請問stc單片機15的硬件SPI可以驅動oled嗎,oled用spi方式
查看數: 3056 | 評論數: 3 | 收藏 1
發布時間: 2020-8-23 10:00
試了好多次,都不亮 用軟件模擬spi可以,硬件spi不亮。沒找到原因。
ID:155507 發表于 2020-8-25 22:48
需要你仔細看器件的SPI時序圖
我給你來個程序試試
  1. #include <stc15.h>      //本例程為SSD1329驅動芯片的96x96OLED屏
  2. sbit RSDC=P1^0;         //即D/C  0是command  1是data
  3. sbit CS=P1^1;          //片選        低有效
  4. struct hanzi                                 // 漢字字模數據結構
  5. {
  6.         unsigned char index[2];         // 漢字內碼索引
  7.         unsigned char msk[32];         // 點陣碼數據
  8. };
  9. struct hanzi code hz[]=
  10. {
  11.         "床", 0x01,0x00,0x00,0x84,0x3F,0xFE,0x20,0x80,
  12.         0x20,0x80,0x20,0x88,0x3F,0xFC,0x20,0x80,
  13.         0x21,0xC0,0x21,0xA0,0x22,0x90,0x24,0x88,
  14.         0x48,0x8E,0x50,0x84,0x80,0x80,0x00,0x80,
  15.         "前", 0x10,0x10,0x0C,0x30,0x04,0x44,0xFF,0xFE,
  16.         0x00,0x00,0x3E,0x08,0x22,0x48,0x22,0x48,
  17.         0x3E,0x48,0x22,0x48,0x22,0x48,0x3E,0x48,
  18.         0x22,0x08,0x22,0x08,0x2A,0x28,0x24,0x10,
  19.         "明", 0x00,0x04,0x04,0xFE,0x7E,0x84,0x44,0x84,
  20.         0x44,0x84,0x44,0xFC,0x7C,0x84,0x44,0x84,
  21.         0x44,0x84,0x44,0xFC,0x7C,0x84,0x44,0x84,
  22.         0x01,0x04,0x01,0x04,0x02,0x14,0x04,0x08,
  23.         "月", 0x00,0x10,0x0F,0xF8,0x08,0x10,0x08,0x10,
  24.         0x08,0x10,0x0F,0xF0,0x08,0x10,0x08,0x10,
  25.         0x08,0x10,0x0F,0xF0,0x08,0x10,0x08,0x10,
  26.         0x10,0x10,0x10,0x10,0x20,0x50,0x40,0x20,
  27.         "光", 0x01,0x00,0x21,0x08,0x11,0x0C,0x09,0x10,
  28.         0x09,0x20,0x01,0x04,0xFF,0xFE,0x04,0x40,
  29.         0x04,0x40,0x04,0x40,0x04,0x40,0x08,0x40,
  30.         0x08,0x42,0x10,0x42,0x20,0x3E,0x40,0x00,
  31.         "疑", 0x20,0x00,0x26,0xFC,0x38,0x08,0x22,0x50,
  32.         0x1E,0x20,0x21,0xFE,0x3E,0x22,0x48,0x24,
  33.         0x08,0xA0,0xFE,0xB8,0x08,0xA0,0x08,0xA0,
  34.         0x14,0xE0,0x22,0xA0,0x41,0x1E,0x02,0x04,
  35.         "是", 0x0F,0xE0,0x08,0x20,0x08,0x20,0x0F,0xE0,
  36.         0x08,0x20,0x08,0x20,0x0F,0xE0,0x00,0x04,
  37.         0xFF,0xFE,0x01,0x00,0x09,0x20,0x09,0xF0,
  38.         0x09,0x00,0x15,0x00,0x23,0x06,0x40,0xFC,
  39.         "地", 0x00,0x40,0x20,0x40,0x22,0x40,0x22,0x40,
  40.         0x22,0x48,0x22,0x7C,0xFB,0xC8,0x26,0x48,
  41.         0x22,0x48,0x22,0x48,0x22,0x68,0x22,0x50,
  42.         0x3A,0x42,0xE2,0x02,0x41,0xFE,0x00,0x00,
  43.         "上", 0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
  44.         0x01,0x10,0x01,0xF8,0x01,0x00,0x01,0x00,
  45.         0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
  46.         0x01,0x00,0x01,0x04,0xFF,0xFE,0x00,0x00,
  47.         "霜", 0x1F,0xF0,0x01,0x00,0x7F,0xFE,0x41,0x02,
  48.         0x9D,0x74,0x01,0x00,0x1D,0x70,0x08,0x04,
  49.         0x08,0xFE,0x7E,0x84,0x08,0xFC,0x1C,0x84,
  50.         0x2A,0xFC,0x48,0x84,0x08,0xFC,0x08,0x84,
