1302+18b20+超聲波測距+12864綜合程序
a8818075
2017-6-6 19:14
覺得不錯贊一個
(57.03 KB, 下載次數: 57)
2017-6-7 02:39 上傳
#include<reg52.h>
#include<12864.h>
#include<1302.h>
#include <DS18B20.h>
#include <CSB.h>
unsigned char table1[]=" ";
unsigned char table2[]=" ";
unsigned char table3[]="室內溫度:";
unsigned char table4[]="測距:";
unsigned char time_buf[8]={40,14,2,16,23,59,50,7};//空年月日時分秒周
unsigned char time_buf1[8];
unsigned char num, bai,shi,ge,i;
unsigned int temp1;
long int distance=0;
unsigned char count;
void init_parameter(void)//初始化
echo=0;
trig=0;
count=0;
distance=0;
void measure_distance(void)//計算距離
uchar I;
uint h,y;
TR0=1;
while(echo)
TR0=0;
I=TL0;
h=TH0;
y=(h<<8)+I;
y=y-0xfc66;
distance=y+1000*count;
TL0=0X66;
TH0=0XFC;
distance=0.17*distance;
void display(long int num)
unsigned int qian,bai,shi,ge;
if((num>5000)||(num==0))
qian=15;
bai=15;
shi=10;
ge=15;
qian=num/1000;
bai=(num/100)%10;
shi=(num/10)%10;
ge=num%10;
LCD_Write_String(4,1,table4);
write_data(qian+0x30);
write_data(bai+0x30);
write_data(shi+0x30);
write_data('.');
write_data(ge+0x30);
write_data('C');
write_data('M');
void disp(void)
table1[3]='2';
table1[4]='0';
table1[5]='0'+time_buf1[1]/10;//顯示年月日
table1[6]='0'+time_buf1[1]%10;
table1[7]='-';
table1[8]='0'+time_buf1[2]/10;
table1[9]='0'+time_buf1[2]%10;
table1[10]='-';
table1[11]='0'+time_buf1[3]/10;
table1[12]='0'+time_buf1[3]%10;
LCD_Write_String(1,1,table1);
table2[0]='0'+time_buf1[4]/10;//顯示時分秒
table2[1]='0'+time_buf1[4]%10;
table2[2]='-';
table2[3]='0'+time_buf1[5]/10;
table2[4]='0'+time_buf1[5]%10;
table2[5]='-';
table2[6]='0'+time_buf1[6]/10;
table2[7]='0'+time_buf1[6]%10;
table2[11]='w';
table2[12]='e';
table2[13]='e';
table2[14]='k';
table2[15]='0'+time_buf1[7]%10;
LCD_Write_String(2,1,table2);
void main(void)
P0=0X00;
dula=0;
wela=0;
lcdinit();
init_parameter();
init_timer();
delayms(15);
ds1302_init();
ds1302_write_time();
ds1302_read_time();
disp();
temp1=tmp();
bai=temp1/100;
shi=temp1%100/10;
ge=temp1%10;
LCD_Write_String(3,1,table3);
write_data('+');
write_data('.');
write_data('C');
tmpchange();
trig_supersonic();
while(echo==0)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
綜合程序.zip
(60.95 KB, 下載次數: 38)
2017-6-6 19:14 上傳
weixiao008
2018-3-5 21:18
學習了學習了。。。!
