單片機8*8點陣程序的警告找不出來,麻煩各位大佬幫忙看一看
查看數: 3689 | 評論數: 15 | 收藏 0
發布時間: 2021-6-20 14:55
8*8點陣程序,我檢查很多次,都看不出程序的問題,可還是會有一個警告,麻煩各位大佬幫忙看一下,這到底是哪里出問題了 單片機源程序如下:         //     &nb ...
ID:934353 發表于 2021-6-29 17:27
很簡單,就是你定義了beep函數,卻沒有調用過它,因為你把beep函數放在while(1)死循環后面了,而且你的死循環里也沒有跳出的條件,所以你跳不出死循環就執行不到beep函數,包括j++那些都執行不到的
ID:155507 發表于 2021-6-22 10:13
給你改了,對比一下就知道哪里錯了。
  1. //  ***************************************************************************************/
  2. #include "reg51.h"                         //此文件中定義了單片機的一些特殊功能寄存器
  3. #include<intrins.h>
  4. typedef unsigned int u16;          //對數據類型進行聲明定義
  5. typedef unsigned char u8;
  6. sbit SRCLK=P3^6;
  7. sbit RCLK=P3^5;
  8. sbit SER=P3^4;
  9. sbit buzzer=P1^5;
  10. unsigned char code ledduan[17][8]={
  11.         {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00},
  12.         {0x00,0x00,0x24,0x7C,0x04,0x00,0x00,0x00},
  13.         {0x00,0x00,0x26,0x4A,0x52,0x22,0x00,0x00},
  14.         {0x00,0x00,0x2A,0x2A,0x2A,0x3E,0x00,0x00},
  15.         {0x00,0x08,0x18,0x28,0x7E,0x08,0x00,0x00},
  16.         {0x00,0x00,0x7A,0x4A,0x4E,0x00,0x00,0x00},
  17.         {0x00,0x00,0x7E,0x4A,0x4E,0x00,0x00,0x00},
  18.         {0x00,0x40,0x40,0x40,0x7E,0x00,0x00,0x00},
  19.         {0x00,0x7E,0x4A,0x4A,0x7E,0x00,0x00,0x00},
  20.         {0x00,0x7A,0x4A,0x4A,0x7E,0x00,0x00,0x00},
  21.         {0x00,0x7A,0x4A,0x4A,0x7E,0x00,0x00,0x00},
  22.         {0x00,0x00,0x7E,0x48,0x78,0x00,0x00,0x00},
  23.         {0x00,0x00,0x7E,0x48,0x48,0x00,0x00,0x00},
  24.         {0x40,0x40,0x7E,0x40,0x40,0x00,0x00,0x00},
  25.         {0x00,0x00,0x3E,0x02,0x02,0x00,0x00,0x00},
  26.         {0x00,0x00,0x3E,0x02,0x3E,0x00,0x00,0x00},
  27.         {0x00,0x30,0x48,0x24,0x24,0x48,0x30,0x00}
  28. } ;
  29. unsigned char code ledwei[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  30. void delay1(u16 i)
  31. {
  32.         while(i--);
  33. }
  34. void beep()
  35. {
  36.         u16 i;
  37.         for(i=0;i<100;i++)
  38.         {
  39.                 delay1(100);
  40.                 buzzer=~buzzer;
  41.         }}
  42. void delay(unsigned int time)
  43. {
  44.         unsigned int i,j;
  45.         for (i=0;i<time;i++)
  46.         for (j=0;j<121;j++);
  47. }
  48. /*******************************************************************************
  49. * 函數名         : Hc595SendByte(u8 dat)
  50. * 函數功能                   : 向74HC595發送一個字節的數據,從高位開始到低位
  51. * 輸入           : 無
  52. * 輸出                  : 無
  53. *******************************************************************************/
  54. void Hc595SendByte(u8 dat)
  55. {
  56.         u8 a;
  57.         SRCLK=0;
  58.         RCLK=0;
  59.         for(a=0;a<8;a++)
  60.         {
  61.                 SER=dat>>7;//運算時,先將dat的值復制到一個臨時單元,向右移位運算的是臨時單元的值,而不是dat,所以移位后, dat的值不變。
  62.                 dat<<=1;
  63.                 SRCLK=1;
  64.                 _nop_();
  65.                 _nop_();
  66.                 SRCLK=0;
  67.         }
  68.         RCLK=1;
  69.         _nop_();
  70.         _nop_();
  71.         RCLK=0;
  72. }
  73. /*******************************************************************************
  74. * 函 數 名       : main
  75. * 函數功能                 : 主函數
  76. * 輸    入       : 無
  77. * 輸    出             : 無
  78. *******************************************************************************/
  79. void main()
  80. {
  81.         unsigned char tab,j;
  82.         unsigned int i;
  83.         while(1)
  84.         {
  85.
  86.                 for (i=0;i<50;i++)
  87.                 { for(tab=0;tab<8;tab++)
  88.                         {          Hc595SendByte(0x00);//消隱,去掉重影
  89.                                 P0=ledwei[tab];
  90.                                 Hc595SendByte(ledduan[j][tab]);
  91.                                 delay(2);
  92.
  93.                         }
  94.                 }
  95.             //} <-------
  96.                 j++;
  97.                 beep();
  98.                 if(j==17)
  99.                 {
  100.                         j=0;
  101.                 }
  102.         }
  103. } //<-----
ID:811711 發表于 2021-6-22 08:58
說的很清楚啊 有個函數你沒有調用
ID:939657 發表于 2021-6-21 22:52
xuyaqi 發表于 2021-6-20 20:04
警告c294看到了嗎?
這個沒問題吧,我用keil4編譯,它只出現一個警告
ID:939657 發表于 2021-6-21 22:50
Carose 發表于 2021-6-20 20:22
這個警告我教你怎么看。可以不用管,segment那里PR?后面那個BEEP意思是提醒你可能有聲明了BEEP函數但是你沒 ...
要用的,我就在j++下面加了
ID:878061 發表于 2021-6-20 22:29
你把beep()函數放在了死循環while(1)的大括號外面,永遠執行不到beep(),所以警告
ID:941075 發表于 2021-6-20 21:48
謝謝樓主也謝謝51黑平臺!
ID:922355 發表于 2021-6-20 20:22
這個警告我教你怎么看。可以不用管,segment那里PR?后面那個BEEP意思是提醒你可能有聲明了BEEP函數但是你沒有用它。如果要用到它,調用它,不用他就注掉,或者你不用管那個警告不會影響編譯運行。
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:94031 發表于 2021-6-20 20:04
tyq666 發表于 2021-6-20 19:44
編譯過了,上面的圖片就是編譯后出現的問題,有一個警告
警告c294看到了嗎?
ID:939657 發表于 2021-6-20 19:44
xuyaqi 發表于 2021-6-20 19:41
你發的程序,你編譯通過了嗎?
ID:94031 發表于 2021-6-20 19:41
tyq666 發表于 2021-6-20 19:14
請問是主程序哪里有問題呢?
你發的程序,你編譯通過了嗎?
ID:939657 發表于 2021-6-20 19:14
請問是主程序哪里有問題呢?
ID:939657 發表于 2021-6-20 19:13
名字不是重點 發表于 2021-6-20 16:02
你定義了一個BEEP的函數,卻沒有調用過它。。。就是這個意思,,
用了,主程序j++下面的程序
ID:94031 發表于 2021-6-20 16:24
main 程序有問題
ID:824490 發表于 2021-6-20 16:02
