下面是主程序文件:
/*八路搶答器-----能夠顯示搶答、回答時(shí)間倒計(jì)時(shí),能夠調(diào)節(jié)搶答、回答時(shí)間,能夠報(bào)警犯規(guī)搶答,可以計(jì)分,可以實(shí)現(xiàn)軟復(fù)位*/
/*桂林電子科技大學(xué)*信息與通信學(xué)院*電子科學(xué)與技術(shù)*/
/*此程序僅供參考!!懇請(qǐng)自重*/
/*本人博客:http://blog.sina.com.cn/13302xiaoqiao */
/*歡迎交流*/
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit fmq=P3^6;
sbit Key_Start=P3^4;//開始鍵,時(shí)間設(shè)置時(shí)+
sbit Key_Stop=P3^5;//停止鍵,時(shí)間設(shè)置時(shí)-
sbit Key_Restart=P3^0;//復(fù)位鍵
sbit Key_set_Q=P3^2;//搶答時(shí)間設(shè)置鍵
sbit Key_set_H=P3^3;//回答時(shí)間設(shè)置鍵
sbit led=P3^7;//搶答LED提示
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff,0xc6,0xf0,0xb6};//段碼表
uchar code table_char[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xc7,0xc0,0x92,0x86,0xbf,0xb7,0xff,0xb9,0x8f};//0-9 L O S E -
uchar table_score[9]={0,50,50,50,50,50,50,50,50};//記分?jǐn)?shù)組,初設(shè)值50分
void delay(uint z);//延時(shí)函數(shù)聲明
void init();//初始化函數(shù)聲明
void display(uchar XuanShou,uchar time);//顯示數(shù)字函數(shù)聲明
void display_char(uchar char_1,uchar char_2,uchar char_3,uchar char_4 );//顯示字符函數(shù)聲明
void display_set(uchar char_1,uchar time,uchar char_2);//時(shí)間設(shè)置閃動(dòng)顯示函數(shù)聲明
void display_score(uchar xs_num);//分?jǐn)?shù)查詢顯示函數(shù)
void beep();//蜂鳴器函數(shù)
void beep_last();//蜂鳴器特殊報(bào)警
void LED();//提示燈函數(shù)
uchar QiangDa_time,HuiDa_time,QiangDa_time_temp=20,HuiDa_time_temp=30;//搶答時(shí)間、回答時(shí)間變量
uchar count_0,count_1;//定時(shí)中計(jì)數(shù)用的
uint shan_count=0;//閃動(dòng)顯示計(jì)數(shù)用
void main()
uchar AnJian,ShuJu,XuanShou_num;
Top:init();//初始化
XuanShou_num=1;//為分?jǐn)?shù)查詢做好準(zhǔn)備
while(1)
display(10,0);//顯示一杠
ShuJu=P1;
if(ShuJu!=0xff)//犯規(guī)搶答!!
// delay(10);
// if(ShuJu!=0xff)
AnJian=ShuJu;
switch(AnJian)//取出選手編號(hào)
case 0xfe : XuanShou_num=1;break;//1111 1110
case 0xfd : XuanShou_num=2;break;//1111 1101
case 0xfb : XuanShou_num=3;break;//1111 1011
case 0xf7 : XuanShou_num=4;break;//1111 0111
case 0xef : XuanShou_num=5;break;//1110 1111
case 0xdf : XuanShou_num=6;break;//1101 1111
case 0xbf : XuanShou_num=7;break;//1011 1111
case 0x7f : XuanShou_num=8;break;//0111 1111
default : goto LOSE;//無(wú)法顯示了,有兩個(gè)以上的鍵同時(shí)按下了!!不過(guò)這種概率相當(dāng)小
while(1)
display_char(13,14,14,XuanShou_num);//閃動(dòng)顯示犯規(guī)選手并且報(bào)警
if(shan_count==50)
beep();
if(Key_Stop==0)
delay(10);
if(Key_Stop==0)
beep();
table_score[XuanShou_num]--;//扣分
while(!Key_Stop)
display_char(14,14,1,16);//按鍵不放開的情況下顯示-1
shan_count=1;//調(diào)用的是閃動(dòng)顯示函數(shù),但是不讓其閃動(dòng)
if(Key_Restart==0)
delay(10);
if(Key_Restart==0)
beep();
goto Top;//熱復(fù)位
if(Key_Start==0)
delay(10);
if(Key_Start==0)//主持人按下?lián)尨疰I,搶答正式開始!
