標(biāo)題: OMGON繼電器G6S-2F-5V資料 [打印本頁]
作者: 夢小坤    時間: 2017-9-13 17:09
Suface Mount DPDT Relay
• High dielectric withstand voltage of 2,000 VAC between coil
and contacts (standard type); 1,500 VAC between contacts
of different polarity.
• Meets FCC Part 68 and Telcordia 2.5 kV surge withstand.
• European version certified for EN60950/EN41003 Supple-
mentary Insulation at 250 V at Pollution Degree 2.
• Low power consumption of 140 mW (Non-latching)
• Available in through-hole and SMT terminals.
• Tape and reel or tube packaging.
• RoHS Compliant.
歐姆龍繼電器資料
OMGON繼電器 G6S-2F-5V.pdf (765.13 KB, 下載次數(shù): 12)
