComm(0xC1);
        LCD_WR_DATA(0x41);                  WriteData(0x41);
        LCD_WR_REG(0XC5);                                        WriteComm(0xC5);
        LCD_WR_DATA(0x00);                  WriteData(0x00);
        LCD_WR_DATA(0x0A);                  WriteData(0x22);
        LCD_WR_DATA(0x80);                  WriteData(0x80);
        LCD_WR_REG(0xB1);                                        WriteComm(0xB1);
        LCD_WR_DATA(0xB0);                  WriteData(0xB0);
        LCD_WR_DATA(0x11);                  WriteData(0x11);
        LCD_WR_REG(0xB4);                                        WriteComm(0xB4);
        LCD_WR_DATA(0x02);                  WriteData(0x02);
        LCD_WR_REG(0xB6);                                        WriteComm(0xB6);
        LCD_WR_DATA(0x42);                  WriteData(0x02);
        LCD_WR_REG(0xB7);                                        WriteComm(0xB7);
        LCD_WR_DATA(0xc6);                  WriteData(0xC6);
        LCD_WR_REG(0xBE);                                        //WriteComm(0XBE);
        LCD_WR_DATA(0x00);                  //WriteData(0x00);
        LCD_WR_DATA(0x04);                  //WriteData(0x04);
        LCD_WR_REG(0xE9);                                        WriteComm(0xE9);
        LCD_WR_REG(0x36);                                                        WriteComm(0x36);
        LCD_WR_DATA((1<<3)|(0<<7)|(1<<6)|(1<<5));   WriteData(0x48);
        LCD_WR_REG(0x3A);                                WriteComm(0x3A);
        LCD_WR_DATA(0x66);              WriteData(0x66);
        LCD_WR_REG(0xE0);                                WriteComm(0xE0);
        LCD_WR_DATA(0x07);              WriteData(0x07);
        LCD_WR_DATA(0x10);              WriteData(0x0f);
        LCD_WR_DATA(0x09);              WriteData(0x0D);
        LCD_WR_DATA(0x17);              WriteData(0x1B);
        LCD_WR_DATA(0x0B);              WriteData(0x0A);
        LCD_WR_DATA(0x41);              WriteData(0x3c);
        LCD_WR_DATA(0x89);              WriteData(0x78);
        LCD_WR_DATA(0x4B);              WriteData(0x4A);
        LCD_WR_DATA(0x0A);              WriteData(0x07);
        LCD_WR_DATA(0x0C);              WriteData(0x0E);
        LCD_WR_DATA(0x0E);              WriteData(0x09);
        LCD_WR_DATA(0x18);              WriteData(0x1B);
        LCD_WR_DATA(0x1B);              WriteData(0x1e);
        LCD_WR_DATA(0x0F);              WriteData(0x0f);
        LCD_WR_REG(0XE1);                                WriteComm(0xE1);
        LCD_WR_DATA(0x17);              WriteData(0x22);
        LCD_WR_DATA(0x1A);              WriteData(0x24);
        LCD_WR_DATA(0x04);              WriteData(0x06);
        LCD_WR_DATA(0x0E);              WriteData(0x12);
        LCD_WR_DATA(0x06);              WriteData(0x07);
        LCD_WR_DATA(0x2F);              WriteData(0x36);
        LCD_WR_DATA(0x45);              WriteData(0x47);
        LCD_WR_DATA(0x43);              WriteData(0x47);
        LCD_WR_DATA(0x02);              WriteData(0x06);
        LCD_WR_DATA(0x0A);              WriteData(0x0a);
        LCD_WR_DATA(0x09);              WriteData(0x07);
        LCD_WR_DATA(0x32);              WriteData(0x30);
        LCD_WR_DATA(0x36);              WriteData(0x37);
        LCD_WR_REG(0x11);  //Sleep OUT (11h)
        delay_ms(120);
        LCD_WR_REG(0x29);  //Display ON (29h)
        //設置LCD屬性參數
        LCD_direction(USE_HORIZONTAL);//設置LCD顯示方向
        LCD_BL=1;//點亮背光
ID:61140 發表于 2024-12-30 10:06
angmall 發表于 2024-12-29 21:41
就是在那個LCD.h里面啊。
P_SW3 = 0x30;
但是無法顯示,只是白屏
不知道什么原因,頭痛……。
ID:155507 發表于 2024-12-29 21:41
xiaoyuxinke 發表于 2024-12-29 14:13
這個程序引腳定義sbit在哪里啊,沒找到
就是在那個LCD.h里面啊。
這個是用硬件SPI,不可以隨便換。
ID:61140 發表于 2024-12-29 14:13
angmall 發表于 2024-12-28 20:52
SPI驅動TFT屏ILI9488的程序@STC32
===STC32G12K128, STC8H8K64U, 開源代碼源程序見附件
ID:155507 發表于 2024-12-28 10:57
/=========================================電源接線================================================//
//5V接DC 5V電源
//GND接地
//=======================================液晶屏數據線接線==========================================//
//本模塊默認數據總線類型為SPI
//液晶屏模塊            單片機
// SDI(MOSI)     接       P23        //SPI寫信號
// SDO(MISO)     接       P         //SPI讀信號,如果不需要讀功能,此管腳可不接
//=======================================液晶屏控制線接線==========================================//
//液晶屏模塊            單片機
//  CS           接       P34       //片選控制信號
//  RESET        接       P43       //復位信號
//  DC           接       P45       //數據/命令選擇控制信號
//  SCK          接       P25       //SPI時鐘信號
//  LED          接       P42       //背光控制信號,如果使用STC89C52RC單片機或者不需要控制,接3.3V
//=========================================觸摸屏接線=========================================//
//不使用觸摸或者模塊本身不帶觸摸,則可不連接
//觸摸屏使用的數據總線類型為SPI
//觸摸屏模塊            單片機
//  T_CLK        接       P25       //觸摸屏SPI時鐘信號
//  T_CS         接       P52       //觸摸屏片選控制信號
//  T_DIN        接       P23       //觸摸屏SPI寫信號
//  T_DO         接       P24       //觸摸屏SPI讀信號
//  T_IRQ        接       P36       //觸摸屏響應檢查信號,如單片機無P4組,請自行更改其他可用IO并修改代碼定義
STC32G_ILI9488.zip
113.3 KB, 下載次數: 0
