利用單片機(jī)定時(shí)器的時(shí)鐘顯示
要成為大神的神
時(shí)間:
2017-8-22 08:54
#include<reg52.h>
#include<intrins.h>
sbit wela=P2^7;
sbit dula=P2^6;
sbit s2=P3^0;
sbit s3=P3^1;
sbit s4=P3^2;
sbit s5=P3^3;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x40,0x40};
uint num,num1,num2,num3,flag=0;
void delay(uint z)
uint i,j;
for(i=z;i>0;i--)
for(j=110;j>0;j--);
void led()
delay(5);
P1=_crol_(P1,1);
void display(uint shi,fen,miao)
uint shi_s,shi_g,fen_s,fen_g,miao_s,miao_g;
shi_s=shi/10;
shi_g=shi%10;
fen_s=fen/10;
fen_g=fen%10;
miao_s=miao/10;
miao_g=miao%10;
dula=1;
P0=table[shi_s];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delay(2);
dula=1;
P0=table[shi_g];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delay(2);
dula=1;
P0=table[16];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delay(2);//橫杠
dula=1;
P0=table[fen_s];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delay(2);
dula=1;
P0=table[fen_g];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delay(2);
dula=1;
P0=table[16];
dula=0;
P0=0xff;
wela=1;
P0=0xfb;
wela=0;
delay(2);//橫杠
dula=1;
P0=table[miao_s];
dula=0;
P0=0xff;
wela=1;
P0=0xbf;
wela=0;
delay(2);
dula=1;
P0=table[miao_g];
dula=0;
P0=0xff;
wela=1;
P0=0x7f;
wela=0;
delay(2);
void keyscan()
if(s2==0)
delay(10);
if(s2==0)
while(!s2);
TR0=~TR0;
if(s3==0)
delay(10);
if(s3==0)
num2++;
if(num2==60)
num2=0;
while(!s3);
if(s4==0)
delay(10);
if(s4==0)
num3++;
if(num3==24)
num3=0;
while(!s4);
if(s5==0)
delay(10);
if(s5==0)
while(!s5);
flag=~flag;
void init()
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
TR0=0;
P1=0xfe;
init();
keyscan();
if(flag==1)
led();
display(num3,num2,num1);
void time0() interrupt 1
num++;
if(num==20)
num=0;
num1++;
if(num1==60)
num1=0;
num2++;
if(num2==60)
num2=0;
num3++;
if(num3==24)
num3=0;
