標(biāo)題: 自己寫的指紋門禁的通信 stm32源碼 [打印本頁]
作者: 在路上111    時間: 2017-8-5 14:28
  1. #include "stm32f10x.h"
  2. #include "zhiwen.h"
  3. #include "string.h"
  4. #include "stdio.h"
  5. //感覺問題出現(xiàn)在串口接收數(shù)據(jù)上
  6. unsigned char Start[5]={"start"};
  7. unsigned char Clearn[5]={"clear"};
  8. unsigned char Ceshi[12]={0xEF,0X01,0XFF,0XFF,0XFF,0XFF,0X01,0X00,0X03,0X03,0X00,0X07};
  9. unsigned char PASS_WORD[5]={"check"};
  10. unsigned char DELETE[6]={"delete"};
  11. int mi(unsigned char dat, unsigned char num)
  12. {
  13.   unsigned char i;
  14.   int sum = 1;
  15.   for(i=0; i<num; i++)
  16.   {
  17.     sum = sum * dat;
  18.   }
  19.   return sum;
  20. }
  21. int main(void)
  22. {
  23.         int i,tmp,result;
  24.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  25.         Usart_Init();
  26.         while(1)
  27.         {
  28.                 if(Computure_Flag==1)
  29.                 {
  30.                         Computure_Flag=0;
  31.                         if(StringCompare(Start,ComputureCommand,5)==1)
  32.                         {
  33.                                 Enter_FingerPrint();//錄入指紋
  34.                         }
  35.                         else if(StringCompare(Clearn,ComputureCommand,5)==1)
  36.                                 ClearAll_Finger();
  37.                         else if(StringCompare(PASS_WORD,ComputureCommand,5)==1)
  38.                                 Check_PassWord();
  39.                         else if(StringCompare(DELETE,ComputureCommand,6)==1)
  40.                         {
  41.
  42.                                 for(i=6;i<Length2;i++)
  43.                                 {
  44.             tmp = ComputureCommand[i]&0x0f;         //如果原數(shù)組中存放的是ascii碼,直接將其轉(zhuǎn)換為數(shù)字
  45.             result+=tmp*mi(10,Length2-i-1); //1*100+2*10+3*1
  46.                           }
  47.                                 Delete_One_Finger(result);
  48.                         }
  49.                         ClearAll(ComputureCommand,Length2);
  50.                 }
  51.     Match_Finger();
  52.         }
  53. }
門禁.rar (377.7 KB, 下載次數(shù): 68)