  51.         "舉", 0x22,0x08,0x19,0x18,0x09,0x20,0x00,0x44,
  52.         0xFF,0xFE,0x04,0x40,0x09,0x20,0x11,0x10,
  53.         0x2F,0xEE,0xC1,0x04,0x01,0x10,0x3F,0xF8,
  54.         0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
  55.         "頭", 0x00,0x80,0x00,0x80,0x08,0x80,0x06,0x80,
  56.         0x22,0x80,0x18,0x80,0x08,0x80,0x00,0x84,
  57.         0xFF,0xFE,0x00,0x80,0x01,0x00,0x01,0x60,
  58.         0x02,0x10,0x04,0x08,0x18,0x0C,0x60,0x04,
  59.         "望", 0x10,0x04,0x0A,0x7E,0xFF,0x44,0x20,0x7C,
  60.         0x20,0x44,0x26,0x7C,0x38,0x44,0x20,0x8C,
  61.         0x00,0x00,0x3F,0xF8,0x01,0x00,0x1F,0xF0,
  62.         0x01,0x00,0x01,0x04,0xFF,0xFE,0x00,0x00,
  63.         "低", 0x10,0x08,0x10,0x3C,0x17,0xC0,0x24,0x40,
  64.         0x24,0x40,0x64,0x40,0xA4,0x44,0x27,0xFE,
  65.         0x24,0x20,0x24,0x20,0x24,0x20,0x24,0x90,
  66.         0x25,0x12,0x26,0x4A,0x24,0x2A,0x20,0x04,
  67.         "思", 0x00,0x08,0x3F,0xFC,0x21,0x08,0x21,0x08,
  68.         0x21,0x08,0x3F,0xF8,0x21,0x08,0x21,0x08,
  69.         0x21,0x08,0x3F,0xF8,0x20,0x08,0x02,0x00,
  70.         0x51,0x88,0x50,0x96,0x90,0x12,0x0F,0xF0,
  71.         "故", 0x10,0x40,0x10,0x40,0x10,0x40,0x14,0x44,
  72.         0xFE,0xFE,0x11,0x08,0x12,0x88,0x10,0x88,
  73.         0x7C,0x88,0x44,0x88,0x44,0x50,0x44,0x20,
  74.         0x44,0x20,0x7C,0x50,0x44,0x8E,0x03,0x04,
  75.         "鄉", 0x02,0x00,0x02,0x00,0x04,0x20,0x08,0x20,
  76.         0x10,0x40,0x3F,0x80,0x01,0x00,0x02,0x08,
  77.         0x04,0x08,0x3F,0xF0,0x00,0x20,0x00,0x40,
  78.         0x00,0x80,0x03,0x00,0x0C,0x00,0x70,0x00,
  79.         "靜", 0x08,0x40,0x08,0x40,0x7E,0xF8,0x09,0x10,
  80.         0x3E,0x24,0x08,0xFE,0xFF,0x24,0x00,0x24,
  81.         0x3F,0xFE,0x22,0x24,0x3E,0x24,0x22,0xFC,
  82.         0x3E,0x24,0x22,0x20,0x22,0xA0,0x26,0x40,
  83.         "夜", 0x02,0x00,0x01,0x04,0xFF,0xFE,0x08,0x80,
  84.         0x08,0x80,0x10,0xF8,0x11,0x08,0x32,0x88,
  85.         0x56,0x50,0x99,0x10,0x10,0xA0,0x10,0x40,
  86.         0x10,0xA0,0x11,0x10,0x12,0x0E,0x1C,0x04,
  87.         "唐", 0x01,0x00,0x00,0x88,0x3F,0xFC,0x20,0x80,
  88.         0x2F,0xF8,0x20,0x88,0x3F,0xFE,0x20,0x88,
  89.         0x2F,0xF8,0x20,0x80,0x2F,0xF8,0x28,0x08,
  90.         0x48,0x08,0x48,0x08,0x8F,0xF8,0x08,0x08,
  91.         "李", 0x01,0x00,0x01,0x08,0x7F,0xFC,0x01,0x00,
  92.         0x05,0x40,0x09,0x30,0x31,0x0E,0xC1,0x04,
  93.         0x0F,0xE0,0x00,0x40,0x01,0x88,0x7F,0xFC,
  94.         0x01,0x00,0x01,0x00,0x05,0x00,0x02,0x00,
  95.         "白", 0x02,0x00,0x04,0x00,0x08,0x08,0x3F,0xFC,
  96.         0x20,0x08,0x20,0x08,0x20,0x08,0x20,0x08,
  97.         0x3F,0xF8,0x20,0x08,0x20,0x08,0x20,0x08,
  98.         0x20,0x08,0x3F,0xF8,0x20,0x08,0x00,0x00,
  99.         "。", 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  100.         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  101.         0x00,0x00,0x00,0x00,0x3C,0x00,0x66,0x00,
