發布時間: 2023-7-30 11:42
正文摘要:#include<reg51.h> #define uchar unsigned char #define uint unsigned int sbit p3_3=P3^3; sbit p2_7=P2^7; char led_mod[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf}; char led_ ... |
#include<reg51.h> #define uchar unsigned char #define uint unsigned int sbit p3_3=P3^3; sbit p2_7=P2^7; char led_mod[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf}; char led_com[]={0x01,0x02,0x04,0x08,0x10,0x20}; sbit BEER=P1^1; int TENms,s,m; char data_time[6]; void display() { uint k; data_time[0]=m; data_time[1]=10; data_time[2]=s/10; data_time[3]=s%10; data_time[4]=TENms/10; data_time[5]=TENms%10; for(k=0;k<6;k++) { P2=0xff; P3=led_com[k]; P2=led_mod[data_time[k]]; if(k==3) { p2_7=0; } } } isr_10msT0() interrupt 1 { TH0=(65536-10000)/256; TL0=(65536-10000)%256; TENms++; BEER=0; if(TENms==100) { TENms=0; s++; BEER=1; } if(s==60) { s=0; m++; } if(m==9&&s==59&&TENms==99) { m=9; BEER=0; TENms=0; TR0=0; } } void main(void) { TENms=0; s=0; m=0; BEER=0; TMOD=0x01; TH0=(65536-10000)/256; TL0=(65536-10000)%256; ET0=1; EA=1; while(1) { display(); switch(P1&0xe0) { case 0xc0:TR0=1;break; case 0xa0:TR0=0;TR0=0;break; case 0x60:TR0=0;TENms=0;s=0;m=0;TR0=0;break; } } } 全部功能正常謝謝各位 |
1。沒消影 2。沒延時 3。多余的延時 4。不能大于2^16(65536) |
這個壇里保姆不多,請先注釋好程序,謝謝 ![]() |
| 其他且不論先點一個數碼管正常后再點第二直到所有正常后再調試其他功能 |
