標題: 新人制作的基于51單片機7按鍵電子琴 [打印本頁]
作者: 鈺杰Life    時間: 2017-6-14 13:17
#include <reg52.h>
sbit LED = P0^0;
sbit BEEP = P0^1;
unsigned int H,L;
void init(void)
        BEEP = 1;
        LED = 1;
        P1 = 0xff;
        EA = 1;
        ET0 = 1;
    TMOD = 0x01;
void main(void)
        unsigned int i;
        unsigned int code tone[] = {523,587,659,698,784,880,988};
        init();
                switch(~P1)
                        case 0x80: i = 0;LED=0;break;
                        case 0x40: i = 1;break;
                        case 0x20: i = 2;break;
                        case 0x10: i = 3;break;
                        case 0x08: i = 4;break;
                        case 0x04: i = 5;break;
                        case 0x02: i = 6;break;
                        case 0x00: i = 7;break;
                        if(i!=7)
                                H = (65536-1000000/tone[i]/2)/256;
                                L = (65536-1000000/tone[i]/2)/256;
                                TH0 = H;
                                TH0 = L;
                                TR0=1;
                                while(P1!=0xff);
                                TR0=0;
                                BEEP=1;
                                LED = 1;
                                TR0= 0 ;
                                BEEP= 0 ;
void timer0(void) interrupt 1
        TH0 = H;
        TL0 = L;
        BEEP = ~BEEP;
作者: 祁醉醉    時間: 2018-9-23 20:29
請問這個是可以按鍵的嗎?
為什么這個就能發出不同頻率的聲音啊……新人求教!
作者: 多嘉臘孜    時間: 2018-9-24 09:36
電路該咋連啊
