脈寬測量程序 HC-SRO4超聲波測距模塊1602顯示
thingkmore
2017-10-10 21:48
基于超聲波的1602顯示,用到了單片機的脈寬測量技術
//HC-SRO4 超聲波測距模塊 DEMO 程序
SMC1602A(16*2)模擬口線接線方式
連接線圖:
|LCM-----51 | LCM-----51 | LCM------51 |
|DB0-----P1.0 | DB4-----P1.4 | RW-------P3.4 |
|DB1-----P1.1 | DB5-----P1.5 | RS-------P3.3 |
|DB2-----P1.2 | DB6-----P1.6 | E--------P3.5 |
|DB3-----P1.3 | DB7-----P1.7 | VLCD接1K電阻到GND|
接線:模塊TRIG接 P2.6 ECH0 接P2.7
本程序源碼只供學習參考,不得應用于商業用途,如有需要請聯系作者。
[注:AT89x51使用12M或11.0592M晶振,實測使用11.0592M]
#include <AT89x51.H> //器件配置文件
#include <intrins.h>
#define RX P2_0
#define TX P2_1
#define LCM_RW P2_5 //定義LCD引腳
#define LCM_RS P2_6 //#define LCD1602_DATAPINS P0
//sbit LCD1602_E=P2^7;
//sbit LCD1602_RW=P2^5;
//sbit LCD1602_RS=P2^6;
#define LCM_E P2_7
#define LCM_Data P0
//#define Key_Data P2_0 //定義Keyboard引腳
//#define Key_CLK P3_2
#define Busy 0x80 //用于檢測LCM狀態字中的Busy標識
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
unsigned char code mcustudio[] ={"***2017.09.07***"};
unsigned char code email[] = {"***tangjiale****"};
unsigned char code Cls[] = {" "};
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','*','M'};
static unsigned char DisNum = 0; //顯示用指針
unsigned int time=0;
unsigned long S=0;
bit flag =0;
unsigned char disbuff[4] ={ 0,0,0,0,};
//寫數據
ReadStatusLCM(); //檢測忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在這后加小的延時
LCM_E = 0; //延時
LCM_E = 1;
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC) ReadStatusLCM(); //根據需要檢測忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//讀數據
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//讀狀態
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
WriteCommandLCM(0x08,1); //關閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標移動設置
WriteCommandLCM(0x0F,1); // 顯示開及光標設置
//按指定位置顯示一個字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
WriteCommandLCM(X, 1); //發命令字
WriteDataLCM(DData); //發數據
//按指定位置顯示一串字符
unsigned char ListLength;
ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到達字串尾則退出
if (X <= 0xF) //X坐標應小于0xF
DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
ListLength++;
X++;
//5ms延時
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延時
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.87)/100; //算出來是M
if((S>=700)||flag==1) //超出測量范圍顯示“*”
flag=0;
DisplayOneChar(0, 1, ASCII[11]);
DisplayOneChar(1, 1, ASCII[10]); //顯示點
DisplayOneChar(2, 1, ASCII[11]);
DisplayOneChar(3, 1, ASCII[11]);
DisplayOneChar(4, 1, ASCII[12]); //顯示M
disbuff[0]=S%1000/100;
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
DisplayOneChar(0, 1, ASCII[disbuff[0]]);
DisplayOneChar(2, 1, ASCII[disbuff[1]]);
DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 1 //T0中斷用來計數器溢出,超過測距范圍
flag=1; //中斷溢出標志
void StartModule() //啟動模塊
TX=1; //啟動一次模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
TX=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
void main(void)
unsigned char TempCyc;
Delay400Ms(); //啟動等待,等LCM講入工作狀態
LCMInit(); //LCM初始化
Delay5Ms(); //延時片刻(可不要)
DisplayListChar(0, 0, mcustudio);
DisplayListChar(0, 1, email);
ReadDataLCM();//測試用句無意義
for (TempCyc=0; TempCyc<10; TempCyc++)
Delay400Ms(); //延時
DisplayListChar(0, 1, Cls);
TMOD=0x01; //設T0為方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1; //允許T0中斷
EA=1; //開啟總中斷
StartModule();
// DisplayOneChar(0, 1, ASCII[0]);
while(!RX); //當RX為零時等待
TR0=1; //開啟計數
while(RX); //當RX為1計數并等待
TR0=0; //關閉計數
Conut(); //計算
delayms(80); //80MS
超聲波測距LC1602顯示.zip
(39.81 KB, 下載次數: 16)
2017-10-10 21:47 上傳
已經測試直接用
faridzled
2017-10-11 07:00
thanks for sharing