QiangDa_time=QiangDa_time_temp;
HuiDa_time=HuiDa_time_temp;
beep();
TR1=1;//搶答時(shí)間開始倒計(jì)時(shí)
break;//跳出犯規(guī)搶答查詢循環(huán)
//一下為查分程序測(cè)試
if(Key_Stop==0)
delay(10);
if(Key_Stop==0)//進(jìn)入分?jǐn)?shù)查詢顯示
beep();
while(!Key_Stop);
while(1)
display_score(XuanShou_num);
if(Key_Start==0)
delay(10);
if(Key_Start==0)
XuanShou_num++;
if(XuanShou_num==9) XuanShou_num=1;
while(!Key_Start);//等待按鍵釋放
if(Key_Stop==0)
delay(10);
if(Key_Stop==0)
XuanShou_num--;
if(XuanShou_num==0) XuanShou_num=8;
while(!Key_Stop);//等待按鍵釋放
if(Key_Restart==0)
delay(10);
if(Key_Restart==0)
beep();
goto Top;//熱復(fù)位
while(1) //查詢是否有按鍵按下,進(jìn)入搶答循環(huán)
display(10,QiangDa_time);//顯示搶答倒計(jì)時(shí)
if(QiangDa_time==0)
// beep();
TR1=0;//關(guān)閉定時(shí)器1
LOSE: while(1)
display_char(10,11,12,13); //顯示lose 字符
if(Key_Restart==0)
delay(10);
if(Key_Restart==0)//熱復(fù)位鍵,從頭開始下一輪
beep();
goto Top;
ShuJu=P1;//把P1口的數(shù)據(jù)送給變量
if(ShuJu!=0xff)//有按鍵按下
// delay(10);
// if(ShuJu!=0xff)//確定有按鍵按下
AnJian=ShuJu;//傳遞數(shù)據(jù)掃描值
// TR0=1;//啟動(dòng)定時(shí)器0
break;//不再進(jìn)行查詢是否有按鍵按下了
case 0xfe : XuanShou_num=1;beep();LED();break;//1111 1110
case 0xfd : XuanShou_num=2;beep();LED();break;//1111 1101
case 0xfb : XuanShou_num=3;beep();LED();break;//1111 1011
case 0xf7 : XuanShou_num=4;beep();LED();break;//1111 0111
case 0xef : XuanShou_num=5;beep();LED();break;//1110 1111
case 0xdf : XuanShou_num=6;beep();LED();break;//1101 1111
case 0xbf : XuanShou_num=7;beep();LED();break;//1011 1111
case 0x7f : XuanShou_num=8;beep();LED();break;//0111 1111
TR0=1;//啟動(dòng)定時(shí)器0(在這里啟動(dòng)比在前面好)
while(1)
display(XuanShou_num,HuiDa_time);//顯示選手編號(hào)和回答倒計(jì)時(shí)
if(HuiDa_time==0)
TR0=0;//關(guān)閉定時(shí)器0
goto LOSE;//跳到顯示lose字符那里
if(Key_Stop==0)
delay(30);
if(Key_Stop==0)//停止鍵按下
beep();
TR0=0;//關(guān)閉定時(shí)器0,選手開始回答
while(!Key_Stop);
while(1) //在顯示選手回答倒計(jì)時(shí)時(shí)只有在stop按鍵按下時(shí),才可按復(fù)位鍵
if(Key_Start==0)
delay(10);
if(Key_Start==0)
beep();
table_score[XuanShou_num]++;//加分
while(!Key_Start)
display_char(17,18,1,16);//按鍵不放開的情況下顯示+1
if(Key_Stop==0)
delay(10);
if(Key_Stop==0)
beep();
while(!Key_Stop)
if(Key_Restart==0)
delay(10);
beep();
goto Top;
// else
/* if(Key_Restart==0)
delay(10);
beep();
goto Top;
