這是改過的程序
- #include <REG52.h>
- #include<intrins.h>
- sbit K1=P1^2;
- sbit ALAM = P2^5; //報(bào)警
- sbit open_led=P2^3; //開鎖指示燈
- /*LCD接口定義*/
- sbit LcdRS = P2^0; //lcd數(shù)據(jù)/命令選擇端 數(shù)據(jù)1命令0
- sbit LcdRW = P2^1; //lcd讀/寫選擇端 讀1寫0
- sbit LcdEn = P2^2; //lcd使能控制端 1有效
- sfr LcdIO = 0x80; //lcd數(shù)據(jù)接口 P0=0x80
- unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盤掃描控制表
- unsigned char countt0,second; //t0中斷計(jì)數(shù)器,秒計(jì)數(shù)器
- unsigned char code start_line[] = {"password: "};
- unsigned char code name[] = {"===Coded Lock==="}; //顯示名稱
- unsigned char code Error[] = {" error "}; //輸入錯(cuò)誤
- unsigned char code codepass[] = {" pass "};
- unsigned char code LockOpen[] = {" open "}; //OPEN
- char InputData[6]; //輸入密碼暫存區(qū)
- unsigned char CurrentPassword[6]={6,5,4,3,2,1}; //當(dāng)前密碼值
- unsigned char N=0; //密碼輸入位數(shù)記數(shù)
- unsigned char ErrorCont; //錯(cuò)誤次數(shù)計(jì)數(shù)
- unsigned char KEY_SCAN,NUM;
- /****向LCD寫入命令或數(shù)據(jù)部分****/
- #define LCD_COMMAND 0 // 輸出指令
- #define LCD_DATA 1 // 輸出數(shù)據(jù)
- #define LCD_CLEAR_SCREEN 0x01 // 清屏指令
- #define LCD_HOME 0x02 // 光標(biāo)返回原點(diǎn)指令
- //=====================16us短延時(shí)==============================
- void Delay_short(unsigned int n)
- unsigned int i;
- for(i=0;i<n;i++)
- //=====================長延時(shí)==============================
- void Delay_long(unsigned char N)
- unsigned char i;
- unsigned int j;
- for(i=0;i<N;i++)
- for(j=0;j<315;j++) //一個(gè)循環(huán)16us,共5ms
- //=====================5ms延時(shí)==============================
- void Delay5Ms(void)
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //===================400ms延時(shí)==============================
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- /*寫LCD子程序 */
- /*入口參數(shù):數(shù)據(jù)style=1 指令, style=0 input:寫入的內(nèi)容*/
- void LCD_Write(bit style, unsigned char input)
- LcdRS=style; //數(shù)據(jù)style=1 指令style=0
- LcdRW=0; //寫
- LcdIO=input; //P0口輸出
- Delay_short(10); //延時(shí)
- LcdEn=1; //lcd使能
- LcdEn=0; //停止
- /****初始化LCD程序****/
- void LCD_Initial()
- Delay_long(6); //延遲5*6=30ms
- LCD_Write(LCD_COMMAND,0x38); //8位數(shù)據(jù)端口,2行顯示,5*7點(diǎn)陣
- LCD_Write(LCD_COMMAND,0x38); //發(fā)送三遍
- Delay_short(2); //延遲大于39us
- LCD_Write(LCD_COMMAND,0x0c); //顯示模式設(shè)置:開啟顯示, 無光標(biāo) 0x0c
- LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏 0x01
- Delay_short(100); //延遲大于1.53ms
- LCD_Write(LCD_COMMAND,0x06); //輸入模式設(shè)置:AC遞增, 畫面不動(dòng) 0x06
- /*液晶字符輸入的位置定位程序*/
- /*入口參數(shù):x范圍:0-15 y范圍:1,2*/
- void GotoXY(unsigned char x, unsigned char y)
- unsigned char address;
- if(y==1)
- address=0x80+x; //y=1顯示在第一行
- else
- address=0xc0+x; //y=2顯示在第二行
- LCD_Write(LCD_COMMAND, address);
- /*將字符串輸出到液晶顯示函數(shù)*/
- /*入口參數(shù):字符串指針 */
- void Print(unsigned char *str)
