簡單的51單片機基于1602液晶的顯示
要成為大神的神
2017-8-22 08:49
簡單的51單片機基于1602液晶的顯示
#include<reg52.h>
sbit en=P3^4;
sbit rs=P3^5;
sbit rw=P3^6;
sbit s2=P3^0;
sbit s3=P3^1;
sbit s4=P3^2;
sbit s5=P3^3;
uchar shi,fen,miao,num,num1=0,num2=0,num3=0,flag;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void busy()
uchar busy;
P0=0xff;
rs=0;
rw=1;
do
en=1;
busy=P0;
en=0;
}while(busy & 0x80);//取最高位
void write_com(uchar com)
busy();
rs=0;
rw=0;
P0=com;
en=1;
en=0;
void write_date(uchar date)
busy();
rs=1;
rw=0;
P0=date;
en=1;
en=0;
void display(uchar num,weizhi)
uchar shi,ge;
shi=num/10;
ge=num%10;
write_com(0x80+0x03+weizhi);
write_date(0x30+shi);
write_date(0x30+ge);
void init()
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);//清屏
write_com(0x80|0x07);
write_date(':');
write_com(0x80|0x0a);
write_date(':');
display(0,2);
display(0,5);
display(0,8);
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
TR0=0;
void keyscan()
if(s5==0)
delay(10);
if(s5==0)
while(!s5);
TR0=~TR0;
if(s3==0)
delay(10);
if(s3==0)
num2++;
if(num2==60)
num2=0;
display(num2,5);
while(!s3);
if(s2==0)
delay(10);
if(s2==0)
num3++;
if(num3==24)
num3=0;
display(num3,2);
while(!s2);
init();
keyscan();
void time0() interrupt 1
num++;
if(num==20)
num=0;
num1++;
display(num1,8);
if(num1==60)
num1=0;
num2++;
if(num2==60)
num2=0;
num3++;
if(num3==24)
num3=0;
display(num3,2);
display(num2,5);