void delay(uint z)//1ms基準(zhǔn)延時(shí)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void init()//初始化函數(shù)
// P1=0xff
EA=1;//開總中斷;
TMOD=0x11;//定時(shí)器工作方式1,16位定時(shí)計(jì)數(shù)器
TH0=(65536-50000)/256;//50us
TL0=(65536-50000)%256;
ET0=1;//開定時(shí)器0中斷(暫時(shí)不啟動(dòng)定時(shí)器)
// TMOD=0x01;//定時(shí)器工作方式1,16位定時(shí)計(jì)數(shù)器
TH1=(65536-50000)/256;//50us
TL1=(65536-50000)%256;
ET1=1;//開定時(shí)器0中斷(暫時(shí)不啟動(dòng)定時(shí)器)
EX0=1;//啟動(dòng)外中斷0
EX1=1;//啟動(dòng)外中斷1
P1=0xff;//讀P1口的數(shù)據(jù)要先置1準(zhǔn)備
count_0=0;//定時(shí)器中的計(jì)數(shù)清零
count_1=0;
shan_count=0;
void display(uchar XuanShou,uchar time)//顯示數(shù)字的函數(shù)
P2=0x7f;//0111 1111最后一位數(shù)碼管亮
P0=table[XuanShou];//選手編號(hào)
delay(1);
P2=0x7f;//0111 1111
P0=0xff;//消余輝
delay(1);
P2=0xdf;//1101 1111
P0=table[time%10];//時(shí)間的個(gè)位
delay(1);
P2=0xdf;//0111 1111
P0=0xff;//消余輝
delay(1);
P2=0xef;// 1110 1111
P0=table[time/10];//時(shí)間的十位
delay(1);
P2=0xef;//0111 1111
P0=0xff;//消余輝
delay(1);
void display_char(uchar char_1,uchar char_2,uchar char_3,uchar char_4 )//閃動(dòng)!顯示字符的函數(shù)
shan_count++;
if(shan_count==150) shan_count=0;
if(shan_count>0&&shan_count<50)
P2=0x7f;//0111 1111
P0=table_char[char_4];
delay(1);
P2=0x7f;//0111 1111
P0=0xff;
delay(1);
P2=0xbf;//1011 1111
P0=table_char[char_3];
delay(1);
P2=0xbf;//1011 1111
P0=0xff;
delay(1);
P2=0xdf;//1101 1111
P0=table_char[char_2];
delay(1);
P2=0xdf;//1101 1111
P0=0xff;
delay(1);
P2=0xef;//1110 1111
P0=table_char[char_1];
delay(1);
P2=0xef;//1110 1111
P0=0xff;
delay(1);
else
P2=0x7f;//0111 1111
P0=0xff;
delay(1);
P2=0xbf;//
P0=0xff;
delay(1);
P2=0xdf;//
P0=0xff;
delay(1);
P2=0xef;//
P0=0xff;
delay(1);
void display_set(uchar char_1,uchar time,uchar char_2)//時(shí)間設(shè)置的閃動(dòng)顯示
shan_count++;
if(shan_count==120) shan_count=0;
if(shan_count>0&&shan_count<40)
P0=table[char_2];//顯示一個(gè)符號(hào)
delay(1);
P2=0x7f;//0111 1111
P0=0xff;//消余輝
delay(1);
P2=0xbf;//1011 1111
delay(1);
P2=0xbf;//1011 1111
P0=0xff;//消余輝
delay(1);
P2=0xdf;//1101 1111
delay(1);
P2=0xdf;//1101 1111
P0=0xff;//消余輝
delay(1);
P0=table[char_1];//顯示一個(gè)符號(hào)
delay(1);
P2=0xef;//1110 1111
P0=0xff;//消余輝
delay(1);
else
P2=0x7f;//0111 1111
P0=table[char_2];
delay(1);
P2=0xbf;//
P0=0xff;
delay(1);
P2=0xdf;//
P0=0xff;
delay(1);
P2=0xef;//
