單片機開機密碼鎖程序
J木昜
2017-11-29 15:04
單片機開機密碼鎖程序
基于開發板設計的開機密碼鎖,功能如下:上電顯示----,密碼輸入正確,停留0.5秒然后顯示按鍵值,10秒沒有操作或者密碼輸入錯誤都返回----,適合想把數碼管和按鍵結合起來的學習,還有不同的窗口。
#include<reg52.h>
#define const_key_time 20
#define const_no_key_push 4400
#define const_05s 220
void SystemInitial();
void PeripheralInitial();
void delay_short(unsigned char ucDelayShort);
void delay_long(unsigned char ucDelayLong);
void hc595_drive(unsigned char ucStatusTemp16_09,unsigned char ucStatusTemp08_01);
void key_scan();
void key_service();
void display_drive();
void display_service();
void num_key_input(unsigned char ucWhichKey);
sbit key_dr1=P0^0;
sbit key_dr2=P0^1;
sbit key_dr3=P0^2;
sbit key_dr4=P0^3;
sbit key_sr1=P0^4;
sbit key_sr2=P0^5;
sbit key_sr3=P0^6;
sbit key_sr4=P0^7;
sbit srclk_dr=P3^6;
sbit rclk_dr=P3^5;
sbit ser_dr=P3^4;
unsigned char ucRowRecord=1;
unsigned char ucKeyStep=1;
unsigned char ucKeySec=0;
unsigned char ucKeyLock=0;
unsigned int uiKeyTimeCnt=0;
unsigned char ucTemp=0;
unsigned char ucDisplayDriveStep=1;
unsigned char ucDig1;
unsigned char ucDig2;
unsigned char ucDig3;
unsigned char ucDig4;
unsigned char ucWd=1;
unsigned char ucWd1Update=1;
unsigned char ucWd2Update=0;
unsigned char ucWd3Update=0;
unsigned char ucPasswordInput[4];
unsigned char ucPasswordCnt=0;
unsigned char ucKeyNum=1;
unsigned int uiNoKeyPushTimer=const_no_key_push;
unsigned int uiPasswordTimer=const_05s;
unsigned char ucTemp1=0;
unsigned char ucTemp2=0;
unsigned char ucTemp3=0;
unsigned char ucTemp4=0;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40,0x73};
SystemInitial();
delay_long(100);
key_service();
display_service();
switch(ucWd)
case 1: if(ucWd1Update==1)
ucWd1Update=0;
ucDig4=ucPasswordInput[0];
ucDig3=ucPasswordInput[1];
ucDig2=ucPasswordInput[2];
ucDig1=ucPasswordInput[3];
break;
case 2: if(ucWd2Update==1)
ucWd2Update=0;
ucDig4=10;
ucDig3=10;
ucDig2=10;
ucDig1=ucKeyNum;
break;
case 3: if(ucWd3Update==1)
ucWd3Update=0;
break;
void key_scan()
switch(ucKeyStep)
case 1: if(ucRowRecord==1)
key_dr1=0;
key_dr2=1;
key_dr3=1;
key_dr4=1;
else if(ucRowRecord==2)
key_dr1=1;
key_dr2=0;
key_dr3=1;
key_dr4=1;
else if(ucRowRecord==3)
key_dr1=1;
key_dr2=1;
key_dr3=0;
key_dr4=1;
key_dr1=1;
key_dr2=1;
key_dr3=1;
key_dr4=0;
uiKeyTimeCnt=0;
ucKeyStep++;
break;
case 2: uiKeyTimeCnt++;
if(uiKeyTimeCnt>1)
uiKeyTimeCnt=0;
ucKeyStep++;
break;
case 3: if(key_sr1==1&&key_sr2==1&&key_sr3==1&&key_sr4==1)
ucKeyStep=1;
ucKeyLock=0;
uiKeyTimeCnt=0;
ucRowRecord++;
if(ucRowRecord>4)
ucRowRecord=1;
else if(ucKeyLock==0)
if(key_sr1==0&&key_sr2==1&&key_sr3==1&&key_sr4==1)
uiKeyTimeCnt++;
if(uiKeyTimeCnt>const_key_time)
uiKeyTimeCnt=0;
ucKeyLock=1;
if(ucRowRecord==1)
ucKeySec=1;
