【求助】51單片機(jī)電子琴,1-7按鍵播放音符,8按鍵自動(dòng)播放音樂(lè)
[打印本頁(yè)]
無(wú)所謂shine
時(shí)間:
2017-6-22 09:33
學(xué)校實(shí)訓(xùn),要求51實(shí)現(xiàn)電子琴,要求如題。
數(shù)碼管為共陰數(shù)碼管,但多了595芯片
程序借鑒了一部分網(wǎng)上內(nèi)容,目前可以實(shí)現(xiàn)1-7的發(fā)音和數(shù)碼管顯示,但按8按鍵卻蜂鳴器長(zhǎng)鳴,不知道什么地方出錯(cuò)
希望各位大神幫忙看下
#include <reg51.h>
sbit BeepIO =P1^7;
sbit DI1 =P1^0;
sbit DI2 =P1^1;
sbit DI3 =P1^2;
sbit DI4 =P1^3;
sbit DIO =P1^4;
sbit RCK =P1^5;
sbit SCLK =P1^6;
uint tune[]={0xfc44,0xfcac,0xfd09,0xfd34,0xfd82,0xfdc8,0xfe07};
uchar code num[]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,
0x00,0xff
//void KeyProc(uchar dat);
uchar SoundTH;
uchar SoundTL;
unsigned char Time;
unsigned char High,Low; //定時(shí)器預(yù)裝值的高8位和低8位
// 音階頻率表 高八位
unsigned char code FREQH[]={
0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
// 音階頻率表 低八位
unsigned char code FREQL[]={
0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
//世上只有媽媽好數(shù)據(jù)表
unsigned char code MUSIC[]={ 6,2,3, 5,2,1, 3,2,2, 5,2,2, 1,3,2, 6,2,1, 5,2,1,
6,2,4, 3,2,2, 5,2,1, 6,2,1, 5,2,2, 3,2,2, 1,2,1,
6,1,1, 5,2,1, 3,2,1, 2,2,4, 2,2,3, 3,2,1, 5,2,2,
5,2,1, 6,2,1, 3,2,2, 2,2,2, 1,2,4, 5,2,3, 3,2,1,
2,2,1, 1,2,1, 6,1,1, 1,2,1, 5,1,6, 0,0,0
void delayTips(unsigned char t);
void PlaySong();
void Song()
uchar i;
uchar k;
i=0;
while(i<100)
k=MUSIC[i]+7*MUSIC[i+1]-1;//去音符振蕩頻率所需數(shù)據(jù)
High=FREQH[k];
Low=FREQL[k];
Time=MUSIC[i+2]; //節(jié)拍時(shí)長(zhǎng)
i=i+3;
PlaySong();
// delayTips(Time); //延時(shí)所需要的節(jié)拍
if(P0==0xef)
while(P0==0xef);
break;
// PlaySong();
TR0=0;
//延時(shí)函數(shù)大約約2*z+5us
void delay2xus(unsigned char z)
while(z--);
// 延時(shí)函數(shù)大約約1ms
void delayms(unsigned char x)
while(x--)
delay2xus(245);
delay2xus(245);
//節(jié)拍延時(shí)函數(shù)
unsigned char i;
for(i=0;i<t;i++)
delayms(250);
TR0=0;
//播放音樂(lè)的函數(shù)
void PlaySong()
TH0=High;//賦值定時(shí)器時(shí)間,決定頻率
TL0=Low;
TR0=1; //打開(kāi)定時(shí)器
void Song()
uchar i;
uchar k;
i=0;
while(i<100)
High=FREQH[k];
Low=FREQL[k];
i=i+3;
PlaySong();
void LEDIO(uchar x)
uchar i;
for(i=0;i<8;i++)
if(x&0x80)
DIO = 1;
DIO = 0;
SCLK = 0;
SCLK = 1;
x <<= 1;
//數(shù)據(jù)送入74HC595的并口輸出寄存器
void LEDRCK()
RCK = 0;
RCK = 1;
//延時(shí)50*T時(shí)間函數(shù)
void delay_50ms(uint t)
uint j;
for(;t>0;t--)
for(j=6254;j>0;j--)
/*void LEDdisplay()
uchar i;
for(i=0;i<18;)
LEDIO(num[i]);
LEDRCK();
delay_50ms(20);
i++;
if(i==18)
i=0;
uchar dat;
TMOD = 0X01;
ET0 = 1;
TR0 = 0;
EA = 1;
DI1 =1;
DI2 =1;
DI3 =1;
DI4 =1;
{ dat=~P0;
KeyProc(dat);
uchar i;
if(dat==0x00)
TR0=0;BeepIO=1;
return;
switch(dat)
case 0x01: i=0;
break;
case 0x02: i=1;
break;
case 0x04: i=2;
break;
case 0x08: i=3;
break;
case 0x10: i=4;
break;
case 0x20: i=5;
break;
case 0x40: i=6;
break;
case 0x80: i=7;
break;
default:break;
if(i<7)
LEDIO(num[i+1]);
LEDRCK();
SoundTH =tune[i]/256;
SoundTL =tune[i]%256;
TR0=1;}
{Song();
void BeepTimer()interrupt 1
BeepIO=!BeepIO;
TH0= SoundTH;
TL0= SoundTL;
無(wú)所謂shine
時(shí)間:
2017-6-22 13:43
自己頂下
溶月淡風(fēng)
時(shí)間:
2017-12-17 21:53
調(diào)試有錯(cuò)
小明1939604039
時(shí)間:
2017-12-17 22:08
你按鍵沒(méi)有消抖
郝炯
時(shí)間:
2017-12-17 22:59
消抖動(dòng)
