標題: 簡易電子琴 [打印本頁]
作者: 車到山前是死路    時間: 2017-11-2 13:18
標題: 簡易電子琴
#include<reg51.h>
sbit P14=P1^4;
sbit P15=P1^5;
sbit P16=P1^6;
sbit P17=P1^7;
unsigned char keyval;
sbit sound=P3^7;
unsigned int C;
unsigned int f;
#define l_dao 262
#define l_re 286
#define l_mi 311
#define l_fa 349
#define l_sao 392
#define l_la 440
#define l_xi 494
#define dao 523
#define re 587
#define mi 659
#define fa 698
#define sao 784
#define la 880
#define xi 987
#define h_dao 1046
#define h_re 1174
#define h_mi 1318
#define h_fa 1396
#define h_sao 1567
#define h_la 1760
#define h_xi 1975
void delay20ms(void)
   unsigned char i,j;
        for(i=0;i<100;i++)
         for(j=0;j<60;j++)
void delay()
     unsigned char i,j;
          for(i=0;i<250;i++)
            for(j=0;j<250;j++)
void Output_Sound(void)
  C=(46083/f)*10;
  TH0=(8192-C)/32;
  TL0=(8192-C)%32;
  TR0=1;
  delay();
  TR0=0;
  sound=1;
  keyval=0xff;
void main(void)
             EA=1;
           ET0=1;
                ET1=1;
                TR1=1;
      TMOD=0x10;
     TH1=(65536-500)/256;
          TL1=(65536-500)%256;
                                    switch(keyval)
                                                    case 1:f=dao;
                                                            Output_Sound();
        break;
                                                         case 2:f=l_xi;
                                                            Output_Sound();
        break;
                      case 3:f=l_la;
                                                            Output_Sound();
        break;
                                                    case 4:f=l_sao;
                                                              Output_Sound();
        break;
                                                         case 5:f=sao;
        Output_Sound();
        break;
                                                         case 6:f=fa;
                                                             Output_Sound();
        break;
                      case 7:f=mi;
                                                            Output_Sound();
        break;
                                                    case 8:f=re;
                                                            Output_Sound();
        break;
                                                         case 9:f=h_re;
                                                             Output_Sound();
        break;
                                                         case 10:f=h_dao;
                                                            Output_Sound();
        break;
                      case 11:f=xi;
                                                           Output_Sound();
        break;
                                                    case 12:f=la;
                                                            Output_Sound();
        break;
                                                         case 13:f=h_la;
                                                            Output_Sound();
        break;
                                                         case 14:f=h_sao;
                                                            Output_Sound();
        break;
                      case 15:f=h_fa;
                                                            Output_Sound();
        break;
                                                    case 16:f=h_mi;
                                                            Output_Sound();
        break;
  void Time0_serve(void ) interrupt 1 using 1
        TH0=(8192-C)/32;
        TL0=(8192-C)%32;
             sound=!sound;
  void time1_serve(void) interrupt 3 using 2
     TR1=0;
     P1=0xf0;
          if((P1&0xf0)!=0xf0)
                                 delay20ms();
                                  if((P1&0xf0)!=0xf0)
                                       P1=0xfe;
                                       if(P14==0)
                                     keyval=1;
                                   if(P15==0)
                                     keyval=2;
                                   if(P16==0)
                                     keyval=3;
                                   if(P17==0)
                                     keyval=4;
                                   P1=0xfd;
                                      if(P14==0)
                                     keyval=5;
                                   if(P15==0)
                                     keyval=6;
                                   if(P16==0)
                                     keyval=7;
                                   if(P17==0)
                                     keyval=8;
                                   P1=0xfb;
                                    if(P14==0)
                                     keyval=9;
                                   if(P15==0)
                                     keyval=10;
                                   if(P16==0)
                                     keyval=11;
                                   if(P17==0)
                                     keyval=12;
                                   P1=0xf7;
                                    if(P14==0)
                                     keyval=13;
                                   if(P15==0)
                                     keyval=14;
                                   if(P16==0)
                                     keyval=15;
                                   if(P17==0)
                                     keyval=16;
     TR1=1;