- while(*str!='\0')
- LCD_Write(LCD_DATA,*str);
- str++;
- //==============將按鍵值編碼為數(shù)值=========================
- unsigned char coding(unsigned char m)
- unsigned char k;
- switch(m)
- // case (0x18): k=3;break;
- // case (0x28): k=7;break;
- // case (0x48): k='#';break;
- // case (0x88): k='D';break;
- case (0x14): k=3;break;
- case (0x24): k=6;break;
- case (0x44): k=9;break;
- case (0x84): k='#';break;
- case (0x12): k=2;break;
- case (0x22): k=5;break;
- case (0x42): k=8;break;
- case (0x82): k=0;break;
- case (0x11): k=1;break;
- case (0x21): k=4;break;
- case (0x41): k=7;break;
- case (0x81): k='*';break;
- return(k);
- //=====================按鍵檢測并返回按鍵值===============================
- unsigned char keynum(void)
- unsigned char row,col,i;
- P3=0xf0;
- if((P3&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P3^0xf0; //確定行線
- i=0;
- P3=a[i]; //精確定位
- while(i<4)
- col=~(P3&0xff); //確定列線
- break; //已定位后提前退出
- else
- i++;
- P3=a[i];
- else
- return 0xff;
- while((P3&0xf0)!=0xf0);
- return (row|col); //行線與列線組合后返回
- else
- return 0xff; //無鍵按下時(shí)返回0xff
- //=======================一聲提示音,表示有效輸入========================
- void OneAlam(void)
- unsigned char y;
- for(y=0;y<30;y++)
- ALAM=0;
- Delay_short(50);
- ALAM=1;
- Delay_short(50);
- //========================二聲提示音,表示操作成功========================
- void TwoAlam(void)
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- OneAlam();
- Delay5Ms();
- ALAM=1;
- //========================三聲提示音,表示錯(cuò)誤========================
- void ThreeAlam(void)
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- OneAlam();
- Delay5Ms();
- ALAM=1;
- //=======================輸入密碼錯(cuò)誤超過三過,報(bào)警并鎖死鍵盤======================
- void Alam_KeyUnable(void)
- P3=0x00;
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- //=======================取消所有操作============================================
- void Cancel(void)
- unsigned char i;
- GotoXY(0,2);
- Print(start_line);
- TwoAlam(); //提示音
- for(i=0;i<6;i++)
- InputData[i]=0;
- ALAM=1; //報(bào)警關(guān)
- ErrorCont=0; //密碼錯(cuò)誤輸入次數(shù)清零
- open_led=1; //指示燈關(guān)閉
- N=0; //輸入位數(shù)計(jì)數(shù)器清零
- //==========================確認(rèn)鍵,并通過相應(yīng)標(biāo)志位執(zhí)行相應(yīng)功能===============================
- void Ensure(void)
- unsigned char i,j;
- for(i=0;i<6;)
- if(CurrentPassword[i]==InputData[i])
- i++;
- else
- ErrorCont++;
- if(ErrorCont==3) //錯(cuò)誤輸入計(jì)數(shù)達(dá)三次時(shí),報(bào)警并鎖定鍵盤
- GotoXY(0,2);
- Print(" KeypadLocked! ");
- TR0=1;
- do
- Alam_KeyUnable();
- while(TR0);
- return ;
- break;
- if(i==6) //密碼正確輸入
- GotoXY(0,2);
- Print(codepass);
- Delay400Ms();
- Delay400Ms();
- GotoXY(0,2);
- Print(LockOpen);
- TwoAlam(); //操作成功提示音
- //KEY_CLOCK=0; //開鎖
- //pass=1; //置正確標(biāo)志位
- open_led=0; //開鎖指示燈亮