  102.         0x66,0x00,0x66,0x00,0x3C,0x00,0x00,0x00,
  103.         ",", 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  104.         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  105.         0x0C,0x00,0x1E,0x00,0x1E,0x00,0x0C,0x00,
  106.         0x04,0x00,0x08,0x00,0x10,0x00,0x00,0x00
  107. };
  108. void init_oled();                                                  //屏初始化,各種datasheet的設置,官方參考數據
  109. void WriteComm(unsigned char com);                  //單片機寫命令
  110. void WriteData(unsigned char dat);                  //單片機寫數據
  111. void init_SPI();                                    //單片機SPI初始化
  112. void Delayms(unsigned int t);
  113. void sawhz(unsigned char x,unsigned char y,unsigned char c[2]);                  //設置起止坐標并寫漢字數據
  114. void clear();                                       //清屏
  115. void write(unsigned dat);                           //最終寫data函數,最高亮度,由4bit變1bit
  116. //因為本驅動是一個Byte的其中4位控制一個led像素點,共16種灰度模式,1111為亮  0000為熄滅
  117. //比如一個字節的低四位是D0像素,高四位是D1像素,依次類推
  118. //void writehz(unsigned char c[2]);
  119. unsigned char m;
  120. unsigned int i;
  121. void main()
  122. {
  123.         P0M0 = 0x00;
  124.         P0M1 = 0x00;
  125.         P1M0 = 0x00;
  126.         P1M1 = 0x00;
  127.         P2M0 = 0x00;
  128.         P2M1 = 0x00;
  129.         P3M0 = 0x00;
  130.         P3M1 = 0x00;
  131.         P4M0 = 0x00;
  132.         P4M1 = 0x00;
  133.         P5M0 = 0x00;
  134.         P5M1 = 0x00;
  135.         P6M0 = 0x00;
  136.         P6M1 = 0x00;
  137.         P7M0 = 0x00;
  138.         P7M1 = 0x00;                                //全設置為準雙向口
  139.         init_SPI();
  140.         init_oled();
  141.         clear();
  142.         sawhz(12,0,"靜");
  143.         sawhz(20,0,"夜");
  144.         sawhz(28,0,"思");
  145.         sawhz(8,16,"唐");
  146.         sawhz(20,16,"李");
  147.         sawhz(28,16,"白");
  148.         sawhz(0,32,"床");
  149.         sawhz(8,32,"前");
  150.         sawhz(16,32,"明");
  151.         sawhz(24,32,"月");
  152.         sawhz(32,32,"光");
  153.         sawhz(40,32,",");
  154.         sawhz(0,48,"疑");
  155.         sawhz(8,48,"是");
  156.         sawhz(16,48,"地");
  157.         sawhz(24,48,"上");
  158.         sawhz(32,48,"霜");
  159.         sawhz(40,48,"。");
  160.         sawhz(0,64,"舉");
  161.         sawhz(8,64,"頭");
  162.         sawhz(16,64,"望");
  163.         sawhz(24,64,"明");
  164.         sawhz(32,64,"月");
  165.         sawhz(40,64,",");
  166.         sawhz(0,80,"低");
  167.         sawhz(8,80,"頭");
  168.         sawhz(16,80,"思");
  169.         sawhz(24,80,"故");
  170.         sawhz(32,80,"鄉");
  171.         sawhz(40,80,"。");
  172.         while(1);
  173. }
