帶字庫的12864顯示字母中間為什么會空一個再顯示?怎么解決呢?
查看數(shù): 2635 | 評論數(shù): 3 | 收藏 0
發(fā)布時間: 2020-3-18 20:36
如圖,K和M之間會空格,這樣就不夠顯示了啊,導(dǎo)致后面都不能正常顯示了,請問這怎么解決呢?
ID:452950 發(fā)表于 2020-3-19 11:01
unsigned char code AC_TABLE[]={                                           //坐標(biāo)編碼
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,
0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
                      顯示字符串
void PutStr(unsigned char row,unsigned char col,unsigned char *puts)
         LCD_write_cmd(0x30);
         LCD_write_cmd(AC_TABLE[8*row+col]);
        while(*puts != '\0')
                if(col==8)
                        col=0;
                        row++;
                if(row==4) row=0;
                LCD_write_data(*puts);
                puts++;
                if(*puts != '\0')
                        puts++;
                        col++;
ID:452950 發(fā)表于 2020-3-18 23:41
你這個k和m是用的帶字庫12864字符表里面的特殊字符吧,占用兩個字節(jié)。直接輸出字符串,漢字占用兩個字節(jié),字母和數(shù)字只占用一個字節(jié)。
ID:429204 發(fā)表于 2020-3-18 22:48
代碼:
#include <reg52.h>
#include <intrins.h>typedef unsigned char u8;
typedef unsigned int u16;
sbit LCD_RS = P3^6;         //定義LCD12864使用的IO口
sbit LCD_RW = P3^7;
sbit LCD_EN = P3^4;
sbit hall = P1^5;u16 v;                                         //速度
u16 km;                                         //里程
u16 re;                                         //熱量
u16 k;                                 //霍爾電平
u8 cnt1;
u8 cnt2;
u8 time[3];
u8 s = 207;                          //車輪周長
void delayms(u16 ms)                //LCD12864延時函數(shù)
        u16 i;
        for(i = 0; i < ms; i++){; }
void Init_LCD(void)                           //初始化LCD控制端口函數(shù)
    LCD_RS=1;                                  //輸出數(shù)據(jù)LCD_RS和LCD_EN清零
    LCD_RW=0;
    LCD_EN=0;
void LCD_write_cmd(u8 cmd)          //LCD12864寫指令函數(shù)
        LCD_EN=0;
        LCD_RS=0;         //寫指令
        LCD_RW=0;         //寫入
        P2=cmd;//賦值給D0-D7對應(yīng)的IO引腳
        delayms(50);
        LCD_EN=1;          //允許
        delayms(50);
        LCD_EN=0;
void LCD_write_data(u8 dat)                        //LCD12864寫數(shù)據(jù)函數(shù)
        LCD_EN=0;
        LCD_RS=1;          //寫數(shù)據(jù)
        LCD_RW=0;          //寫入
        P2=dat;//賦值給D0-D7對應(yīng)的IO引腳
        delayms(50);
        LCD_EN=1;           //允許
        delayms(50);
        LCD_EN=0;
void LCD_init(void)                                //初始化LCD12864顯示設(shè)置函數(shù)
        delayms(10000);
        delayms(20);
        LCD_write_cmd(0x30);//功能設(shè)置
        delayms(20);
        LCD_write_cmd(0x0c);//顯示開關(guān)控制
        delayms(20);
        LCD_write_cmd(0x01);//顯示清除
        delayms(1200);
        LCD_write_cmd(0x06);//顯示清除
        delayms(50);
void LCD_Display()                                  //LCD顯示函數(shù)
     Init_LCD();                              //初始化LCD控制端口
     LCD_init();                          //初始化LCD顯示設(shè)置
     LCD_write_cmd(0x80);        //第一行數(shù)據(jù)指針地址
//-------------第一行顯示內(nèi)容-------------//
     LCD_write_data(0xCB); //速
     LCD_write_data(0xD9);
     LCD_write_data(0xB6); //度
     LCD_write_data(0xC8);
     LCD_write_data(0xA1); //:
     LCD_write_data(0xC3);
     LCD_write_data(v/10%10+'0'); //速度十位
     LCD_write_data(v%10+'0'); //速度個位
     LCD_write_data(0xA3);      //.
     LCD_write_data(0xAE);
     LCD_write_data(v*10%10+'0'); //速度十分位
     LCD_write_data(0xA3); //k
     LCD_write_data(0xEB);
         LCD_write_data(0xA3); //m
     LCD_write_data(0xED);
         LCD_write_data(0xA3); ///
     LCD_write_data(0xAF);
         LCD_write_data(0xA3); //h
     LCD_write_data(0xA8);
         delayms(10);
void main()                        //主函數(shù)
        TMOD = 0x01;                                                //設(shè)置定時器1工作方式2,定時器工作方式3
        TH0 = (65536-922)/256;                                //高8位設(shè)初值1ms
        TL0 = (65536-922)%256;                                //低8位設(shè)初值1ms
        EA = 1;                                                            //開總中斷
        ET0 = 1;                                                    //開T1定時器0中斷
        TR0 = 1;                                                       //開定時器0
    while(1)
                v = (s/cnt1*10)*3600;                    //計算速度,單位km/h
                LCD_Display();                //LCD12864進行顯示
void EX0_INT(void) interrupt 1                    //計數(shù)中斷
        TL0 = (65536-922)%256;                                //重裝初值1ms
        cnt2++;
        if(hall == 0)
                cnt1++;                                                        //記錄1ms的次數(shù)
        else
                cnt1 = 0;                                                //清空計數(shù)次數(shù)
