標(biāo)題: 51單片機(jī)GPS經(jīng)緯度信息發(fā)送與顯示的實(shí)物制作與源程序 [打印本頁(yè)]
作者: 君子慎獨(dú)    時(shí)間: 2017-11-1 21:49
利用GPS北斗ATGM336H-5N模塊輸出的原始定位信息,發(fā)到單片機(jī)后進(jìn)行處理,提取有用的信息如經(jīng)緯度、速度、海拔、日期等,通過(guò)串口發(fā)到電腦的串口調(diào)試助手進(jìn)行顯示,并顯示到LCD屏幕。
程序的功能有GPS信息顯示與發(fā)送(LCD顯示經(jīng)緯度、海拔、速度,電腦串口接收時(shí)間、日期、經(jīng)緯度、海拔、速度數(shù)據(jù))
GPS原始數(shù)據(jù)捕獲(從一開(kāi)始通電時(shí)不完整到過(guò)一會(huì)后完整)見(jiàn)附件
GPS原始數(shù)據(jù)捕獲與簡(jiǎn)單分析:
$GNGGA,120726.000,3208.0858,N,11841.7828,E,1,05,4.3,12.7,M,0.0,M,,*40
$GNGLL,3208.0858,N,11841.7828,E,120726.000,A,A*43
$GPGSA,A,3,12,25,,,,,,,,,,,6.9,4.3,5.4*3F
$BDGSA,A,3,10,04,07,,,,,,,,,,6.9,4.3,5.4*28
$GPGSV,3,1,12,04,,,21,10,66,313,,12,42,100,34,14,21,289,*49
$GPGSV,3,2,12,15,18,086,,18,79,174,27,20,13,143,24,21,18,203,*73
$GPGSV,3,3,12,24,40,042,,25,37,150,31,31,10,230,,32,33,301,*7A
$BDGSV,1,1,04,03,,,35,04,32,122,34,07,54,184,34,10,33,200,36*50
$GNRMC,120726.000,A,3208.0858,N,11841.7828,E,0.11,303.11,031017,,,A*70
$GNVTG,303.11,T,,M,0.11,N,0.20,K,A*21
$GNZDA,120726.000,03,10,2017,00,00*4E
$GPTXT,01,01,01,ANTENNA OK*35
原始數(shù)據(jù)中逗號(hào)數(shù)量和順序的統(tǒng)計(jì):
      1          2         3 4          5 6 7  8   9   a b   c d
$GNGGA,034214.000,3208.1201,N,11841.7167,E,1,07,1.7,7.7,M,0.0,M,,*7 OK*
      1          2 3         4 5          6 7    8      9      abc
$GNRMC,034214.000,A,3208.1201,N,11841.7167,E,2.71,336.76,041017,,,A*700
GPS原始數(shù)據(jù)及處理后的數(shù)據(jù)
(見(jiàn)附件)
單片機(jī)源程序如下:
  1. /*******************************************************************************
  2.         單片機(jī)的RXD端口接收來(lái)自GPS模塊的數(shù)據(jù),把數(shù)據(jù)進(jìn)行處理,并顯示到Lcd上,同時(shí)
  3. 通過(guò)TXD端口經(jīng)過(guò)USB-TTL模塊發(fā)送到電腦的串口調(diào)試軟件上顯示。
  4.         注意事項(xiàng):
  5.         1、串口調(diào)試軟件的波特率要設(shè)為9600;
  6.         2、單片機(jī)與USB-TTL模塊兩者要共地。。。ㄎ乙膊恢獮槭裁矗瑪偸.jpg)
  7. *******************************************************************************/
  8. #include "reg52.h"
  9. #include "main.h"
  10. #include "LCD1602.h"
  11. #include "GPS.h"
  12. unsigned char xdata Display_GPGGA_Buffer[68]={0};                //用于儲(chǔ)存GPGGA的數(shù)據(jù)
  13. unsigned char xdata Display_GPRMC_Buffer[68]={0};                //用于儲(chǔ)存GPRMC的數(shù)據(jù)
  14. unsigned int k=0,qian_a=0,hou_a=0,qian_b=0,hou_b=0,qian_c=0,hou_c=0;        //存儲(chǔ)前后逗號(hào)的位置序號(hào)的變量
  15. bit qian_OK=0;                   //已找出前面的逗號(hào)的標(biāo)志變量
  16. bit First_Share_OK=0;  //已開(kāi)始LCD顯示的標(biāo)志變量
  17. bit jiajian=1;                    //進(jìn)行加或減的標(biāo)志變量
  18. //bit Page = 0;
  19. bit Flag_OV = 0;           //日期需進(jìn)位的標(biāo)志變量
  20. bit Flag_Calc_GPGGA_OK = 0;           //GPGGA完整有效的數(shù)據(jù)已收到的標(biāo)志變量
  21. bit Flag_Calc_GPRMC_OK = 0;           //GPRMC完整有效的數(shù)據(jù)已收到的標(biāo)志變量
  22. //****************************************************
  23. //主函數(shù)
  24. //****************************************************
  25. void main()
  26. {
  27.         unsigned int i = 0;
  28.         unsigned int j=0;
  29.         Init_LCD1602();        //LCD初始化
  30.         LCD1602_write_com(0x80);                                                //LCD指針設(shè)置到第一行第一列
  31.         LCD1602_write_word("Searching data. ");                        //顯示正在搜索數(shù)據(jù)
  32.         Uart_Init();        //串口初始化
  33.         while(1)
  34.         {
  35. //                Scan_Key();
  36.                 qian_OK=0;        //標(biāo)志變量歸零
  37.                 k=0;        //累計(jì)量歸零