- for(j=0;j<6;j++) //將輸入清除
- InputData[i]=0;
- while(1);
- else
- GotoXY(0,2);
- Print(Error);
- ThreeAlam(); //錯(cuò)誤提示音
- Delay400Ms();
- GotoXY(0,2);
- InputData[i]=0;
- N=0; //將輸入數(shù)據(jù)計(jì)數(shù)器清零,為下一次輸入作準(zhǔn)備
- void test_led()
- while(1)
- open_led=0;
- Delay400Ms();
- open_led=1;
- Delay400Ms();
- void test_alarm()
- while(1)
- ALAM=1;
- Delay_short(60);
- ALAM=0;
- Delay_short(60);
- void timer_init()
- TMOD=0x11;
- TL0=0xB0;
- TH0=0x3C;
- EA=1;
- ET0=1;
- TR0=0;
- void test_key()
- unsigned char code ascii[]={"0123456789ABCDEF"};
- KEY_SCAN=keynum();
- if(KEY_SCAN!=0xff)
- GotoXY(0,1);
- Print("key_code:0x");
- LCD_Write(LCD_DATA, ascii[KEY_SCAN/16]);
- LCD_Write(LCD_DATA, ascii[KEY_SCAN%16]);
- void keyscan() //按鍵掃描程序
- static bit key_sign=0; //按鍵自鎖標(biāo)志
- static bit sign=0;
- static unsigned char count=0;//計(jì)數(shù)變量
- unsigned char i;
- if(K1==0) //檢測按鍵如果為0
- count++; //消抖計(jì)數(shù)
- if((count>=250)&&(key_sign==0))
- key_sign=1; //按鍵自鎖標(biāo)志置1
- sign=~sign;
- if(sign==1)
- for(i=0;i<N;i++)
- GotoXY(9+i,2);
- LCD_Write(LCD_DATA,InputData[i]+0x30);
- else
- for(i=0;i<N;i++)
- GotoXY(9+i,2);
- LCD_Write(LCD_DATA,'*');
- else //按鍵抬起
- key_sign=0; //按鍵自鎖標(biāo)志清0
- count=0; //消抖計(jì)數(shù)清0
- //==============================主函數(shù)===============================
- void main(void)
- unsigned char j;
- // test_led();
- // test_alarm();
- Delay400Ms(); //啟動(dòng)等待,等LCM講入工作狀態(tài)
- LCD_Initial(); //LCD初始化
- // while(1)
- // test_key();
- GotoXY(0,1);//日歷顯示固定符號從第一行第0個(gè)位置之后開始顯示
- Print(name);//向液晶屏寫日歷顯示的固定符號部分
- GotoXY(0,2);//時(shí)間顯示固定符號寫入位置,從第2個(gè)位置后開始顯示
- Print(start_line);//寫顯示時(shí)間固定符號,兩個(gè)冒號
- GotoXY(9,2); //設(shè)置光標(biāo)位置
- LCD_Write(LCD_COMMAND,0x0f); //設(shè)置光標(biāo)為閃爍
- // while(1);
- P3=0xFF;
- timer_init();
- Delay5Ms(); //延時(shí)片刻(可不要)
- N=0; //初始化數(shù)據(jù)輸入位數(shù)
- while(1)
- if (!TR0)
- else
- KEY_SCAN = 0xff;
- NUM=coding(KEY_SCAN);
- switch(NUM)
- case 'A': ; break;
- case 'B': ; break;
- case 'C': ; break;
- case 'D': ; break;
- case '*': Cancel(); break; //取消當(dāng)前輸入
- case '#': Ensure(); break; //確認(rèn)鍵,
- default:
- if(N<6) //當(dāng)輸入的密碼少于6位時(shí),接受輸入并保存,大于6位時(shí)則無效。
- // unsigned char temp;
- OneAlam(); //按鍵提示音
- for(j=N;j<=N;j++)
- GotoXY(9+j,2);
- /* if(K1==0)
- GotoXY(9+N,2);
- temp=NUM+0x30 ;
- LCD_Write(LCD_DATA,temp);
- InputData[N]=NUM;
- N++;
- else //輸入數(shù)據(jù)位數(shù)大于6后,忽略輸入
- N=6;
- break;
- keyscan();
- //*********************************中斷服務(wù)函數(shù)**************************************
- void time0_int(void) interrupt 1
- TL0=0xB0;
- TH0=0x3C;
- countt0++;
- if(countt0==20)
- countt0=0;
- second++;
- if(second==10)
- P3=0xf0;
- TL0=0xB0;
- TH0=0x3C;
- second=0;
- GotoXY(0,2);
- TR0=0; //關(guān)定時(shí)器
復(fù)制代碼
