18V 2A 500KHz Synchronous Step-Down Regulator SL1588
查看數: 1556 | 評論數: 0 | 收藏 0
發布時間: 2021-6-28 14:01
General Description The SL1588 is a high frequency, synchronous, rectified, step-down, switch-mode converter with internal power MOSFETs. It offers a very compact solution to achieve a 2A continuous ...
