標(biāo)題: MSP430單片機(jī)用12864液晶繪制DS18B20溫度曲線(xiàn)源代碼 [打印本頁(yè)]
作者: 我不是我    時(shí)間: 2017-7-11 19:16
MSP430單片機(jī)用12864液晶繪制DS18B20溫度曲線(xiàn)源代碼,keil4文件
單片機(jī)源程序如下:
  1. #include <msp430x14x.h>
  2. #include "Lcd12864.h"
  3. #include "DS18B20.h"
  4. #include "bmp.h"
  5. #define CPU_F ((double)8000000)
  6. #define delayus(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
  7. #define delayms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
  8. #define uchar unsigned char
  9. #define uint unsigned int
  10. //=========================================
  11. //函數(shù)功能:初始化時(shí)鐘
  12. //=========================================
  13. void Init_CLK()
  14. {
  15.         unsigned int i;
  16.         WDTCTL = WDTPW + WDTHOLD;         //停止看門(mén)狗
  17.         BCSCTL1 &= ~XT2OFF;                         //打開(kāi)XT2振蕩器
  18.         do
  19.         {
  20.                 IFG1 &= ~OFIFG;                         //清除振蕩器失效標(biāo)志
  21.                 for(i = 0xff;i > 0;i--); //延時(shí),等待XT2起振
  22.         }
  23.         while((IFG1 & OFIFG) != 0);  //直到震蕩失效標(biāo)志不存在
  24.         BCSCTL2 = SELM_2 + SELS;           //選擇MCLK、SMCLK為XT2
  25. }
  26. //=========================================
  27. //函數(shù)功能:主函數(shù)
  28. //=========================================
  29. void main()
  30. {
  31.         uchar table[6];
  32.     uint temp,XPonit,YPoint;
  33.         float Point;
  34.         Init_CLK();
  35.           InitLcd12864();
  36.         Init_DS18B20();
  37.         FillGdram(0x00);
  38.         DisplayBMP(bmp);
  39.     while(1)
  40.     {
  41.                 for(XPonit=8;XPonit<=127;XPonit++)
  42.                 {
  43.                         temp = Get_Temp();
  44.                         delayms(100);
  45.                         table[0] = temp / 100 + '0';
  46.                         table[1] = temp % 100 / 10 + '0';
  47.                         table[2] = '.';
  48.                         table[3] = temp % 10 + '0';
  49.                         table[4] = 'C';
  50.                         table[5] = '\0';
  51.                         DisplayString(1,6,table);                  //顯示第一行,從第1個(gè)位置開(kāi)始
  52.                         Point = (float)temp / 10 + 0.5;
  53.                         YPoint = 63 - ((int)Point + 7);
  54.                         DrawPoint(XPonit,YPoint,1);
  55.                 }
  56.                 if(XPonit == 128)
  57.                 {
  58.                         XPonit = 8;
  59.                         FillGdram(0x00);
  60.                         DisplayBMP(bmp);
  61.                 }
  62.     }
  63.         /*
  64.     //DrawPoint(7,7,1); // 畫(huà)點(diǎn)(7,7)
  65.          // 8 x 8 表格程序段開(kāi)始
  66.
  67.           DrawHorizontalLine(0,127,0,1);
  68.
  69.
  70.           DrawHorizontalLine(0,127,15,1);
  71.           DrawHorizontalLine(0,127,23,1);
  72.           DrawHorizontalLine(0,127,31,1);
  73.           DrawHorizontalLine(0,127,39,1);
  74.           DrawHorizontalLine(0,127,47,1);
  75.           DrawHorizontalLine(0,127,55,1);
  76.           DrawHorizontalLine(0,127,63,1);
  77.           DrawVerticalLine(0,0,63,1);
  78.           DrawVerticalLine(15,0,63,1);
  79.           DrawVerticalLine(31,0,63,1);
  80.           DrawVerticalLine(47,0,63,1);
  81.           DrawVerticalLine(63,0,63,1);
  82.           DrawVerticalLine(79,0,63,1);
  83.           DrawVerticalLine(95,0,63,1);
  84.           DrawVerticalLine(111,0,63,1);
  85. ……………………
  86. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
MSP430單片機(jī)用12864液晶繪制DS18B20溫度曲線(xiàn)源代碼.rar (62.2 KB, 下載次數(shù): 32)
