單片機LED數碼管顯示數字及左移程序Proteus仿真(獨立按鍵)
查看數: 3755 | 評論數: 3 | 收藏 0
發布時間: 2022-11-28 21:55
單片機獨立按鍵控制LED數碼管顯示數字及左移 仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
ID:1135525 發表于 2024-11-5 14:31
U2是什么元件
ID:1135525 發表于 2024-11-5 10:53
終于找到關于多個數碼管動態顯示的帖子了
ID:1134495 發表于 2024-11-2 23:48
請問使用矩陣鍵盤的話應該怎么改
// 矩陣鍵盤讀取按鍵鍵碼
unsigned char MatrixKey()
    unsigned char KeyNumber = 0;
    P1 = 0xFF;
    P1_3 = 0;
    if (P1_7 == 0) {Delay_ms(20); while (P1_7 == 0); Delay_ms(20); KeyNumber = 16;}
    if (P1_6 == 0) {Delay_ms(20); while (P1_6 == 0); Delay_ms(20); KeyNumber = 15;}
    if (P1_5 == 0) {Delay_ms(20); while (P1_5 == 0); Delay_ms(20); KeyNumber = 14;}
    if (P1_4 == 0) {Delay_ms(20); while (P1_4 == 0); Delay_ms(20); KeyNumber = 13;}
    P1 = 0xFF;
    P1_2 = 0;
    if (P1_7 == 0) {Delay_ms(20); while (P1_7 == 0); Delay_ms(20); KeyNumber = 12;}
    if (P1_6 == 0) {Delay_ms(20); while (P1_6 == 0); Delay_ms(20); KeyNumber = 11;}
    if (P1_5 == 0) {Delay_ms(20); while (P1_5 == 0); Delay_ms(20); KeyNumber = 10;}
    if (P1_4 == 0) {Delay_ms(20); while (P1_4 == 0); Delay_ms(20); KeyNumber = 9;}
    P1 = 0xFF;
    P1_1 = 0;
    if (P1_7 == 0) {Delay_ms(20); while (P1_7 == 0); Delay_ms(20); KeyNumber = 8;}
    if (P1_6 == 0) {Delay_ms(20); while (P1_6 == 0); Delay_ms(20); KeyNumber = 7;}
    if (P1_5 == 0) {Delay_ms(20); while (P1_5 == 0); Delay_ms(20); KeyNumber = 6;}
    if (P1_4 == 0) {Delay_ms(20); while (P1_4 == 0); Delay_ms(20); KeyNumber = 5;}
    P1 = 0xFF;
    P1_0 = 0;
    if (P1_7 == 0) {Delay_ms(20); while (P1_7 == 0); Delay_ms(20); KeyNumber = 4;}
    if (P1_6 == 0) {Delay_ms(20); while (P1_6 == 0); Delay_ms(20); KeyNumber = 3;}
    if (P1_5 == 0) {Delay_ms(20); while (P1_5 == 0); Delay_ms(20); KeyNumber = 2;}
    if (P1_4 == 0) {Delay_ms(20); while (P1_4 == 0); Delay_ms(20); KeyNumber = 1;}
    return KeyNumber;
