MAX111數(shù)字萬(wàn)用表單片機(jī)源程序 12864顯示
[打印本頁(yè)]
狗go狗
時(shí)間:
2017-7-4 18:09
用12864液晶屏來(lái)顯示的單片機(jī)數(shù)字萬(wàn)用表制作資料,菜單顯示處理很經(jīng)典:
(62.49 KB, 下載次數(shù): 79)
2017-7-4 21:48 上傳
單片機(jī)源程序如下:
控制說(shuō)明:
電阻測(cè)量: 10: send0(0x80); 100: send0(0x81);
1K: send0(0x82); 10K: send0(0x83);
100K: send0(0x84); 1M: send0(0x85);
10M: send0(0x86);
直流電壓測(cè)量:100MV: send1(0x04);
10V: send1(0x08);
100V: send1(0x10);
10KV: send1(0x20);
交流電壓測(cè)量:100MV: send1(0x06);
10V: send1(0x0a);
100V: send1(0x12);
10KV: send1(0x22);
直流電流測(cè)量: 1MA: send2(0x02);
10MA: send2(0x04);
100MA: send2(0x08);
10A: send2(0x10);
交流電流測(cè)量: 1MA: send2(0x03);
10MA: send2(0x05);
100MA: send2(0x09);
10A: send2(0x11);
注:初始化時(shí)要全部處于非工作狀態(tài)<send0(0x08) send1(0x00) send2(0x00)>使用時(shí)選擇相應(yīng)指令,返回時(shí)關(guān)斷.
#include <reg52.h>
#include <stdio.h>
#include <intrins.h>
#include <string.h>
#include <math.h>
#include "ziku.h" //字庫(kù)
sbit key_up = P3^2; //光標(biāo)上移按鍵
sbit key_down = P3^3; //光標(biāo)下移按鍵
sbit key_ok = P3^4; //確定按鍵
sbit key_back = P3^5; //退出按鍵
sbit ZLDL = P3^0; //
/*** 利用二維數(shù)組存放字模 ***/
unsigned char code arrayadress0[][4];
unsigned char code arrayadress1[][12];
unsigned char code arrayadress2[][16];
unsigned char code arrayadress3[][8];
unsigned char code arrayadress4[][4];
unsigned char code arrayadress5[][8];
unsigned char code arrayadress6[][16];
unsigned char code arrayadress7[][12];
/***** 函數(shù)聲明 *****/
extern void InitLCD(); //液晶初始化函數(shù)
extern void delay1ms(unsigned char x); //延時(shí)1ms函數(shù)
extern void delay10ms(unsigned char x); //延時(shí)10ms函數(shù)
extern void biaoge(); //畫表格函數(shù)
extern void Clrscreen(unsigned char m); //送指定數(shù)據(jù)函數(shù)
extern double duqudata0(unsigned char i); //采集數(shù)據(jù)函數(shù)
extern double duqudata1_1(unsigned char i); //采集數(shù)據(jù)函數(shù)
extern double duqudata1_2(unsigned char i); //采集數(shù)據(jù)函數(shù)
extern double duqudata1_3(unsigned char i); //采集數(shù)據(jù)函數(shù)
extern double duqudata2(unsigned char i); //采集數(shù)據(jù)函數(shù)
extern double duqudata3(unsigned char i); //采集數(shù)據(jù)函數(shù)
extern void send0(unsigned char abc); //串口發(fā)送子函數(shù)(控制電阻檔)
extern void send1(unsigned char abc); //模擬串口發(fā)送子函數(shù)(控制電壓檔)
extern void send2(unsigned char abc); //模擬串口發(fā)送子函數(shù)(控制電壓檔)
extern void Clrscreen_ge(unsigned char dat,unsigned char layer,unsigned char column,unsigned char whidth); //送固定數(shù)據(jù)\畫表格
extern void Clrscreen_data(unsigned char dat,unsigned char layer,unsigned char column,unsigned char whidth); //送固定數(shù)據(jù)函數(shù)
extern void display_GD(unsigned char layer,unsigned char column,unsigned char whidth,unsigned char daxiao,signed char KY,signed char HY,unsigned char *china_code); //移動(dòng)顯示函數(shù)