P0=table[char_1];
delay(1);
void display_score(uchar xs_num)//分?jǐn)?shù)查詢顯示函數(shù)
P0=table[(table_score[xs_num]%10)];//分?jǐn)?shù)的個(gè)位
delay(1);
P2=0x7f;//0111 1111
P0=0xff;//消余輝
delay(1);
P2=0xbf;//1011 1111
P0=table[(table_score[xs_num]/10)];//分?jǐn)?shù)的十位
delay(1);
P2=0xbf;//1011 1111
P0=0xff;//消余輝
delay(1);
P2=0xdf;//1101 1111
P0=table_char[15];//間隔符號(hào)
delay(1);
P2=0xdf;//1101 1111
P0=0xff;//消余輝
delay(1);
P0=table[xs_num];//選手編號(hào)
delay(1);
P2=0xef;//1110 1111
P0=0xff;//消余輝
delay(1);
void beep() //有源蜂鳴器函數(shù)
fmq=0;
delay(80);
fmq=1;
void beep_last()//最后一聲特殊聲調(diào)
fmq=0;
delay(300);
fmq=1;
void LED()
led=0;
delay(150);
led=1;
void T0_time() interrupt 1//定時(shí)器0中斷函數(shù)_回答時(shí)間
TH0=(65536-50000)/256;//50ms
TL0=(65536-50000)%256;//馬上重裝初值,以免有誤差
if(count_0==20)
count_0=0;
HuiDa_time--;
if(HuiDa_time<=5)
if(HuiDa_time==0)
beep_last();//最后一聲特殊警告
beep();
count_0++;
void T1_time() interrupt 3//定時(shí)器1中斷函數(shù)_搶答時(shí)間
TL1=(65536-50000)%256;//馬上重裝初值,這樣在后面調(diào)用beep()函數(shù)時(shí)就不會(huì)影響定時(shí)器的準(zhǔn)確計(jì)時(shí)了
if(count_1==20)
count_1=0;
QiangDa_time--;
if(QiangDa_time<=5)
if(QiangDa_time==0)
beep_last();//最后一聲警告
else
beep();
count_1++;
void EX0_set_QiangDa_time() interrupt 0 //外中斷0,設(shè)置搶答時(shí)間
delay(10);//消抖一下
if(Key_set_Q==0)
beep();
while(1)
// display(11,QiangDa_time_temp);
// delay(100);//閃動(dòng)效果
display_set(12,QiangDa_time_temp,13);//調(diào)用時(shí)間設(shè)置閃動(dòng)顯示函數(shù),效果為 [時(shí)間]
if(Key_Start==0)//時(shí)間+1鍵
delay(10);
if(Key_Start==0)
QiangDa_time_temp++;
if(QiangDa_time_temp==100)
QiangDa_time_temp=1;
// else
if(Key_Stop==0)//時(shí)間-1鍵
delay(10);
if(Key_Stop==0)
QiangDa_time_temp--;
if(QiangDa_time_temp==0)
QiangDa_time_temp=99;
// else
if(Key_Restart==0)
if(Key_Restart==0)
beep();
break;
void EX1_set_HuiDa_time() interrupt 2 //外中斷1,設(shè)置回答時(shí)間
delay(10);//消抖一下
if(Key_set_H==0)
beep();
while(1)
display_set(12,HuiDa_time_temp,13);//調(diào)用時(shí)間設(shè)置閃動(dòng)顯示函數(shù),效果為 [時(shí)間]
delay(10);
if(Key_Start==0)
HuiDa_time_temp++;
if(HuiDa_time_temp==100)
HuiDa_time_temp=1;
// else
delay(10);
if(Key_Stop==0)
HuiDa_time_temp--;
if(HuiDa_time_temp==0)
HuiDa_time_temp=99;
// else
if(Key_Restart==0)
if(Key_Restart==0)
beep();
break;
