為啥單片機(jī)串口解析時好時壞希望有大佬能解決下
查看數(shù): 2004 | 評論數(shù): 12 | 收藏 0
發(fā)布時間: 2023-3-16 10:09
#include "..\comm\STC32G.h" #include "stdio.h" #include "intrins.h" #include "string.h" typedef         unsigned char      &nb ...
ID:1066795 發(fā)表于 2023-3-19 16:37
  1. if( M_Flag)
  2.                                         {
  3.
  4.                                                 PrintString1(RX1_Buffer);
  5.                                                 PrintString1("\n");
  6.                                                 M_index[M_index_num]=RX1_Buffer[3] ;
  7.                                                 M_index_num++;
  8.                                                 memset(RX1_Buffer,0,RX1_Cnt);
  9.                                                  M_Flag   =0;
  10.                                                 RX1_Cnt         =0;
  11.                                                 PrintString1(M_index);
  12.                                                 PrintString1("\n");
  13.                                         }
  14. void UART1_int (void) interrupt 4
  15. {
  16.
  17. //
  18. //                if(RI) // 中斷產(chǎn)生
  19. //                                {
  20. //                                        RI=0 ; //清除中斷標(biāo)志
  21. //                                        RX1_Buffer[RX1_Cnt] = SBUF;
  22. //                                        RX1_Cnt++;
  23. //                                        if(RX1_Cnt >= UART1_BUF_LENGTH)
  24. //                                                        {RX1_Cnt = 0;}
  25. //                                        }
  26. //                if((RX1_Buffer[RX1_Cnt-1]==0x2B)&&(RX1_Buffer[RX1_Cnt]==0x43))//頭
  27. //        {        Cnt_head  = RX1_Cnt-1;}
  28. //                if((RX1_Buffer[Cnt_head]==0x2B)&&(RX1_Buffer[Cnt_head+1]==0x43)&&(RX1_Buffer[RX1_Cnt-1]==0x0A)) //檢測到頭的情況下檢測尾巴
  29. //                                {
  30. //                                                Cnt_len = RX1_Cnt-1 - Cnt_head;
  31. //
  32. //                                                Uart_S = 1;
  33. //                                          RX1_Cnt = 0;
  34. //                                                Cnt_head =0;
  35. ////
  36. //                                }
  37.                          if(RI)//如果產(chǎn)生中斷
  38.                                  {
  39.
  40.                                         switch(state){
  41.                                                 case 1:
  42.        if(SBUF == 0x4C){ //頭
  43.        RX1_Cnt=0;
  44.        state = 2;
  45.        RX1_Buffer[RX1_Cnt++] = SBUF;
  46.        }
  47.        else
  48.        {
  49.        state=1;
  50.        RX1_Cnt=0;
  51.
  52.        }
  53.        break;
  54.
  55.                                                 case 2:
  56.        if(SBUF == 0x3A){ //頭
  57.        state = 3;
  58.        RX1_Buffer[RX1_Cnt++] = SBUF;
  59.        }
  60.        else
  61.        {
  62.        state=1;
  63.        RX1_Cnt=0;
  64.
  65.        }
  66.        break;
  67.
  68.                                                  case 3:
  69.        if(SBUF==0x2C){  //尾
  70.
  71.        RX1_Buffer[RX1_Cnt++] = SBUF;
  72.        M_Flag = 1;
  73.        state =1;
  74.
  75.        }
  76.        else
  77.        {
  78.
  79.        RX1_Buffer[RX1_Cnt++] = SBUF;
  80.        state=3;
  81.        }
  82.        break;
  83.
  84.
  85.                                                  default:
  86.        state = 1;
  87.        break;
  88.
  89.                                         }
  90.
  91.                                          RI = 0;
  92.                  }
  93.
  94.     if(TI)
  95.     {
  96.         TI = 0;
  97.         B_TX1_Busy = 0;
  98.     }
  99.
  100. }
復(fù)制代碼
這個應(yīng)該是可以解決指定頭和位幀然后不定長數(shù)據(jù)解析了吧嘿嘿
ID:1066795 發(fā)表于 2023-3-17 11:13
lkc8210 發(fā)表于 2023-3-17 10:14
由于12行的關(guān)系
13行的RX1_Buffer[RX1_Cnt-1]為接收值后面的RX1_Buffer[RX1_Cnt]永遠(yuǎn)等于0
按照您這么說,這確實(shí)后面的那個RX1_Buffer[RX1_Cnt] 沒有值
ID:161164 發(fā)表于 2023-3-17 10:14
yslsdas 發(fā)表于 2023-3-17 08:58
emm 抱歉實(shí)在是 邏輯理解不出來 RX1_Cnt-1 時為0x2B (+)RX1_Cnt 時 為 0x43 (C) 這里有什么邏輯問題,還 ...
由于12行的關(guān)系
ID:1066795 發(fā)表于 2023-3-17 08:59
lihuajie32 發(fā)表于 2023-3-16 20:56
不用大佬,小弟就可以,時好時壞,以硬件的角度看,沒插好、插頭慫了,軟件看那是玄學(xué)!
線什么的應(yīng)該沒什么問題
ID:1066795 發(fā)表于 2023-3-17 08:58
人中狼 發(fā)表于 2023-3-16 22:08
這里邏輯問題
emm 抱歉實(shí)在是 邏輯理解不出來 RX1_Cnt-1 時為0x2B (+)RX1_Cnt 時 為 0x43 (C) 這里有什么邏輯問題,還望不吝賜教
ID:384109 發(fā)表于 2023-3-16 22:08
這里邏輯問題
ID:1066823 發(fā)表于 2023-3-16 20:56
ID:1066795 發(fā)表于 2023-3-16 18:34
人中狼 發(fā)表于 2023-3-16 15:42
中斷里的接收判斷錯誤了
能略微指點(diǎn)一下嗎?
ID:384109 發(fā)表于 2023-3-16 15:42
中斷里的接收判斷錯誤了
ID:807182 發(fā)表于 2023-3-16 14:48
中斷盡量快,不要處理數(shù)據(jù),把數(shù)據(jù)放到其他地方判斷
ID:1066795 發(fā)表于 2023-3-16 11:24
有大佬幫忙看看嗎?
