標題: 單片機16*16點陣漢字顯示仿真加源碼 用74hc595驅動芯片 [打印本頁]
作者: 你好249    時間: 2017-10-14 21:46
單片機16*16點陣仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
點陣由于電流比較大不能直接接單片機所以用74hc595驅動串轉并芯片,還可以實現用很少的io口來控制.
  1. #include "reg51.h"
  3. #define uint  unsigned int
  4. #define Lie   P1
  5. sbit SHCP = P2^0;
  6. sbit  DS  = P2^1;
  7. sbit STCP = P2^2;
  8. uchar code led[ ] ={
  9. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  10. 0x08,0x40,0x08,0x40,0x0A,0x48,0xEA,0x4B,0xAA,0x4A,0xAA,0x4A,0xAA,0x4A,0xFE,0x7F,
  11. 0xAA,0x4A,0xAA,0x4A,0xA9,0x4A,0xF9,0x4B,0x29,0x48,0x0C,0x60,0x08,0x40,0x00,0x00, // 重
  12. 0x00,0x40,0x00,0x20,0xFC,0x9F,0x44,0x80,0x44,0x40,0x44,0x20,0x44,0x18,0x45,0x06,
  13. 0xFE,0x01,0x44,0x06,0x44,0x18,0x44,0x20,0x66,0x40,0x44,0xC0,0x00,0x40,0x00,0x00, //慶
  14. 0x80,0x80,0x80,0x40,0xFC,0x3F,0x96,0x02,0xA5,0x44,0x84,0x80,0xFC,0x7F,0x08,0x80,
  15. 0x08,0x40,0xC9,0x3F,0x4A,0x00,0x4E,0x00,0xE8,0x3F,0x4C,0x40,0x08,0x70,0x00,0x00, //航
  16. 0x40,0x80,0x42,0x80,0x42,0x40,0x42,0x20,0x42,0x10,0x42,0x0C,0x42,0x03,0xFE,0x00,
  17. 0x42,0x03,0x42,0x0C,0x42,0x10,0x42,0x20,0x43,0x40,0x62,0xC0,0x40,0x40,0x00,0x00,         //天
  18. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  19. };
  20. //uchar led[]={}
  21. void shift16bit(uchar dat1,uchar dat2)  //595輸出16位數據
  22. {
  23. uchar i;
  24. STCP=0;
  25. for(i=0;i<8;i++)
  26.   {
  27.    SHCP=0;
  28.    if(dat1 &0x80) DS=1;
  29.      else DS=0;
  30.     dat1<<=1;
  31.    SHCP=1;
  32.   }
  33.   for(i=0;i<8;i++)
  34.   {
  35.    SHCP=0;
  36.    if(dat2 &0x80) DS=1;
  37.      else DS=0;
  38.     dat2<<=1;
  39.    SHCP=1;
  40.   }
  41. STCP=1;
  42. }
  43. void delay(uint x)
  44. {
  45. uint i;
  46. for(i=0;i<x;i++);
  47. }
  48. void main()
  49. {
  50. uchar i,x=0;
  51. uint n;
  52. while(1)
  53. {
  54. for(n=0;n<10;n++)
  55. for(i=0;i<16;i++)
  56.   {
  57.    Lie=i;
  58.    shift16bit(led[2*i+1+2*x],led[2*i+2*x]);
  59.    delay(100);
  60.   }
  61.   x++;
  62. if(x==64) x=0;
  63. /*
  64. for(n=0;n<100;n++)
  65. ……………………
  66. …………限于本文篇幅 余下代碼請從51黑下載附件…………
16by16點陣.rar (226.09 KB, 下載次數: 136)
作者: Liar1717    時間: 2018-5-16 14:30
謝謝,正好需要
作者: 1292240963    時間: 2018-12-17 16:47
贊一個,good啊
作者: ty417502873    時間: 2018-12-19 06:23
有沒有四片595的程序
作者: 劉啊    時間: 2019-6-10 22:50
dat1不需要初始值嗎
作者: 1847218429    時間: 2019-6-22 12:28
插旗  待會回來
作者: WQL_X    時間: 2019-7-8 19:06
還不錯
作者: liut3027    時間: 2020-1-8 23:44
太強了
作者: liut3027    時間: 2020-1-8 23:45
太強了,謝謝樓主