extern void display(unsigned char layer,unsigned char column,unsigned char whidth,unsigned char daxiao,unsigned char *china_code); //隨意顯示函數(shù)
extern void display_LM(unsigned char layer,unsigned char column,unsigned char whidth,unsigned char daxiao,unsigned char *china_code); //拉幕顯示
extern void QU_ASCII(unsigned char layer,unsigned char column,unsigned char whidth,unsigned char daxiao,unsigned char *china_code); //動(dòng)態(tài)數(shù)字顯示
void InitJDQ(); //初始化繼電器
void display_start(); //開屏顯示內(nèi)容
void display_RES(); //進(jìn)入電阻檔顯示界面
void display_VOL(); //進(jìn)入電壓檔顯示界面
void display_GAL(); //進(jìn)入電流檔顯示界面
void display_figure(unsigned char i); //采集處理的數(shù)字顯示
void display_dat(); //采集數(shù)據(jù)處理顯示
/**** 全局變量定義 ****/
unsigned char k;
unsigned char Z,Z0,Z1,Z2;
double number,numb,N=0,Y;
void InitJDQ() //初始化繼電器
void InitJDQ()
send0(0x08);
send1(0x00);
send2(0x00);
ZLDL=0;
void display_start() //開屏顯示內(nèi)容
Clrscreen(0x00);
display(0,0,4,12,arrayadress1[0]); //電阻測(cè)量
display(2,0,4,12,arrayadress1[8]); //短路檢測(cè)
display(4,0,6,12,arrayadress1[16]); //直流電壓測(cè)量
display(6,0,6,12,arrayadress1[28]); //交流電壓測(cè)量
display(0,56,6,12,arrayadress1[40]); //直流電流測(cè)量
display(2,56,6,12,arrayadress1[52]); //交流電流測(cè)量
display(4,80,4,12,arrayadress1[64]); //頻率測(cè)量
void display_RES() //進(jìn)入電阻檔顯示界面
void display_RES()
Clrscreen(0x00);
display(0,0,6,12,arrayadress7[0]); //請(qǐng)選擇檔位:
display(6,32,8,12,arrayadress7[12]); //選擇后請(qǐng)按確認(rèn)鍵
display(2,6,2,8,arrayadress3[12]); //10
display(2,34,3,8,arrayadress3[16]); //100
QU_ASCII(2,70,1,8,"1");
display(2,78,1,8,arrayadress3[10]); //1K
display(2,98,2,8,arrayadress3[12]);
display(2,114,1,8,arrayadress3[10]); //10K
display(4,6,3,8,arrayadress3[16]);
display(4,30,1,8,arrayadress3[10]); //100K
QU_ASCII(4,60,1,8,"1");
display(4,68,1,8,arrayadress3[6]); //1M
display(4,98,2,8,arrayadress3[12]);
display(4,114,1,8,arrayadress3[6]); //10M
void display_VOL() //進(jìn)入電壓檔顯示界面
void display_VOL()
Clrscreen(0x00);
display(2,22,3,8,arrayadress3[16]);
display(2,46,1,8,arrayadress3[6]);
display(2,54,1,8,arrayadress3[0]); //100MV
display(2,82,2,8,arrayadress3[12]);
display(2,98,1,8,arrayadress3[0]); //10V
display(4,22,3,8,arrayadress3[16]);
display(4,46,1,8,arrayadress3[0]); //100V
QU_ASCII(4,82,1,8,"1");
display(4,90,1,8,arrayadress3[10]);
display(4,98,1,8,arrayadress3[0]); //1KV
void display_GAL() //進(jìn)入電流檔顯示界面
void display_GAL()
Clrscreen(0x00);
QU_ASCII(2,22,1,8,"1");
display(2,32,2,8,arrayadress3[6]); //1MA
display(2,74,2,8,arrayadress3[12]);
display(2,92,2,8,arrayadress3[6]); //10MA
