溫控風扇的單片機源碼
ttiaNJIAN
2017-11-25 16:41
溫控風扇的單片機源碼
#include <reg52.h> //調用單片機頭文件
#define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
#define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
#include "eeprom52.h"
//數碼管段選定義 0 1 2 3 4 5 6 7 8 9
uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //斷碼
//數碼管位選定義
uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};
uchar dis_smg[8] = {0x28,0xee,0x32,0xa2,0xe4,0x92,0x82,0xf8};
uchar smg_i = 3; //顯示數碼管的個位數
sbit dq = P2^4; //18b20 IO口的定義
bit flag_lj_en; //按鍵連加使能
bit flag_lj_3_en; //按鍵連3次連加后使能 加的數就越大了
uchar key_time,key_value; //用做連加的中間變量
bit key_500ms ;
sbit pwm = P2^3;
uchar f_pwm_l ; //越小越暗
uint temperature ; //
bit flag_300ms ;
uchar menu_1; //菜單設計的變量
uint t_high = 300,t_low = 100; //溫度上下限報警值
uint number;
/***********************1ms延時函數*****************************/
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<120;j++);
/***********************小延時函數*****************************/
void delay_uint(uint q)
while(q--);
/***********************數碼顯示函數*****************************/
void display()
static uchar i;
i++;
if(i >= smg_i)
i = 0;
P1 = 0xff; //消隱
P3 = smg_we[i]; //位選
P1 = dis_smg[i]; //段選
/******************把數據保存到單片機內部eepom中******************/
void write_eeprom()
SectorErase(0x2000);
byte_write(0x2000, t_high % 256);
byte_write(0x2001, t_high / 256);
byte_write(0x2002, t_low % 256);
byte_write(0x2003, t_low / 256);
byte_write(0x2055, a_a);
/******************把數據從單片機內部eepom中讀出來*****************/
void read_eeprom()
t_high = byte_read(0x2001);
t_high <<= 8;
t_high |= byte_read(0x2000);
t_low = byte_read(0x2003);
t_low <<= 8;
t_low |= byte_read(0x2002);
a_a = byte_read(0x2055);
/**************開機初始化保存的數據*****************/
void init_eeprom()
read_eeprom(); //先讀
if(a_a != 22) //新的單片機初始單片機內問eeprom
t_high = 250;
t_low = 200;
a_a = 22;
write_eeprom(); //保存數據
/***********************18b20初始化函數*****************************/
void init_18b20()
bit q;
dq = 1; //把總線拿高
delay_uint(1); //15us
dq = 0; //給復位脈沖
delay_uint(80); //750us
dq = 1; //把總線拿高 等待
delay_uint(10); //110us
q = dq; //讀取18b20初始化信號
delay_uint(20); //200us
dq = 1; //把總線拿高 釋放總線
/*************寫18b20內的數據***************/
void write_18b20(uchar dat)
uchar i;
for(i=0;i<8;i++)
{ //寫數據是低位開始
dq = 0; //把總線拿低寫時間隙開始
dq = dat & 0x01; //向18b20總線寫數據了
delay_uint(5); // 60us
dq = 1; //釋放總線
dat >>= 1;
/*************讀取18b20內的數據***************/
uchar read_18b20()
uchar i,value;
for(i=0;i<8;i++)
dq = 0; //把總線拿低讀時間隙開始
value >>= 1; //讀數據是低位開始
dq = 1; //釋放總線
if(dq == 1) //開始讀寫數據
value |= 0x80;
delay_uint(5); //60us 讀一個時間隙最少要保持60us的時間
return value; //返回數據
/*************讀取溫度的值 讀出來的是小數***************/
uint read_temp()
uint value;
uchar low; //在讀取溫度的時候如果中斷的太頻繁了,就應該把中斷給關了,否則會影響到18b20的時序
init_18b20(); //初始化18b20
EA = 0;
write_18b20(0xcc); //跳過64位ROM
write_18b20(0x44); //啟動一次溫度轉換命令
EA = 1;
delay_uint(50); //500us
EA = 0;
write_18b20(0xbe); //發出讀取暫存器命令
low = read_18b20(); //讀溫度低字節
value = read_18b20(); //讀溫度高字節
EA = 1;
value <<= 8; //把溫度的高位左移8位
value |= low; //把讀出的溫度低位放到value的低八位中
value *= 0.625; //轉換到溫度值 小數
return value; //返回讀出的溫度 帶小數
/*************定時器0初始化程序***************/
void time_init()
EA = 1; //開總中斷
TMOD = 0X11; //定時器0、定時器1工作方式1