  38.                 if (First_Share_OK==0)                                  //讓變量j在0~10000之間來(lái)回增減,增加到10000時(shí)顯示". ",減到0時(shí)顯示" .",實(shí)現(xiàn)兩點(diǎn)來(lái)回閃動(dòng)
  39.                 {
  40.                         if (jiajian==1)
  41.                         {
  42.                                 j++;
  43.                                 if (j==10000)
  44.                                 {
  45.                                         jiajian=0;
  46.                                         LCD1602_write_com(0x8e);
  47.                                         LCD1602_write_data('.');
  48.                                         LCD1602_write_com(0x8f);
  49.                                         LCD1602_write_data(' ');
  50.                                 }
  51.                         }
  52.                         else
  53.                         {
  54.                                 j--;
  55.                                 if (j==0)
  56.                                 {
  57.                                         jiajian=1;
  58.                                         LCD1602_write_com(0x8e);
  59.                                         LCD1602_write_data(' ');
  60.                                         LCD1602_write_com(0x8f);
  61.                                         LCD1602_write_data('.');
  62.                                 }
  63.                         }
  64.                 }
  65. //代碼詳見(jiàn)附件
  66. //                {
  67. //                        UartPrintf("----------------------------------------------\r\n");
  68. //                        UartPrintf(RX_Buffer);
  69. //                        UartPrintf("\r\n");
  70. //                }
  71.
  72.                 if (   Flag_GPS_OK  == 1
  73.                            && RX_Buffer[1] == 'G'
  74.                         && RX_Buffer[3] == 'G'
  75.                         && RX_Buffer[4] == 'G'
  76.                         && RX_Buffer[5] == 'A'
  77.                         && (RX_Buffer[28] == 'N'|| RX_Buffer[28] == 'S')
  78.                         && (RX_Buffer[41] == 'E'|| RX_Buffer[41] == 'W') )                //確認(rèn)是否收到"GPGGA"這一幀完整有效的數(shù)據(jù)
  79.                 {
  80.                         for( i = 0; i < 67 ; i++)                                                  //必須為i<67,因?yàn)橐_保Display_GPGGA_Buffer[67]為'\0',便于串口發(fā)送
  81.                         {
  82.                                 Display_GPGGA_Buffer[i] = RX_Buffer[i];                  //儲(chǔ)存到數(shù)組中
  83.                         }
  84.                         Flag_Calc_GPGGA_OK = 1;                                                          //收到完整有效數(shù)據(jù)后,置為1
  85.                 }
  86.                 if(Flag_Calc_GPGGA_OK == 1)                                                          //已收到完整有效的數(shù)據(jù),可以進(jìn)行顯示,
  87.                 {
  88.                         Flag_Calc_GPGGA_OK = 0;                                                          //標(biāo)志位歸零
  89.                         if (First_Share_OK == 0)
  90.                         {
  91.                                 First_Share_OK=1;                                                          //"Searching data. "不需再顯示,標(biāo)志變量置為1
  92.                                 LCD1602_write_com(0x01);                                          //先清屏
  93.                         }
  94.