display(4,48,2,8,arrayadress3[6]); //100MA
display(4,82,2,8,arrayadress3[12]);
display(4,100,1,8,arrayadress3[8]); //10A
void display_figure() //采集處理數(shù)字顯示
switch(i)
case 1: QU_ASCII(3,k,1,8,"1"); break;
case 2: QU_ASCII(3,k,1,8,"2"); break;
case 3: QU_ASCII(3,k,1,8,"3"); break;
case 4: QU_ASCII(3,k,1,8,"4"); break;
case 5: QU_ASCII(3,k,1,8,"5"); break;
case 6: QU_ASCII(3,k,1,8,"6"); break;
case 7: QU_ASCII(3,k,1,8,"7"); break;
case 8: QU_ASCII(3,k,1,8,"8"); break;
case 9: QU_ASCII(3,k,1,8,"9"); break;
default: QU_ASCII(3,k,1,8,"0");
void display_dat() //采集數(shù)據(jù)處理顯示
void display_dat()
unsigned char j;
j=number;
if(j/100) //判斷最高位是否為十位
k=32; //全局變量K(顯示起始列)的賦值
Z0=number/100; //取十位上的數(shù)值
display_figure(Z0); //顯示數(shù)據(jù)(switch...case)
number=number-Z0*100; //減掉十位數(shù)據(jù)
k+=8;
Z0=number/10; //取十位上的數(shù)值
number=number-Z0*10; //減掉十位數(shù)據(jù)
k+=8; //列地址加八
Z0=number/1; //取個(gè)位數(shù)值
display(3,56,1,4,arrayadress0[0]); //小數(shù)點(diǎn)顯示
number=number-Z0*1; //減掉個(gè)位數(shù)據(jù)
k+=12;
Z0=number/0.1; //取小數(shù)點(diǎn)后第一位的數(shù)值
display_figure(Z0);
number=number-Z0*0.1;
k+=8;
Z0=number/0.01; //取小數(shù)點(diǎn)后第二位的數(shù)值
display_figure(Z0);
number=number-Z0*0.01;
k+=8;
Z0=number/0.001; //取小數(shù)點(diǎn)后第三位的數(shù)值;
display_figure(Z0);
else if(j/10) //判斷最高位是否為十位
Clrscreen_data(0x00,3,32,8);
k=40; //全局變量K(顯示起始列)的賦值
k+=8; //列地址加八
k+=12;
display_figure(Z0);
k+=8;
display_figure(Z0);
k+=8;
display_figure(Z0);
else if(j/1) //判斷最高位是否為個(gè)位
Clrscreen_data(0x00,3,40,8);
k=48;
Z1=number/1;
display_figure(Z1); //顯示數(shù)據(jù)(switch...case)
number=number-Z1*1;
k+=12;
Z1=number/0.1;
display_figure(Z1);
number=number-Z1*0.1;
k+=8;
Z1=number/0.01;
display_figure(Z1);
number=number-Z1*0.01;
k+=8;
Z1=number/0.001;
display_figure(Z1);
else //顯示小于1的數(shù)
QU_ASCII(3,48,1,8,"0");
k=60;
Z2=number/0.1;
display_figure(Z2);
number=number-Z2*0.1;
k+=8;
Z2=number/0.01;
display_figure(Z2);
number=number-Z2*0.01;
k+=8;
Z2=number/0.001;
display_figure(Z2);
signed char i,j;
InitLCD();
Clrscreen(0x00); //清屏
InitJDQ(); //繼電器初始化
do
// W_G();
for(i=96,j=0;i>=0,j<64;i--,j++)
display_GD(1,i,j,16,96,0,arrayadress2[0]); //水平滾動(dòng) 歡迎使用
delay1ms(50);
display_LM(3,23,80,16,arrayadress2[8]); //拉幕 數(shù)字萬(wàn)用表
delay10ms(200);
/**************************************************************************************************電阻測(cè)量/
start_1:
display_start(); //主屏顯示
start_1_0:
do
// W_G();
Clrscreen_data(0xff,0,0,48); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
}while(key_up==1&key_down==1&key_ok==1); //按鍵判斷
if(key_up==0) goto start_7_0; //光標(biāo)上移