ET0 = 1; //開定時器0中斷
TR0 = 1; //允許定時器0定時
ET1 = 1; //開定時器0中斷
TR1 = 0; //允許定時器0定時
/********************獨立按鍵程序*****************/
uchar key_can; //按鍵值
void key() //獨立按鍵程序
static uchar key_new;
key_can = 20; //按鍵值還原
P2 |= 0x07;
if((P2 & 0x07) != 0x07) //按鍵按下
if(key_500ms == 1) //連加
key_500ms = 0;
key_new = 1;
delay_1ms(1); //按鍵消抖動
if(((P2 & 0x07) != 0x07) && (key_new == 1))
{ //確認是按鍵按下
key_new = 0;
switch(P2 & 0x07)
case 0x06: key_can = 3; break; //得到k2鍵值
case 0x05: key_can = 2; break; //得到k3鍵值
case 0x03: key_can = 1; break; //得到k4鍵值
flag_lj_en = 1; //連加使能
if(key_new == 0)
key_new = 1;
flag_lj_en = 0; //關閉連加使能
flag_lj_3_en = 0; //關閉3秒后使能
key_value = 0; //清零
key_time = 0;
key_500ms = 0;
/****************按鍵處理數碼管顯示函數***************/
void key_with()
if(key_can == 1) //設置鍵
f_pwm_l = 30;
menu_1 ++;
if(menu_1 >= 3)
menu_1 = 0;
smg_i = 3; //數碼管顯示3位
if(menu_1 == 1) //設置高溫報警
smg_i = 4; //數碼管顯示4位
if(key_can == 2)
if(flag_lj_3_en == 0)
t_high ++ ; //按鍵按下未松開自動加三次
t_high += 10; //按鍵按下未松開自動加三次之后每次自動加10
if(t_high > 990)
t_high = 990;
if(key_can == 3)
t_high -- ; //按鍵按下未松開自動減三次
t_high -= 10; //按鍵按下未松開自動減三次之后每次自動減10
if(t_high <= t_low)
t_high = t_low + 1;
dis_smg[0] = smg_du[t_high % 10]; //取小數顯示
dis_smg[1] = smg_du[t_high / 10 % 10] & 0xdf; //取個位顯示
dis_smg[2] = smg_du[t_high / 100 % 10] ; //取十位顯示
dis_smg[3] = 0x64; //H
if(menu_1 == 2) //設置低溫報警
if(key_can == 2)
t_low ++ ; //按鍵按下未松開自動加三次
t_low += 10; //按鍵按下未松開自動加三次之后每次自動加10
if(t_low >= t_high)
t_low = t_high - 1;
if(key_can == 3)
t_low -- ; //按鍵按下未松開自動減三次
t_low -= 10; //按鍵按下未松開自動加三次之后每次自動加10
if(t_low <= 10)
t_low = 10;
dis_smg[0] = smg_du[t_low % 10]; //取小數顯示
dis_smg[1] = smg_du[t_low / 10 % 10] & 0xdf; //取個位顯示
dis_smg[2] = smg_du[t_low / 100 % 10] ; //取十位顯示
dis_smg[3] = 0x3D; //L
/****************風扇控制函數***************/
void fengshan_kz()
if(temperature >= t_high) //風扇全開
TR1 = 1;
pwm = 0;
else if((temperature < t_high) && (temperature >= t_low)) //風扇緩慢
f_pwm_l = 60;
TR1 = 1;
else if(temperature < t_low) //關閉風扇
TR1 = 0;
pwm = 1;
/****************主函數***************/
P0 = P1 = P2 = P3 = 0xff;
time_init(); //初始化定時器
temperature = read_temp(); //先讀出溫度的值
init_eeprom(); //開始初始化保存的數據
delay_1ms(650);
dis_smg[0] = smg_du[temperature % 10]; //取溫度的小數顯示
dis_smg[1] = smg_du[temperature / 10 % 10] & 0xdf; //取溫度的個位顯示
dis_smg[2] = smg_du[temperature / 100 % 10] ; //取溫度的十位顯示
f_pwm_l = 50;
key(); //按鍵程序
if(key_can < 10)
key_with(); //設置報警溫度
if(flag_300ms == 1) //300ms 處理一次溫度程序
flag_300ms = 0;
if(menu_1 == 0)
smg_i = 3;
fengshan_kz(); //風扇控制函數
/*************定時器0中斷服務程序***************/
void time0_int() interrupt 1
static uchar value; //定時2ms中斷一次
TH0 = 0xf8;
TL0 = 0x30; //2ms
display(); //數碼管顯示函數
value++;
if(value >= 150)
value = 0;
flag_300ms = 1;
if(flag_lj_en == 1) //按下按鍵使能
key_time ++;
if(key_time >= 250) //500ms
key_time = 0;
key_500ms = 1; //500ms
key_value ++;
if(key_value > 3)
key_value = 10;
flag_lj_3_en = 1; //3次后1.5秒連加大些
/*******************定時器1用做單片機模擬PWM 調節***********************/
void Timer1() interrupt 3 //調用定時器1
static uchar value_l;
TH1=0x0f; // 定時中斷一次
TL1=0xec; //
if(pwm==1)
value_l+=3;
if(value_l > f_pwm_l) //高電平
value_l=0;
pwm=0;
value_l+=3;
if(value_l > 100 - f_pwm_l) //低電平
value_l=0;
pwm=1;
