發布時間: 2018-11-13 07:58
正文摘要:我在嘗試移植教材上的程序時,發現在頁讀取EEPROM時,第9位應答位假如直接置1或置0,就可以順利讀取,但由形參傳遞1或0給應答位時,就只能讀到一串0,這是什么原因? |
| 實例49 讀寫AT24C02 |
ahshmj 發表于 2018-11-13 15:53 大佬求幫忙看看 |
----------------------------------------------------------------主函數 #include <reg52.h> #define u8 unsigned char #define u16 unsigned int extern void Int_Lcd(); extern void Lcd_Show(u8 x,u8 y,u8 *set); extern void EE_Read(u8 *buf,u8 addr,u8 len); extern void EE_Write(u8 *buf,u8 addr,u8 len); void Str_Convert(u8 *str,u8 *src,u8 len); void main() { u8 buf[5]={5,2,8,6,1}; u8 str[20]; Int_Lcd(); // EE_Write(buf,0x00,sizeof(buf)); //EEPROM寫入 EE_Read(buf,0x00,sizeof(buf)); //EEPROM讀取 Str_Convert(str,buf,sizeof(buf)); //字符串轉化函數 Lcd_Show(0,0,str); //1cd1602顯示 while(1); } void Str_Convert(u8 *str,u8 *src,u8 len) { u8 tem; while(len--) { tem=*src>>4; if(tem<=9) *str++=tem+'0'; else *str++=tem-10+'a'; tem=*src&0x0f; if(tem<=9) *str++=tem+'0'; else *str++=tem-10+'a'; *str++=' '; src++; } } ----------------------------------------------------------------LCD1602 #include <reg52.h> #define u8 unsigned char #define u16 unsigned int #define LCD_DB P0 sbit LCD_RS=P2^6; sbit LCD_RW=P2^5; sbit LCD_E=P2^7; void LCD_Wait_Ready() { u8 sta; LCD_DB=0xff; LCD_RS=0; LCD_RW=1; do { LCD_E=1; sta=LCD_DB; LCD_E=0; } while(sta & 0x80); } void LCD_Write_Cmd(u8 cmd) { LCD_Wait_Ready(); LCD_RS=0; LCD_RW=0; LCD_DB=cmd; LCD_E=1; LCD_E=0; } void LCD_Write_Dat(u8 dat) { LCD_Wait_Ready(); LCD_RS=1; LCD_RW=0; LCD_DB=dat; LCD_E=1; LCD_E=0; } void Lcd_Set_Cursor(u8 x,u8 y) { u8 addr; if(y==0) addr=0x00+x; else addr=0x40+x; LCD_Write_Cmd(addr | 0x80); } void Lcd_Show(u8 x,u8 y,u8 *str) { Lcd_Set_Cursor(x,y); while(*str!='\0') { LCD_Write_Dat(*str++); } } void Int_Lcd() { LCD_Write_Cmd(0x38); LCD_Write_Cmd(0x0c); LCD_Write_Cmd(0x06); LCD_Write_Cmd(0x01); } ----------------------------------------------------------------I2C #include <reg52.h> #include <intrins.h> #define u8 unsigned char #define u16 unsigned int sbit SCL=P2^1; sbit SDA=P2^0; sbit LED1=P0^0; sbit LED2=P0^1; void Dealy() { u8 i; for(i=0;i<10;i++) _nop_(); } void I2C_Start() { SDA=1; SCL=1; Dealy(); SDA=0; Dealy(); SCL=0; Dealy(); } void I2C_Stop() { SCL=0; SDA=0; Dealy(); SCL=1; Dealy(); SDA=1; Dealy(); } bit I2C_Write(u8 dat) //I2C寫入 { bit ack; u8 mask; for(mask=0x80;mask>0;mask>>=1) { if((mask & dat)==0) SDA=0; else SDA=1; Dealy(); SCL=1; Dealy(); SCL=0; Dealy(); } SDA=1; Dealy(); SCL=1; ack=SDA; Dealy(); SCL=0; Dealy(); return (~ack); } u8 I2C_Read(bit ack) //I2C讀取 { u8 dat,i; SDA=1; Dealy(); //延時10us for(i=0;i<8;i++) { SCL=1; Dealy(); dat<<=1; dat |= SDA; Dealy(); SCL=0; Dealy(); } SDA=ack; //SDA由形參ack控制 Dealy(); SCL=1; Dealy(); SCL=0; Dealy(); return dat; } u8 I2C_ReadACK() { u8 dat,i; SDA=1; Dealy(); //延時10us for(i=0;i<8;i++) { SCL=1; Dealy(); dat<<=1; dat |= SDA; Dealy(); SCL=0; Dealy(); } SDA=0; //SDA直接置0 Dealy(); SCL=1; Dealy(); SCL=0; Dealy(); return dat; } u8 I2C_ReadNAK() { u8 dat,i; SDA=1; Dealy(); for(i=0;i<8;i++) { SCL=1; Dealy(); dat<<=1; dat |= SDA; Dealy(); SCL=0; Dealy(); } SDA=1; //SDA直接置1 Dealy(); SCL=1; Dealy(); SCL=0; Dealy(); return dat; } ----------------------------------------------------------------EEPROM #include <reg52.h> #define u8 unsigned char #define u16 unsigned int extern void I2C_Start(); extern void I2C_Stop(); extern bit I2C_Write(u8 dat); extern bit I2C_Read(bit ack); extern u8 I2C_ReadACK(); extern u8 I2C_ReadNAK(); void EE_Read(u8 *buf,u8 addr,u8 len) //EEPROM讀取,len讀取長度 { do { I2C_Start(); if(I2C_Write(0x50<<1)) break; I2C_Stop(); } while(1); I2C_Write(addr); //寫入讀取的起始地址 I2C_Start(); I2C_Write((0x50<<1)|0x01); while(len>1) { *buf++=I2C_Read(0); //應答位置0 // *buf++=I2C_ReadACK(); len--; } *buf=I2C_Read(1); //應答位置1 // *buf=I2C_ReadNAK(); I2C_Stop(); } void EE_Write(u8 *buf,u8 addr,u8 len) //EEPROM寫入 { while(len>0) { do { I2C_Start(); if(I2C_Write(0x50<<1)) break; I2C_Stop(); } while(1); I2C_Write(addr); while(len>0) { I2C_Write(*buf++); len--; addr++; if((addr&0x07)==0) break; } I2C_Stop(); } } |
ahshmj 發表于 2018-11-13 15:53 額,好吧,我把程序列出來 |
| 怎么用圖形貼出來,而不用文本格式呢?別人想試一試程序還要照圖抄一遍? |
浮念 發表于 2018-11-13 11:02 程序上我沒有太大的問題,這部分程序我也是移植后再自己重新編寫了的,主要就是想不明白為啥直接置位可以,用形參置位就出問題了,形參置位和直接置位有啥區別嗎? |
| 你可以在論壇里面搜集一下,有很多現成的程序可以參考學習。要善用論壇的搜索功能。 |