else if(key_down==0) goto start_2_0; //光標(biāo)下移
else if(key_ok==0) //確認(rèn)
RES:
display_RES();
RES_10:
do
Clrscreen_data(0x00,2,4,20); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
}while(key_up==1&key_down==1&key_ok==1&key_back); //按鍵判斷
if(key_up==0) goto RES_10M_0; //光標(biāo)上移
else if(key_down==0) goto RES_100_0; //光標(biāo)下移
display(1,6,5,16,arrayadress4[0]); //當(dāng)前阻值
display(3,92,1,16,arrayadress6[0]); //Ω
biaoge();
send0(0x80); //相應(yīng)繼電器控制選擇檔位
do
for(i=0;i<5;i++) //MAX111采集5次
number=duqudata0(1);
N=N+number;
number=N/5; //求5次采集的平均值
N=0;
number=(40*number)/(0.65-number);
display_dat(); //對(duì)采集數(shù)據(jù)的處理顯示
}while(key_back==1);
send0(0x08); //關(guān)繼電器
goto RES;
else goto start_1;
RES_100:
display_RES();
RES_100_0:
do
Clrscreen_data(0x00,2,32,28); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto RES_10; //光標(biāo)上移
else if(key_down==0) goto RES_1K_0; //光標(biāo)下移
biaoge();
send0(0x81); //相應(yīng)繼電器控制選擇檔位
do
N=N+number;
N=0;
number=(400*number)/(3.21-number);
goto RES_100;
else goto start_1;
RES_1K:
display_RES();
RES_1K_0:
do
Clrscreen_data(0x00,2,68,20); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto RES_100_0; //光標(biāo)上移
else if(key_down==0) goto RES_10K_0; //光標(biāo)下移
display(3,92,1,8,arrayadress3[10]); //K
display(3,100,1,16,arrayadress6[0]); //Ω
biaoge();
send0(0x82); //相應(yīng)繼電器控制選擇檔位
do
N=N+number;
N=0;
number=(4*number)/(4.27-number); //1K
goto RES_1K;
else goto start_1;
RES_10K:
display_RES();
RES_10K_0:
do
Clrscreen_data(0x00,2,96,28); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto RES_1K_0; //光標(biāo)上移
else if(key_down==0) goto RES_100K_0; //光標(biāo)下移
biaoge();
send0(0x83); //相應(yīng)繼電器控制選擇檔位
do
N=N+number;
N=0;
number=(40*number)/(4.5-number);
goto RES_10K;
else goto start_1;
RES_100K:
display_RES();
RES_100K_0:
do
Clrscreen_data(0x00,4,4,36); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto RES_10K_0; //光標(biāo)上移
else if(key_down==0) goto RES_1M_0; //光標(biāo)下移
biaoge();
send0(0x84); //相應(yīng)繼電器控制選擇檔位
do
N=N+number;
N=0;
number=(400*number)/(4.67-number);
goto RES_100K;
else goto start_1;
RES_1M:
display_RES();
RES_1M_0:
do
Clrscreen_data(0x00,4,58,20); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto RES_100K_0; //光標(biāo)上移
else if(key_down==0) goto RES_10M_0; //光標(biāo)下移
display(3,92,1,8,arrayadress3[6]); //M
biaoge();
send0(0x85); //相應(yīng)繼電器控制選擇檔位
do
N=N+number;
N=0;
number=(4*number)/(4.82-number);
goto RES_1M;
else goto start_1;
RES_10M:
display_RES();
RES_10M_0:
do
Clrscreen_data(0x00,4,96,28); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto RES_1M_0; //光標(biāo)上移
else if(key_down==0) goto RES_10; //光標(biāo)下移
