標題: AT24C02EEPROM芯片程序 [打印本頁]
作者: ycstmer    時間: 2017-11-21 09:26
AT24C02EEPROM芯片程序
#include<reg51.h>
#include <intrins.h>
unsigned char sec;        //定義計數值,每過1秒,sec加1
unsigned int tcnt;        //定時中斷次數
bit  write=0;             //寫24C08的標志;
sbit sda=P2^0;                          //IO口定義
sbit scl=P2^1;
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char j,k;
void delay(unsigned char i)                //延時程序
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,                                //數碼管編碼
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void display(uchar bai_c,uchar sh_c)                        //顯示程序
   dula=0;
   P0=table[bai_c];                //顯示百位
   dula=1;
   dula=0;
   wela=0;
   P0=0x7e;
   wela=1;
   wela=0;
   delay(5);
   dula=0;
   P0=table[sh_c];                //顯示十位
   dula=1;
   dula=0;
   wela=0;
   P0=0x7d;
   wela=1;
   wela=0;
   delay(5);
/////////24C08讀寫驅動程序////////////////////
void delay1(unsigned char x)
{  unsigned int i;
  for(i=0;i<x;i++);
void flash()
void x24c08_init()  //24c08初始化子程序
{scl=1; flash(); sda=1; flash();}
void start()        //啟動I2C總線
{sda=1; flash(); scl=1; flash(); sda=0; flash(); scl=0; flash();}
void stop()         //停止I2C總線
{sda=0; flash(); scl=1; flash(); sda=1; flash();}
void writex(unsigned char j)  //寫一個字節
{  unsigned char i,temp;
   temp=j;
   for (i=0;i<8;i++)
   {temp=temp<<1; scl=0; flash(); sda=CY; flash(); scl=1; flash();}
   scl=0; flash(); sda=1; flash();
unsigned char readx()   //讀一個字節
   unsigned char i,j,k=0;
   for (i=0;i<8;i++)
   {  flash(); scl=1; flash();
      if (sda==1) j=1;
      else j=0;
      k=(k<<1)|j;
          scl=0;}
   flash(); return(k);
void clock()         //I2C總線時鐘
   unsigned char i=0;
   scl=1; flash();
   while ((sda==1)&&(i<255))i++;
   scl=0; flash();
////////從24c02的地址address中讀取一個字節數據/////
unsigned char x24c08_read(unsigned char address)
   unsigned char i;
   start(); writex(0xa0);
   clock(); writex(address);
   clock(); start();
   writex(0xa1); clock();
   i=readx(); stop();
   delay1(10);
   return(i);
//////向24c02的address地址中寫入一字節數據info/////
void x24c08_write(unsigned char address,unsigned char info)
   EA=0;
   clock(); writex(info);
   clock(); stop();
   EA=1;
   delay1(50);
void t0(void) interrupt 1 using 0  //定時中斷服務函數
TH0=(65536-50000)/256; //對TH0 TL0賦值
TL0=(65536-50000)%256; //重裝計數初值
tcnt++;        //每過250ust tcnt加一
if(tcnt==20)  //計滿20次(1秒)時
    tcnt=0;   //重新再計
    sec++;
    write=1;  //1秒寫一次24C08
    if(sec==100) //定時100秒,在從零開始計時
      {sec=0;}
unsigned char i;
TMOD=0x01;  //定時器工作在方式1
ET0=1;  EA=1;
x24c08_init();        //初始化24C08
sec=x24c08_read(2);//讀出保存的數據賦于sec
TL0=(65536-50000)%256; //使定時器0.05秒中斷一次
TR0=1;           //開始計時
      i=10;
      while(i--)
        display(sec/10,sec%10);
        if(write==1) //判斷計時器是否計時一秒
         write=0;              //清零
          x24c08_write(2,sec);  //在24c08的地址2中寫入數據sec
