TM1804程序問題
xcj
2017-10-27 19:26
TM1804程序問題
#include<reg51.h>
#include<intrins.h>
#define nop() _nop_()
#define Red 1
#define Green 2
#define Blue 3
#define White 4
#define High 1
#define Low 0
sbit DIO=P1^0;
bdata uchar a;
sbit a7=a^7;
sbit LED=P2^2;
uchar show[3],color=1,temp=0xff;
void delay_ms(int z)
int x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write(uchar date)
uchar i;
for(i=0;i<8;i++)
if(date&0x80)
DIO=1;
nop(); nop(); nop(); nop();
DIO=0;
DIO=1;
nop();nop();nop();nop();
nop();
DIO=0;
date<<=1;
void display()
uchar i,j;
for(j=0;j<1;j++)
for(i=0;i<3;i++)
write(show[i]);
void load()
uchar i;
for(i=0;i<1;i++)
if(color==Red)
show[i*3+0]=temp;
show[i*3+1]=0x00;
show[i*3+2]=0x00;
if(color==Green)
show[i*3+0]=0x00;
show[i*3+1]=temp;
show[i*3+2]=0x00;
if(color==Blue)
show[i*3+0]=0x00;
show[i*3+1]=0x00;
show[i*3+2]=temp;
if(color==White)
show[i*3+0]=temp;
show[i*3+1]=temp;
show[i*3+2]=temp;
void show_3()
for(color=1;color<5;color++)
for(temp=0;temp<255;temp++)
load();
display();
delay_ms(50);
for(temp=255;temp>0;temp--)
load();
display();
delay_ms(50);
void show_1()
uchar i;
for(i=0;i<2;i++)
write(0xff);
write(0x00);
write(0xaa);
write(0xff);
write(0x00);
write(0xaa);
write(0xff);
write(0x00);
write(0xaa);
write(0xff);
write(0xff);
write(0xff);
uchar i,j;
for(j=0;j<4;j++)
for(i=0;i<3;i++)
write(0xff);
delay_ms(50);
show_3();
LED=!LED;
有誰能給講解下這個程序嗎?
理解起來有點混亂
