標題: 基于AT89C51單片機的0~59秒計時器C語言程序 [打印本頁]
作者: 祺子and祺寶    時間: 2017-11-5 18:33
#include<reg51.h>
#include<math.h>
uchar code dispcode[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar sec1,sec2,sec3,sec4,sec,arcsec,num;
void delay();//延時函數
  sec=0;
  TMOD=0x01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  ET0=1;
  EA=1;
  TR0=1;
    arcsec=abs(99-sec);
//        sec1=sec/10;
//        sec2=sec%10;
//        sec3=arcsec/10;
//        sec4=arcsec%10;
    P2=0x01;
    P0=dispcode[sec/10];
    delay();
    P2=0x02;
    P0=dispcode[sec%10];
    delay();
    P2=0x10;
    P0=dispcode[arcsec/10];
    delay();
    P2=0x20;
    P0=dispcode[arcsec%10];
    delay();
void int0() interrupt 1
   num++;
   if(num==20)
     num=0;
         sec++;
         if(sec>99)sec=0;
void delay()
  unsigned int i;
  for(i=0;i<125;i++);
