標題: 關于C語言定時器重載值修正的問題 [打印本頁]
作者: 星際漫游者 時間: 2017-7-24 10:28
只是一個PWM控制LED燈的小程序。我對于C語言的定時器修正值判斷不清楚,這里的修正值13,
不知道從哪里開始數機械周期的
#include <reg52.h>
sbit PWMOUT = P0^0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char HReloadH = 0; //高電平重載值的高字節
unsigned char HReloadL = 0; //高電平重載值的低字節
unsigned char LReloadH = 0; //低電平重載值的高字節
unsigned char LReloadL = 0; //低電平重載值的低字節
void ConfigPWM(unsigned int fr, unsigned char dc);
void ClosePWM();
void main ()
unsigned int i;
P0 = 0xFF; //P0口初始化
ADDR0 = 0; //選擇獨立LED
ADDR1 = 1;
ADDR2 = 1;
ADDR3 = 1;
ENLED = 0; //LED總使能
EA = 1; //開總中斷
ConfigPWM(100, 10); //頻率100Hz,占空比10%
for (i=0; i<40000; i++);
ClosePWM();
ConfigPWM(100, 40); //頻率100Hz,占空比40%
ClosePWM();
ConfigPWM(100, 90); //頻率100Hz,占空比90%
ClosePWM();
void ConfigPWM(unsigned int fr, unsigned char dc) //PWM配置函數,fr-頻率,dc-占空比
unsigned int high, low;
unsigned long tmp;
tmp = (11059200 / 12) / fr; //計算一個周期所需的計數值
high = (tmp * dc) / 100; //計算高電平所需的計數值
low = tmp - high; //計算低電平所需的計數值
high = 65536 - high + 13; //計算高電平的定時器重載值并修正
low = 65536 - low + 13; //計算低電平的定時器重載值并修正
HReloadH = (unsigned char)(high >> 8); //高電平重載值拆分為高低字節
HReloadL = (unsigned char)high;
LReloadH = (unsigned char)(low >> 8); //低電平重載值拆分為高低字節
LReloadL = (unsigned char)low;
TMOD &= 0xF0; //清零T0的控制位
TMOD |= 0x01; //配置T0為模式1
TH0 = HReloadH; //加載T0重載值
TL0 = HReloadL;
ET0 = 1; //使能T0中斷
TR0 = 1; //啟動T0
PWMOUT = 1; //輸出高電平
void ClosePWM() //關閉PWM
TR0 = 0; //停止定時器
ET0 = 0;
PWMOUT = 1; //輸出高電平
void InterruptTimer0() interrupt 1 //T0中斷服務函數
if (PWMOUT == 1) //當前輸出為高電平時,裝載低電平值并輸出低電平
TH0 = LReloadH;
TL0 = LReloadL;
PWMOUT = 0;
else //當前輸出為低電平時,裝載高電平值并輸出高電平
TH0 = HReloadH;
TL0 = HReloadL;
PWMOUT = 1;
作者: 星際漫游者 時間: 2017-7-25 10:05
我能說我打錯字了嗎 “這是控制LED燈的程序”
