標(biāo)題: VL53L0X引腳圖 應(yīng)用電路圖與管腳功能等pdf參考資料下載 [打印本頁(yè)]
作者: 電子愛(ài)好者11    時(shí)間: 2017-7-9 20:45
給大家分享一些關(guān)于VL53L0X芯片的參考資料:
VL53L0X方框圖:
VL53L0X引腳圖:
VL53L0X管腳功能介紹:
VL53L0X的典型應(yīng)用電路:
World smallest Time-of-Flight ranging and gesture detection sensor
Features
• Fully integrated miniature module
– 940nm Laser VCSEL
– VCSEL driver
– Ranging sensor with advanced embedded micro controller
– 4.4 x 2.4 x 1.0mm
• Fast, accurate distance ranging
– Measures absolute range up to 2m
– Reported range is independent of the
target reflectance
– Operates in high infrared ambient light levels
– Advanced embedded optical cross-talk compensation to simplify cover glass selection
• Eye safe
– Class 1 laser device compliant with latest standard IEC 60825-1:2014 - 3rd edition
• Easy integration
– Single reflowable component
– No additional optics
– Single power supply
– I2C interface for device control and data transfer
– Xshutdown (Reset) and interrupt GPIO
– Programmable I2C address
完整的pdf格式文檔51黑下載地址:
VL53L0X.pdf (917.68 KB, 下載次數(shù): 57)
作者: admin    時(shí)間: 2017-7-9 22:02
好資料,51黑有你更精彩!!!
作者: POSIT    時(shí)間: 2018-2-13 12:49
謝謝大神分享下
作者: 2275488627    時(shí)間: 2019-4-9 19:56
謝謝分享
