標題: 基于Arduino的LCD1602顯示實驗 [打印本頁]
作者: 遇見之影    時間: 2017-7-20 20:07
int LCD1602_RS=12;
int LCD1602_RW=11;
int LCD1602_EN=10;
int DB[] = { 6, 7, 8, 9};
char str1[]="Welcome to";
char str2[]="geek-workshop";
char str3[]="this is the";
char str4[]="4-bit interface";
void LCD_Command_Write(int command)
int i,temp;
digitalWrite( LCD1602_RS,LOW);
digitalWrite( LCD1602_RW,LOW);
digitalWrite( LCD1602_EN,LOW);
temp=command & 0xf0;
for (i=DB[0]; i <= 9; i++)
   digitalWrite(i,temp & 0x80);
   temp <<= 1;
digitalWrite( LCD1602_EN,HIGH);
delayMicroseconds(1);
temp=(command & 0x0f)<<4;
   temp <<= 1;
void LCD_Data_Write(int dat)
int i=0,temp;
digitalWrite( LCD1602_RS,HIGH);
temp=dat & 0xf0;
   temp <<= 1;
temp=(dat & 0x0f)<<4;
   temp <<= 1;
void LCD_SET_XY( int x, int y )
  int address;
  if (y ==0)    address = 0x80 + x;
  else          address = 0xC0 + x;
  LCD_Command_Write(address);
void LCD_Write_Char( int x,int y,int dat)
  LCD_SET_XY( x, y );
  LCD_Data_Write(dat);
void LCD_Write_String(int X,int Y,char *s)
    LCD_SET_XY( X, Y );    //設置地址
    while (*s)             //寫字符串
      LCD_Data_Write(*s);
      s ++;
void setup (void)
  int i = 0;
  for (i=6; i <= 12; i++)
     pinMode(i,OUTPUT);
  delay(100);
  LCD_Command_Write(0x28);//4線 2行 5x7
  delay(50);
  LCD_Command_Write(0x06);
  delay(50);
  LCD_Command_Write(0x0c);
  delay(50);
  LCD_Command_Write(0x80);
  delay(50);
  LCD_Command_Write(0x01);
  delay(50);
void loop (void)
   delay(50);
   LCD_Write_String(3,0,str1);//第1行,第4個地址起
   delay(50);
   LCD_Write_String(1,1,str2);//第2行,第2個地址起
   delay(5000);
   delay(50);
   LCD_Write_String(0,0,str3);
   delay(50);
   LCD_Write_String(0,1,str4);
   delay(5000);
_1602.rar
860 Bytes, 下載次數: 18, 下載積分: 黑幣 -5
作者: LSLilei    時間: 2017-7-22 15:36
樓主不上個接線圖嗎
作者: 遇見之影    時間: 2017-7-24 21:29
接線圖在附件中
作者: wfm7777    時間: 2017-8-31 17:52
好東西,學習一下