  95.                         LCD1602_write_com(0x80);
  96.                         LCD1602_write_data(Display_GPGGA_Buffer[28]);                        //顯示 N 或者 S
  97.                         LCD1602_write_word(": ");
  98.                         LCD1602_write_data(Display_GPGGA_Buffer[18]);                        //緯度
  99.                         LCD1602_write_data(Display_GPGGA_Buffer[19]);
  100.                         LCD1602_write_data(0xdf);        //度符號(hào)的ASCII碼,16進(jìn)制
  101.                         LCD1602_write_data(Display_GPGGA_Buffer[20]);                        //緯度
  102.                         LCD1602_write_data(Display_GPGGA_Buffer[21]);
  103.                         LCD1602_write_word("'");        //秒
  104.                         for (i=0;i<68;i++)                                                  //由于海拔有時(shí)是1位數(shù)有時(shí)是2位數(shù)有時(shí)是3位數(shù),不定
  105.                         {        //而確定的是其數(shù)值在第9與第10個(gè)逗號(hào)之間,所以用此算法輸出海拔
  106.                                 if ( Display_GPGGA_Buffer[i]==',' )          //逐個(gè)檢索
  107.                                         k++;                                                          //k計(jì)算逗號(hào)數(shù)量
  108.                                 if (k==9&&qian_OK==0)
  109.                                         qian_a=i,qian_OK=1;                                  //找到第9個(gè),則記錄其序號(hào),同時(shí)標(biāo)志變量置為1
  110.                                 if (k==10)                                                          //海拔數(shù)據(jù)位于第9~10個(gè)逗號(hào)之間
  111.                                 {
  112.                                         hou_a=i;                                                  //記錄第10個(gè)的序號(hào)
  113.                                         k=0;                                                           //歸零
  114.                                         qian_OK=0;                                                  //重置為0
  115.                                         break;                                                          //找到后直接跳出循環(huán)
  116.                                 }
  117.                         }
  118.                         LCD1602_write_com(0x89);                                                  //準(zhǔn)備在第一行第9列輸出海拔數(shù)據(jù)
  119.                         switch(hou_a-qian_a-1)                                                        //計(jì)算海拔數(shù)據(jù)的長(zhǎng)度
  120.                         {
  121.                                 case 3:LCD1602_write_word("   ");break;                //根據(jù)海拔數(shù)據(jù)長(zhǎng)度輸出對(duì)應(yīng)所需的空格數(shù),使其顯示方式為右對(duì)齊
  122.                                 case 4:LCD1602_write_word("  ");break;
  123.                                 case 5:LCD1602_write_word(" ");break;
  124.                                 case 6:break;
  125.                                 case 7:break;
  126.                         }
  127.                         for (i=qian_a+1; i<=hou_a-1; i++)
  128.                                 LCD1602_write_data(Display_GPGGA_Buffer[i]);           //輸出海拔
  129.                         LCD1602_write_data('m');                                                           //顯示單位
  130.
