基于STM32103和ds18b20的測溫 5110屏幕顯示
51H_NiHao
時(shí)間:
2017-6-23 14:17
顯示為洛基亞5110
單片機(jī)源程序如下:
#include "delay.h"
#include "LCD5110.h"
#include "ds18b20.h"
#include "sys.h"
#include "timer.h"
#include "exti.h"
// vu8 i = 0;
u8 str[20];
s16 temperature ; //溫度
int main(void)
RCC_Configuration(); //系統(tǒng)時(shí)鐘配置
GPIO_Configuration();
delay_init() ;
NVIC_Configuration(); //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
TIM3_Int_Init(4999,7199);//10Khz的計(jì)數(shù)頻率,計(jì)數(shù)到5000為500ms
// 配置外部中斷
KEY_Init();
EXTIX_Init();
SPI2_Config();
DMA_SPI_Config();
LCD_CLK_H();
LCD_VCC_H();
LCD_GND_L();
LCD_BGL_L(); //背光燈開啟
delay_ms(10); //等待
LCD_Init(); //初始化液晶
LCD_Clear(); //清屏
while(DS18B20_Init()) //DS18B20初始化
LCD_Write_EnStr(0,0,"DS18B20 Error");
LCD_Write_EnStr(2,2,"DS18B20 OK");
delay_ms(1000);
delay_ms(1000);
LCD_Write_EnStr(0,0,"*************");
LCD_Write_EnStr(0,1," The current ");
LCD_Write_EnStr(0,2," temperature");
LCD_Write_EnStr(6,3,"is");
LCD_Write_EnStr(0,5,"*************");
if(temperature<0)
LCD_Write_EnStr(2,4,"-"); //顯示負(fù)號
temperature=-temperature; //轉(zhuǎn)為正數(shù)
}else LCD_Write_EnStr(0,4," "); //去掉負(fù)號
LCD_Write_EnStr(4,4,str);
//定時(shí)器3中斷服務(wù)程序
//每500ms讀取一次溫度
void TIM3_IRQHandler(void) //TIM3中斷
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //檢查TIM3更新中斷發(fā)生與否
temperature = DS18B20_Get_Temp(); //讀取溫度
num_to_str( temperature,str); //將溫度轉(zhuǎn)換為ASC值
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //清除TIMx更新中斷標(biāo)志
void EXTI3_IRQHandler(void)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
測溫.rar
(308.57 KB, 下載次數(shù): 77)
2017-6-24 23:09 上傳
點(diǎn)擊文件名下載附件
ubuntu321
時(shí)間:
2018-2-14 10:54
感謝分享,模仿你的作品