  174. void clear()                //清屏
  175. {
  176.         for(i=4608;i>0;i--)
  177.         WriteData(0x00);
  178. }
  179. /*
  180. void writehz(unsigned char c[2])
  181. {
  182.                 unsigned char i,k;
  183.                 for(k=0;k<23;k++)                           //23 代表字庫中的個數  輪詢方式查詢
  184.                 {
  185.                                 if((hz[k].index[0]==c[0])&&(hz[k].index[1]==c[1]))                         //數據結構查詢
  186.                                 {
  187.                                                 for(i=0;i<32;i++)
  188.        write(hz[k].msk);
  189.                                 }
  190.                 }
  191. }
  192. */
  193. void sawhz(unsigned char x,unsigned char y,unsigned char c[2])                         //setxy and writehz  頭字母saw  設置起止坐標并寫漢字
  194. {
  195.         unsigned char i,k;
  196.         WriteComm(0x15);//SET COLUMN ADDR
  197.         WriteComm(0x10+x);//第 16+x 列開始                 即本屏幕的第一列
  198.         WriteComm(0x10+x+7);  //第16+x+3列結束
  199.         WriteComm(0x75);//SET ROW ADDR
  200.         WriteComm(0x00+y);//第 0+y 行開始
  201.         WriteComm(0x00+y+15);//第0+y+15行結束   共16行
  202.         for(k=0;k<25;k++)
  203.         {
  204.                 if((hz[k].index[0]==c[0])&&(hz[k].index[1]==c[1]))
  205.                 {
  206.                         for(i=0;i<32;i++)
  207.                         write(hz[k].msk);
  208.                 }
  209.         }
  210. }
  211. void Delayms(unsigned int t)         //stc15@11.0592   1ms延時
  212. {
  213.         unsigned int a,b;
  214.         for(a=t;a>0;a--)
  215.         for(b=850;b>0;b--);
  216. }
  217. void WriteComm(unsigned char com)                   //單片機寫命令SPI函數
  218. {
  219.         RSDC=0;
  220.         SPSTAT=0xc0;                //SPIstat clear
  221.         SPDAT=com;                  //upper eight bits
  222.         while((SPSTAT&0x80)==0);    //wait for transfer finished
  223.         SPSTAT=0xc0;                //SPIstat clear
  224.         RSDC=1;
  225. }
  226. void WriteData(unsigned char dat)                   //單片機寫data,SPI函數
  227. {
  228.         RSDC=1;
  229.         SPSTAT=0xc0;                //SPIstat clear
  230.         SPDAT=dat;                  //upper eight bits
  231.         while((SPSTAT&0x80)==0);    //wait for transfer finished
  232.         SPSTAT=0xc0;                //SPIstat clear
  233.         RSDC=0;
  234. }
  235. void write(unsigned dat)                         //最終寫data函數,最高亮度,由4bit變1bit
  236. {
  237.         unsigned char n;
  238.         for(n=0;n<4;n++)
  239.         {
  240.                 if((dat&0xc0)==0xc0)           //與1100 0000與,留高兩位
  241.                 WriteData(0xff);
  242.                 else if((dat&0xc0)==0x80)
  243.                 WriteData(0xf0);
