標題: stm32 +tm1638 只能顯示,不能讀鍵 [打印本頁]
作者: hrsoftgao    時間: 2017-10-24 19:42
stm32 +tm1638 只能顯示,不能讀鍵 為何?那地方出了問題 求大神指點。
void TM1638_Write(unsigned char        DATA)                        //D′êy¾Yoˉêy
        unsigned char i;
        for(i=0;i<8;i++)
                CLK=0;
                if(DATA&0X01)
                        DIO=1;
                        DIO=0;
                DATA>>=1;
                CLK=1;
unsigned char TM1638_Read(void)                                        //¶áêy¾Yoˉêy
        unsigned char i;
        unsigned char temp=0;
        DIO=1;        //éèÖÃÎaêäèë
        for(i=0;i<8;i++)
        delay_us(5)        ;
                temp>>=1;
                CLK=0;
                if(DIO)
                        temp|=0x80;
                CLK=1;
        return temp;
void Write_COM(unsigned char cmd)                //·¢ËíÃüáî×Ö
        STB=0;
        TM1638_Write(cmd);
        STB=1;
unsigned char Read_key(void)
        unsigned char c[4],i,key_value=0;
        STB=0;
                delay_ms(100);
        TM1638_Write(0x42);
        delay_ms(100);
        for(i=0;i<4;i++)
                        c[ i]=TM1638_Read();
        STB=1;                                        //4¸ö×Ö½úêy¾YoÏ3éò»¸ö×Ö½ú
        if(c[0]==0x04) key_value=1;
        if(c[0]==0x40) key_value=2;
        if(c[1]==0x04) key_value=3;
        if(c[1]==0x40) key_value=4;
        if(c[2]==0x04) key_value=5;
        if(c[2]==0x40) key_value=6;
        if(c[3]==0x04) key_value=7;
        if(c[3]==0x40) key_value=8;
        if(c[0]==0x02) key_value=9;
        if(c[0]==0x20) key_value=10;
        if(c[1]==0x02) key_value=11;
        if(c[1]==0x20) key_value=12;
        if(c[2]==0x02) key_value=13;
        if(c[2]==0x20) key_value=14;
        if(c[3]==0x02) key_value=15;
        if(c[3]==0x20) key_value=16;
        return (key_value);
網上的代碼,顯示沒問題。
while (1)
        LedDisplay(1,3,7,0,2,1,0,2);
        delay_ms(1000);
                key_value=Read_key();
        switch (key_value)
                case 1:
                LedDisplay(1,0,0,0,0,0,0,0);
                break;
                case 2 :
                LedDisplay(2,0,0,0,0,0,0,0);
                break;
                case 3 :
                LedDisplay(3,0,0,0,0,0,0,0);
                break;
                case 4 :
                LedDisplay(4,0,0,0,0,0,0,0);
                break;
                case 5 :
                LedDisplay(5,0,0,0,0,0,0,0);
                break;
                case 6 :
                LedDisplay(6,0,0,0,0,0,0,0);
                break;
                case 7 :
                LedDisplay(7,0,0,0,0,0,0,0);
                break;
                case 8 :
                LedDisplay(8,0,0,0,0,0,0,0);
                break;
                case 9:
                LedDisplay(9,0,0,0,0,0,0,0);
                break;
                case 10 :
                LedDisplay(0,1,0,0,0,0,0,0);
                break;
                case 11 :
                LedDisplay(1,1,0,0,0,0,0,0);
                break;
                case 12 :
                LedDisplay(2,1,0,0,0,0,0,0);
                break;
                case 13 :
                LedDisplay(3,1,0,0,0,0,0,0);
                break;
                case 14 :
                LedDisplay(4,1,0,0,0,0,0,0);
                break;
                case 15:
                LedDisplay(5,1,0,0,0,0,0,0);
                break;
                case 16 :
                LedDisplay(6,1,0,0,0,0,0,0);
                break;
                default :
                break;//LedDisplay(0,0,0,0,0,0,0,0);
                有需要 stm32 驅動tm1638的工程的告訴我 我把我的工程放上來
在線等待
作者: hrsoftgao    時間: 2017-10-25 22:24
沒高手嗎?
作者: lumilu    時間: 2018-6-17 15:39
群主,你的問題解決了沒有?
作者: hrsoftgao    時間: 2019-4-4 20:05
解決了
作者: longqishi57777    時間: 2022-7-5 10:49
問下樓主是怎么解決的,我也遇到了
作者: longqishi57777    時間: 2022-7-6 09:49
自己頂一下在 TM1638_Read(void) 函數中, CLK=0;與 if(DIO)之間加一個_nop_(),在stc15W實測可以