  131.                         LCD1602_write_com(0xc0);        //在第2行第1列開(kāi)始輸出經(jīng)度
  132.                         LCD1602_write_data(Display_GPGGA_Buffer[41]);                          //輸出E 或者 W
  133.                         LCD1602_write_data(':');
  134.                         LCD1602_write_data(Display_GPGGA_Buffer[30]);                        //經(jīng)度
  135.                         LCD1602_write_data(Display_GPGGA_Buffer[31]);
  136.                         LCD1602_write_data(Display_GPGGA_Buffer[32]);
  137.                         LCD1602_write_data(0xdf);
  138.                         LCD1602_write_data(Display_GPGGA_Buffer[33]);
  139.                         LCD1602_write_data(Display_GPGGA_Buffer[34]);
  140.                         LCD1602_write_word("'");
  141.                         UartPrintf("----------------------------------------------\r\n");                 //串口發(fā)送數(shù)據(jù)到電腦
  142.                         UartPrintf("Original data(1):\r\n");
  143.                         UartPrintf(Display_GPGGA_Buffer);        //直接把首地址作為實(shí)參
  144.                         UartPrintf("......\r\n");
  145.                         UartPrintf("Processed data(1): \r\n");
  146.                         UartPrintData(Display_GPGGA_Buffer[28]);                        //N 或者 S
  147.                         UartPrintf(":  ");
  148.                         UartPrintData(Display_GPGGA_Buffer[18]);                        //發(fā)送緯度
  149.                         UartPrintData(Display_GPGGA_Buffer[19]);
  150.                         UartPrintData('*');        //串口無(wú)法發(fā)送擴(kuò)展的ASCII碼(大于127),所以用*代替度數(shù)符號(hào)
  151.                         UartPrintData(Display_GPGGA_Buffer[20]);
  152.                         UartPrintData(Display_GPGGA_Buffer[21]);
  153.                         UartPrintData('\'');
  154.                         UartPrintf("\r\n");        //發(fā)送回車換行
  155.
  156.                         UartPrintData(Display_GPGGA_Buffer[41]);                        //E 或者 W
  157.                         UartPrintf(": ");
  158.                         UartPrintData(Display_GPGGA_Buffer[30]);
  159.                         UartPrintData(Display_GPGGA_Buffer[31]);
  160.                         UartPrintData(Display_GPGGA_Buffer[32]);
  161.                         UartPrintData('*');
  162.                         UartPrintData(Display_GPGGA_Buffer[33]);                        //發(fā)送經(jīng)度
  163.                         UartPrintData(Display_GPGGA_Buffer[34]);
  164.                         UartPrintData('\'');
  165.                         UartPrintf("\r\n");
  166.                         UartPrintf("Altitude: ");
  167.                         for (i=qian_a+1; i<=hou_a-1; i++)                                        //發(fā)送海拔
  168.                                 UartPrintData(Display_GPGGA_Buffer[i]);
  169.                         UartPrintf(" m");
  170.                         UartPrintf("\r\n");
  171.
  172.                 }
  173. //  這部分代碼詳見(jiàn)附件
  174. && RX_Buffer[1] == 'G'&& RX_Buffer[3] == 'R'&& RX_Buffer[4] == 'M'&& RX_Buffer[5] == 'C')
  175. //                {
  176. //                        UartPrintf(RX_Buffer);
  177. //                        UartPrintf("\r\n");
  178. //                }
  179.
  180.                 if(   Flag_GPS_OK  == 1
  181.                    && RX_Buffer[1] == 'G'
  182.                    && RX_Buffer[3] == 'R'
  183.                    && RX_Buffer[4] == 'M'
  184.                    && RX_Buffer[5] == 'C'
  185.                    && RX_Buffer[18]== 'A')                //確認(rèn)是否收到"GPRMC"這一幀完整有效的數(shù)據(jù)
  186.                 {
  187.                         for( i = 0; i < 67 ; i++)
  188.                         {
  189.                                 Display_GPRMC_Buffer[i] = RX_Buffer[i];
  190.                         }
  191.
  192.                         Flag_Calc_GPRMC_OK = 1;
  193.