  244.                 else if((dat&0xc0)==0x40)
  245.                 WriteData(0x0f);
  246.                 else
  247.                 WriteData(0x00);
  248.                 dat<<=2;
  249.         }
  250. }
  251. void init_SPI()
  252. {
  253.         SPDAT=0;
  254.         SPSTAT=0xc0;           //SPIstat clear
  255.         SPCTL=0xdc;            //master         dc高到低   f8低到高   SSIG=1 SPEN=1 MSTR =1 CPOL=1 CPHA=1
  256. }
  257. void init_oled()
  258. {
  259.         CS=0;
  260.         Delayms(25);
  261.         WriteComm(0x15);//SET COLUMN ADDR
  262.         WriteComm(0x10);//第16列開始
  263.         WriteComm(0x3f);  //第63列結束  共(63-16+1)*2=96列
  264.         WriteComm(0x75);//SET ROW ADDR
  265.         WriteComm(0x00);//第0行開始
  266.         WriteComm(0x5f);//第95行結束   共96行
  267.         WriteComm(0xA0);//SET RE-MAP
  268.         WriteComm(0x51);
  269.         WriteComm(0xA1);//SET DISPLAY START LINE
  270.         WriteComm(0x00);
  271.         WriteComm(0xA2);//SET DISPLAY OFFSET
  272.         WriteComm(0x60);
  273.         WriteComm(0xA4);//SET DISPLAY MODE
  274.         WriteComm(0xA8);//SET MUX RADIO
  275.         WriteComm(0x5F);
  276.         WriteComm(0xB2);//SET FRAME FREQUENCY
  277.         WriteComm(0x23);
  278.         WriteComm(0xB3);//SET FRONT CLOCK DIVIDER & OSCILLATOR FREQUENCY
  279.         WriteComm(0xF0);
  280.         WriteComm(0x81);//SET CONTRAST CURRENT
  281.         WriteComm(0x7F);//
  282.         WriteComm(0xBC);    //first pre_charge voltage
  283.         WriteComm(0x1F);
  284.         Delayms(10);
  285.         WriteComm(0x82);   //second pre_charge speed
  286.         WriteComm(0xFE);
  287.         Delayms(10);
  288.         WriteComm(0xB1);   //first pre_charge phase length
  289.         WriteComm(0x21);
  290.         WriteComm(0xBB);//SET SECONDE PRE_CHARGE PERIOD
  291.         WriteComm(0x0F);
  292.         WriteComm(0xbe);//SET VCOMH
  293.         WriteComm(0x1F);
  294.         WriteComm(0xB8);        //SET GS
  295.         WriteComm(0x04); //GS1
  296.         WriteComm(0x06); //GS2
  297.         WriteComm(0x08); //GS3
  298.         WriteComm(0x0A); //GS4
  299.         WriteComm(0x0C); //GS5
  300.         WriteComm(0x0E); //GS6
  301.         WriteComm(0x10); //GS7
  302.         WriteComm(0x12); //GS8
  303.         WriteComm(0x14); //GS9
  304.         WriteComm(0x16); //GS10
  305.         WriteComm(0x18); //GS11
  306.         WriteComm(0x1A); //GS12
  307.         WriteComm(0x1C); //GS13
  308.         WriteComm(0x1E); //GS14
  309.         WriteComm(0x20); //GS15
  310.         Delayms(10);
  311.         WriteComm(0xAF);         //DSPLAY ON
  312. }
ID:123289 發表于 2020-8-25 17:18
學會查手冊吧,SPI的口輸入電壓電流的極限是多少?你的OLED要求是多少?不就有答案了嗎。
ID:804115 發表于 2020-8-23 19:26
用邏輯分析儀抓spi的四根線電平,對比好的和不好的,瞬間找到問題。
