電機控制專用國產32位單片機MM32SPIN360C規格書下載
查看數: 4310 | 評論數: 3 | 收藏 1
發布時間: 2020-11-30 15:13
靈動微電子是本土領先的通用32位MCU產品及解決方案供應商,提供MM32 MCU基于Arm Cortex-M系列內核200多個型號,MM32 MCU被廣泛應用于工業、電機、家電、消費玩具、手機平板配件、醫療、交通出行、顯示及交互等領域。 ...
ID:228452 發表于 2022-9-18 20:57
Motor-DK (MM32SPIN360C)
Input voltage range: 12V - 28V
Use 60V / 40A N-MOS tube x 6
Use built-in GBW 6MHz high-speed op amp x 3
MCU uses 5V power supply
Support with/without Hall, square wave/sine wave drive
Support 1 / 2 Shunt R three-phase current sampling
BEMF voltage feedback using ADC sampling
Support DC Bus voltage, total current measurement
Use MCU built-in comparator as overcurrent protection
With potentiometer speed regulation, LED and other functions
ID:228452 發表于 2022-9-18 20:46
Is there a code, the code to control the motor? "
https://gitee.com/seekfree/MM32SPIN360C_BLDC_Project
ID:462629 發表于 2021-3-12 10:16
有代碼嗎,控制電機的代碼?