  194.                         Hour = (Display_GPRMC_Buffer[7]-0x30)*10+(Display_GPRMC_Buffer[8]-0x30)+8;        //UTC時(shí)間轉(zhuǎn)換到北京時(shí)間(東八區(qū)),0x30即48
  195.                         if( Hour >= 24)                                //如果溢出
  196.                         {
  197.                                 Hour %= 24;                                //獲取實(shí)際Hour
  198.                                 Flag_OV = 1;                        //日期進(jìn)位的標(biāo)志變量置為1
  199.                         }
  200.                         else
  201.                         {
  202.                                 Flag_OV = 0;
  203.                         }
  204.                         Min_High = Display_GPRMC_Buffer[9];
  205.                         Min_Low = Display_GPRMC_Buffer[10];                           //獲取時(shí)間數(shù)據(jù)
  206.                         Sec_High = Display_GPRMC_Buffer[11];
  207.                         Sec_Low = Display_GPRMC_Buffer[12];
  208.                         for (i=0;i<68;i++)                //由于日期數(shù)據(jù)前面的速度數(shù)據(jù)也是位數(shù)不定,所以速度數(shù)據(jù)位數(shù)也不定,故亦用此算法精確地確定日期數(shù)據(jù)位置
  209.                         {
  210.                                 if ( Display_GPRMC_Buffer[i]==',' )
  211.                                         k++;
  212.                                 if (k==9&&qian_OK==0)                                                            //日期數(shù)據(jù)位于第9~10個(gè)逗號(hào)之間
  213.                                         qian_b=i,qian_OK=1;
  214.                                 if (k==10)
  215.                                 {
  216.                                         hou_b=i;
  217.                                         k=0;
  218.                                         qian_OK=0;
  219.                                         break;
  220.                                 }
  221.                         }
  222.                         Year_High = Display_GPRMC_Buffer[qian_b+5];                                //獲取日期
  223.                         Year_Low = Display_GPRMC_Buffer[qian_b+6];
  224.                         Month_High = Display_GPRMC_Buffer[qian_b+3];
  225.                         Month_Low = Display_GPRMC_Buffer[qian_b+4];
  226.                         Day_High = Display_GPRMC_Buffer[qian_b+1];
  227.                         Day_Low = Display_GPRMC_Buffer[qian_b+2];
  228.                         if(Flag_OV == 1)        //如果日期須進(jìn)位
  229.                         {
  230.                                 UTCDate2LocalDate();        //UTC日期進(jìn)位并轉(zhuǎn)換為北京時(shí)間
  231.                         }
  232.                 }
  233.                 if(Flag_Calc_GPRMC_OK == 1)                            //GPRMC數(shù)據(jù)完整有效則顯示
  234.                 {
  235.                         Flag_Calc_GPRMC_OK = 0;
  236.                         if (First_Share_OK == 0)
  237.                         {
  238.                                 First_Share_OK=1;
  239.                                 LCD1602_write_com(0x01);
  240.                         }
  241.                         for (i=0;i<68;i++)        //由于速度數(shù)據(jù)也是位數(shù)不定,故亦用此算法精確地確定速度數(shù)據(jù)位置
  242.                         {
  243.                                 if ( Display_GPRMC_Buffer[i]==',' )
  244.                                         k++;
  245.                                 if (k==7&&qian_OK==0)                                                  //速度數(shù)據(jù)位于第7~8個(gè)逗號(hào)之間
  246.                                         qian_c=i,qian_OK=1;
  247.                                 if (k==8)
  248.                                 {
  249.                                         hou_c=i;
  250.                                         k=0;
