樓主顯示程序和按鍵程序都有毛病,給你改了試試。
下載附件
2020-6-3 14:38 上傳
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar c,bai,shi,ge;
- uint b;
- uchar const table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0};
- sbit dula=P2^6;
- sbit wela=P2^7;
- uchar keycan(void);
- void delay(uint z);
- void display(uchar bai,uchar shi,uchar ge);
- void main()
- uchar key;
- P0=0x00;
- while(1)
- key=keycan();
- switch(key)
- case 0xee: b=1*1; break;
- case 0xde: b=2*2; break;
- case 0xbe: b=3*3; break;
- case 0x7e: b=4*4; break;
- case 0xed: b=5*5; break;
- case 0xdd: b=6*6; break;
- case 0xbd: b=7*7; break;
- case 0x7d: b=8*8; break;
- case 0xeb: b=9*9; break;
- case 0xdb: b=10*10; break;
- case 0xbb: b=11*11; break;
- case 0x7b: b=12*12; break;
- case 0xe7: b=13*13; break;
- case 0xd7: b=14*14; break;
- case 0xb7: b=15*15; break;
- case 0x77: b=16*16; break;
- bai=b/100%10;
- shi=b/10%10;
- ge =b%10;
- display(bai,shi,ge);
- uchar keycan()
- uchar cord_h,cord_l;
- P3=0x0f;
- cord_h=P3&0x0f;
- if(cord_h!=0x0f)
- c++;
- if(cord_h!=0x0f && c==3)
- c=2;
- cord_h=P3&0x0f;
- if(cord_h!=0x0f)
- P3=cord_h|0xf0;
- cord_l=P3&0xf0;
- return(cord_h+cord_l);
- }return (0xff);
- else c=0;
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- P0=0x00;//段消隱
- dula=1;
- dula=0;
- P0=0xf7;
- wela=1;
- wela=0;
- P0=table[bai];
- dula=1;
- dula=0;
- delay(1);
- P0=0x00;
- dula=1;
- dula=0;
- P0=0xef;
- wela=1;
- wela=0;
- P0=table[shi];
- dula=1;
- dula=0;
- delay(1);
- P0=0x00;
- dula=1;
- dula=0;
- P0=0xdf;
- wela=1;
- wela=0;
- P0=table[ge];
- dula=1;
- dula=0;
- delay(1);