ucKeySec=2;
ucKeySec=3;
ucKeySec=4;
if(key_sr1==1&&key_sr2==0&&key_sr3==1&&key_sr4==1)
uiKeyTimeCnt++;
uiKeyTimeCnt=0;
ucKeyLock=1;
if(ucRowRecord==1)
ucKeySec=5;
ucKeySec=6;
ucKeySec=7;
ucKeySec=8;
if(key_sr1==1&&key_sr2==1&&key_sr3==0&&key_sr4==1)
uiKeyTimeCnt++;
uiKeyTimeCnt=0;
ucKeyLock=1;
if(ucRowRecord==1)
ucKeySec=9;
ucKeySec=10;
ucKeySec=11;
ucKeySec=12;
if(key_sr1==1&&key_sr2==1&&key_sr3==1&&key_sr4==0)
uiKeyTimeCnt++;
uiKeyTimeCnt=0;
ucKeyLock=1;
if(ucRowRecord==1)
ucKeySec=13;
ucKeySec=14;
ucKeySec=15;
ucKeySec=16;
break;
void key_service()
switch(ucKeySec)
case 1: num_key_input(1);
ucKeySec=0;
break;
case 2: num_key_input(2);
ucKeySec=0;
break;
case 3: num_key_input(3);
ucKeySec=0;
break;
case 4: num_key_input(4);
ucKeySec=0;
break;
case 5: num_key_input(5);
ucKeySec=0;
break;
case 6: num_key_input(6);
ucKeySec=0;
break;
case 7: num_key_input(7);
ucKeySec=0;
break;
case 8: num_key_input(8);
ucKeySec=0;
break;
case 9: num_key_input(9);
ucKeySec=0;
break;
case 10: num_key_input(0);
ucKeySec=0;
break;
case 11: ucKeySec=0;
break;
case 12: ucKeySec=0;
break;
case 13: ucKeySec=0;
break;
case 14: ucKeySec=0;
break;
case 15: ucKeySec=0;
break;
case 16: ucKeySec=0;
break;
switch(ucWd)
case 1: ucPasswordInput[ucPasswordCnt]=ucWhichKey;
ucPasswordCnt++;
if(ucPasswordCnt>=4)
ucPasswordCnt=0;
ucWd=3;
ucWd3Update=1;
ucWd1Update=1;
break;
case 2: ucKeyNum=ucWhichKey;
ucWd2Update=1;
break;
switch(ucDisplayDriveStep)
case 1: ucTemp=table[ucDig1];
hc595_drive(ucTemp,0xfe);
break;
case 2: ucTemp=table[ucDig2];
hc595_drive(ucTemp,0xfd);
break;
case 3: ucTemp=table[ucDig3];
hc595_drive(ucTemp,0xfb);
break;
case 4: ucTemp=table[ucDig4];
hc595_drive(ucTemp,0xf7);
break;
ucDisplayDriveStep++;
if(ucDisplayDriveStep>4)
unsigned char ucTempData=0;
unsigned char i;
srclk_dr=0;
rclk_dr=0;
ucTempData=ucStatusTemp16_09;
for(i=0;i<8;i++)
if(ucTempData>=0x80)
ser_dr=1;
else ser_dr=0;
srclk_dr=0;
delay_short(1);
srclk_dr=1;
ucTempData=ucTempData<<1;
ucTempData=ucStatusTemp08_01;
for(i=0;i<8;i++)
ser_dr=1;
else ser_dr=0;
srclk_dr=0;
delay_short(1);
srclk_dr=1;
delay_short(1);
rclk_dr=0;
delay_short(1);
rclk_dr=1;
delay_short(1);
void T0_time() interrupt 1
unsigned int i;
if(ucWd==3)
if(uiPasswordTimer>0)
uiPasswordTimer--;
if(uiPasswordTimer==0)
if(ucPasswordInput[0]==1&&ucPasswordInput[1]==3&&ucPasswordInput[2]==1&&ucPasswordInput[3]==4)
ucWd=2;
ucWd2Update=1;
for(i=0;i<4;i++)
ucPasswordInput[i]=11;
ucWd=1;
ucWd1Update=1;
if(ucWd==2)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
24.開機密碼鎖.rar
(39.22 KB, 下載次數: 20)
2017-11-29 15:04 上傳
6278779JJJ
2018-7-7 13:09
樓主 ,你確定你的代碼沒有問題?怎么我自己燒到板子里去之后并沒有你說的功能呢?矩陣按鍵也不顯示,LCD也不顯示輸入的數據???