  251.                                         qian_OK=0;
  252.                                         break;
  253.                                 }
  254.                         }
  255.                         LCD1602_write_com(0xc9);                                                       //準(zhǔn)備在第2行第9列顯示
  256.                         switch(hou_c-qian_c-2)                                                            //原式為(hou_c-1)-qian_c-1。由于速度不太準(zhǔn)還浮動(dòng),故只讓它顯示一位小數(shù)
  257.                         {
  258.                                 case 3:LCD1602_write_word(" ");break;                    //使右對(duì)齊
  259.                                 case 4:break;
  260.                                 case 5:break;
  261.                         }
  262.                         for (i=qian_c+1; i<=hou_c-2; i++)                                        //(原式為hou_c-1-1)
  263.                                 LCD1602_write_data(Display_GPRMC_Buffer[i]);        //顯示速度
  264.                         LCD1602_write_word("m/s");                                                        //顯示單位
  265.                         UartPrintf("\r\n");
  266.                         UartPrintf("Original data(2):\r\n");
  267.                         UartPrintf(Display_GPRMC_Buffer);
  268.                         UartPrintf("......\r\n");
  269.                         UartPrintf("Processed data(2): \r\n");
  270.                         UartPrintf("Time: ");
  271.                         UartPrintData(Hour/10+0x30);                                          //串口發(fā)送時(shí)間
  272.                         UartPrintData(Hour%10+0x30);
  273.                         UartPrintData(':');
  274.                         UartPrintData(Min_High);
  275.                         UartPrintData(Min_Low);
  276.                         UartPrintData(':');
  277.                         UartPrintData(Sec_High);
  278.                         UartPrintData(Sec_Low);
  279.                         UartPrintf("\r\n");
  280.                          UartPrintf("Date: ");        //發(fā)送日期
  281.                         UartPrintf("20");
  282.                         UartPrintData(Display_GPRMC_Buffer[qian_b+5]);
  283.                         UartPrintData(Display_GPRMC_Buffer[qian_b+6]);
  284.                         UartPrintData('-');
  285.                         UartPrintData(Display_GPRMC_Buffer[qian_b+3]);
  286.                         UartPrintData(Display_GPRMC_Buffer[qian_b+4]);
  287.                         UartPrintData('-');
  288.                         UartPrintData(Display_GPRMC_Buffer[qian_b+1]);
  289.                         UartPrintData(Display_GPRMC_Buffer[qian_b+2]);
  290.                         UartPrintf("\r\n");
  291.                         UartPrintf("Speed: ");
  292.                         for (i=qian_c+1; i<=hou_c-1; i++)
  293.                                 UartPrintData(Display_GPRMC_Buffer[i]);
  294.                         UartPrintf(" m/s\r\n");        //發(fā)送速度,2位小數(shù)都發(fā)
  295.                         UartPrintf("----------------------------------------------\r\n");//分隔符
  296.
  297.                 }
  298.
  299.         }
  300. }
  301. //****************************************************
  302. //UTC日期與當(dāng)?shù)厝掌谵D(zhuǎn)換
  303. //****************************************************
  304. void UTCDate2LocalDate(void)
  305. {
  306.         Day = (Day_High - 0x30) * 10 + (Day_Low-0x30) + 1;                //日期進(jìn)一
  307.         Month = (Month_High - 0x30) * 10 + (Month_Low - 0x30);
  308.         Year = 2000 + (Year_High - 0x30) * 10 + (Year_Low - 0x30);
  309.
  310.         MaxDay = GetMaxDay(Month,Year);                                //獲取當(dāng)月天數(shù)最大值