biaoge();
send0(0x86); //相應(yīng)繼電器控制選擇檔位
do
N=N+number;
N=0;
number=(40*number)/(5.55-number);
goto RES_10M;
else goto start_1;
/**************************************************************************************************短路檢測(cè)/
start_2:
display_start();
start_2_0:
do
// W_G();
Clrscreen_data(0xff,2,0,48); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto start_1_0; //光標(biāo)上移
else if(key_down==0) goto start_3_0; //光標(biāo)下移
display(1,6,5,16,arrayadress4[40]); //線路狀態(tài)
biaoge();
do
R_10:
do
send0(0x80);
numb=duqudata3(1);
if(numb<1)
send0(0xc0); //蜂鳴器響
number=(40*numb)/(0.65-numb);
display_dat();
Clrscreen_data(0x00,3,109,18);
else goto R_100;
}while(numb<1&key_back==1);
send0(0x00); //關(guān)繼電器
goto start_2;
R_100:
do
send0(0x81);
numb=duqudata3(1);
if(numb<1)
if(numb<0.5) goto R_10;
send0(0xc1); //蜂鳴器響
number=(400*numb)/(3.21-numb);
display_dat();
else goto R_1K;
goto start_2;
R_1K:
do
send0(0x82);
numb=duqudata3(1);
if(numb<1)
if(numb<0.5) goto R_100;
number=(4*numb)/(4.27-numb);
display_dat();
else goto R_10K;
goto start_2;
R_10K:
do
send0(0x83);
numb=duqudata3(1);
if(numb<1)
if(numb<0.5) goto R_1K;
number=(40*numb)/(4.5-numb);
display_dat();
else goto R_100K;
goto start_2;
R_100K:
do
send0(0x84);
numb=duqudata3(1);
if(numb<1)
if(numb<0.5) goto R_10K;
number=(400*numb)/(4.67-numb);
display_dat();
else goto R_1M;
goto start_2;
R_1M:
do
send0(0x85);
numb=duqudata3(1);
if(numb<1)
if(numb<0.5) goto R_100K;
number=(4*numb)/(4.82-numb);
display_dat();
else goto R_10M;
goto start_2;
R_10M:
do
send0(0x86);
numb=duqudata3(1);
if(numb<1)
if(numb<0.5) goto R_1M;
number=(40*numb)/(5.55-numb);
display_dat();
Clrscreen_data(0x00,3,30,18);
QU_ASCII(3,60,1,8,"0");
QU_ASCII(3,68,1,8,"0");
QU_ASCII(3,76,1,8,"0");
Clrscreen_data(0x00,3,84,42);
goto start_2;
/**********************************************************************************************直流電壓測(cè)量/
start_3:
display_start();
start_3_0:
do
// W_G();
Clrscreen_data(0xff,4,0,72); //光標(biāo)閃動(dòng)
delay10ms(43);
delay10ms(100);
if(key_up==0) goto start_2_0; //光標(biāo)上移
else if(key_down==0) goto start_4_0; //光標(biāo)下移
VOL:
display_VOL();
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
(數(shù)字萬(wàn)用表)程序.zip
(169.93 KB, 下載次數(shù): 57)
2017-7-4 18:08 上傳
點(diǎn)擊文件名下載附件
程序詳細(xì)
hai2599
時(shí)間:
2017-7-7 06:18
不知道準(zhǔn)確度怎么樣。。
xymiss
時(shí)間:
2017-7-21 00:52
這個(gè)牛逼了。。得下玩玩
YQS
時(shí)間:
2017-7-21 09:59
樓主,沒有電路圖,原理圖難仿哦!
DANP
時(shí)間:
2019-8-8 09:56
有原理圖嗎
yyzf998
時(shí)間:
2020-4-24 23:37
樓主,能分享一下原理圖就非常完美了!不過(guò)還是要感謝您的!謝謝!
wsh791
時(shí)間:
2020-4-25 07:25
謝謝分享
龍小白
時(shí)間:
2022-9-16 08:50
下載了看看能用不