  311.         if(Day > MaxDay)                //如果溢出
  312.         {
  313.                 Day = 1;
  314.                 Month += 1;
  315.                 if(Month > 12)
  316.                 {
  317.                         Year+=1;
  318.                 }
  319.         }
  320.         Day_High = Day/10 + 0x30;                                //轉(zhuǎn)換日期值為ASCII
  321.         Day_Low = Day%10 + 0x30;
  322.         Month_High = Month/10 + 0x30;
  323.         Month_Low = Month%10 + 0x30;
  324.         Year_High = Year%100/10 + 0x30;
  325.         Year_Low = Year%10 + 0x30;
  326. }
  327. //****************************************************
  328. //獲取當(dāng)月日期最大值
  329. //****************************************************
  330. unsigned char GetMaxDay(unsigned char Month_Value,unsigned int Year_Value)
  331. {
  332.         unsigned char iDays;
  333.         switch(Month_Value)
  334.         {
  335.                 case 1:
  336.                 case 3:
  337.                 case 5:
  338.                 case 7:
  339.                 case 8:
  340.                 case 10:
  341.                 case 12:
  342.                         {
  343.                                 iDays = 31;
  344.                         }
  345.                         break;
  346.                 case 2:
  347.                         {
  348.                                 //2月份比較特殊,需要根據(jù)是不是閏年來(lái)判斷當(dāng)月是28天還29天
  349.                                 iDays = IsLeapYear(Year_Value) ? 29 : 28 ;
  350.                         }
  351.                         break;
  352.                 case 4:
  353.                 case 6:
  354.                 case 9:
  355.                 case 11:
  356.                         {
  357.                                 iDays = 30;
  358.                         }
  359. ……………………
  360. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
GPS(LCD,USart).zip (101.7 KB, 下載次數(shù): 363)
作者: xwnc    時(shí)間: 2017-11-8 18:34
樓主太強(qiáng)了,學(xué)習(xí)學(xué)習(xí)
作者: marklee    時(shí)間: 2018-1-8 09:17
好東西 學(xué)習(xí)學(xué)習(xí)
作者: 114892148    時(shí)間: 2018-1-17 12:38
太贊了樓主
作者: jack2694514902    時(shí)間: 2018-4-12 20:36
樓主,有急用,能分享下嗎
作者: aking991    時(shí)間: 2018-9-27 17:00
曾經(jīng)也作了一個(gè),還是匯編版的,本想改成C版的,可是一直沒(méi)時(shí)間處理
作者: andyliang    時(shí)間: 2018-9-28 11:58
什么時(shí)候能跟上樓主
作者: index.jsp    時(shí)間: 2018-11-17 23:20
很棒。學(xué)習(xí)一下
作者: 1589959571    時(shí)間: 2018-11-24 16:09
樓主有沒(méi)有仿真
作者: 君子慎獨(dú)    時(shí)間: 2018-12-27 02:34
1589959571 發(fā)表于 2018-11-24 16:09
樓主有沒(méi)有仿真
GPS哪能仿真鴨
作者: 阿維拉    時(shí)間: 2019-2-22 10:56
怎么能讓其顯示在彩屏上
作者: tyj123456    時(shí)間: 2019-2-27 22:38
作者: Jeff_BlindCat    時(shí)間: 2019-3-25 08:30
謝謝樓主分享,還沒(méi)法下載。
作者: 小姜戈    時(shí)間: 2019-5-5 14:45
樓主的分享非常有用,可是我按這個(gè)程序做出來(lái),串口接收到的還是這種$GNGGA,034214.000,3208.1201,N,11841.7167,E,1,07,1.7,7.7,M,0.0,M,,*7 OK*形式的數(shù)據(jù),這是什么原因呢麻煩樓主指點(diǎn)一下下
作者: hyz5122    時(shí)間: 2019-7-6 12:08
文章不錯(cuò),就是要的積分有點(diǎn)高。!
作者: hyz5122    時(shí)間: 2019-7-6 12:24
看了一下發(fā)表的部分,非常不錯(cuò),學(xué)習(xí)了!
作者: 快樂(lè)眼淚    時(shí)間: 2019-7-7 20:44
這個(gè)真不錯(cuò)!
作者: aaaaaa。    時(shí)間: 2019-10-16 20:58
請(qǐng)問(wèn)樓主能發(fā)一下原理圖嗎
作者: liuhua1111    時(shí)間: 2019-10-29 14:30
這代碼強(qiáng)強(qiáng)強(qiáng),學(xué)習(xí)
作者: 153905507    時(shí)間: 2019-11-4 15:37
原理圖可以發(fā)下嗎
作者: 吾乃長(zhǎng)山霸王龍    時(shí)間: 2019-12-6 14:44
可以請(qǐng)作者發(fā)下原理圖嗎
作者: 吾乃長(zhǎng)山霸王龍    時(shí)間: 2019-12-6 14:51
樓主求原理圖
作者: ynzsc001    時(shí)間: 2019-12-30 17:42
提示...........\main.m51 contains an  incorrect path.
導(dǎo)致文件編譯不了
作者: scyqwer    時(shí)間: 2019-12-31 14:54
gps調(diào)試
作者: 123456qwj    時(shí)間: 2020-4-14 22:09
為啥我的液晶屏上沒(méi)有顯示數(shù)據(jù)
作者: zxopenljx    時(shí)間: 2020-6-7 15:39
感謝樓主分享
