標題: 自己做的8位競賽搶答器仿真與代碼 [打印本頁]
作者: csz8773    時間: 2017-5-29 18:42
可能有些小毛病仿真沒毛病,就是自己的那個開發版出不來,大家拿去研究研究
仿真原理圖如下 需要用8.0以上的版本(proteus仿真工程文件可到本帖附件中下載)
單片機源代碼如下:
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//變量定義
  5. sbit BEEP=P3^1;
  6. sbit start_stop=P3^2;
  7. sbit reset=P3^3;
  8. sbit key1=P1^0;
  9. sbit key2=P1^1;
  10. sbit key3=P1^2;
  11. sbit key4=P1^3;
  12. sbit key5=P1^4;
  13. sbit key6=P1^5;
  14. sbit key7=P1^6;
  15. sbit key8=P1^7;
  16. sbit state=P3^0;
  17. bit start_stop_flag=0;
  18. bit key1_flag=0;
  19. bit key2_flag=0;
  20. bit key3_flag=0;
  21. bit key4_flag=0;
  22. bit key5_flag=0;
  23. bit key6_flag=0;
  24. bit key7_flag=0;
  25. bit key8_flag=0;
  26. bit reset_flag=0;
  27. bit action=0;
  28. uchar second=20;
  29. uchar timer0_count=0;
  30. uchar number=0;
  31. uchar number_display=0;
  32. uint flag=1;                                  //延時函數
  33. void delay(uint z)
  34. {
  35.       uint x,y;
  36. for(x=z;x>0;x--)
  37.       for(y=120;y>0;y--);
  38. }                                              //蜂鳴器發聲延時
  39. void DelayMS(uint x)
  40. {
  41. uchar t;
  42. while(x--)
  43. for(t=0;t<100;t++);
  44.   }                                       //數碼管顯示驅動函數
  45. void display(uchar number,uchar second)
  46. {
  47. uchar second_first,second_second;
  48. second_first = second /  10;
  49. second_second = second %  10;
  50. P0 =0x00;
  51. P2 = 0xfe;
  52. P0 = table[number];
  53. delay(2);
  54. P0 =0x00;
  55. P2 = 0xfd;
  56. P0 = 0x40;
  57. delay(2);
  58. P0 =0x00;
  59. P2 = 0xfb;
  60. P0 = table[second_first];
  61. delay(2);
  62. P0 =0x00;
  63. P2 = 0xf7;
  64. P0 = table[second_second];
  65. delay(2);
  66. P0 =0x00;  }                                       //蜂鳴器響應按周期t發音
  67. void Play(uchar t)
  68. {  uchar i;  for(i=0;i<1;i++)
  69.    {   BEEP=~BEEP;
  70.        DelayMS(t);  }  BEEP=0;
  71. }                                                  //開始鍵掃描函數
  72. void start_stop_keyscan()
  73. {
  74. if(start_stop == 0)
  75. {
  76. delay(8);
  77. if((start_stop == 0)&&(!start_stop_flag))
  78. {
  79. start_stop_flag =  1;
  80. action       =  1;
  81. TR0 =  1;
  82. state = 0;
  83. }
  84. }
  85. else
  86. {
  87. start_stop_flag = 0;
  88.   }
  89.     }                                                 //八位搶答鍵掃描函數
  90. uchar key_scan8()
  91. {
  92. if(key1 == 0)
  93. {
  94. delay(8);
  95. if((key1 == 0)&&(!key1_flag))
  96. {
  97. key1_flag =  1;
  98. number                =  1;
  99. number_display = number;
  100. }
  101. }
  102. else
  103. {
  104. key1_flag = 0;
  105. number                 = 0;
  106. }    if(key2 == 0)
  107. {
  108. delay(8);
  109. if((key2 == 0)&&(!key2_flag))
  110. {
  111. key2_flag =  1;
  112. number                = 2;
  113. number_display = number;
  114. }
  115. }
  116. else
  117. {
  118. key2_flag = 0;
  119. number                 = 0;
  120.    }
  121. if(key3 == 0)
  122. {
  123. delay(8);
  124. if((key3 == 0)&&(!key3_flag))
  125. {
  126. key3_flag =  1;
  127. number                = 3;
  128. number_display = number;
  129. }
  130. }
  131. else
  132. {
  133. key3_flag = 0;
  134. number                 = 0;
  135. }
  136. if(key4 == 0)
  137. {
  138. delay(8);
  139. if((key4 == 0)&&(!key4_flag))
  140. {
  141. key4_flag =  1;
  142. number                = 4;
  143. number_display = number;
  144. }
  145. }
  146. else
  147. {
  148. key4_flag = 0;
  149. number                 = 0;
  150. }
  151. if(key5 == 0)
  152. {
  153. delay(8);
  154. if((key5 == 0)&&(!key5_flag))
  155. {
  156. key5_flag =  1;
  157. number                = 5;
  158. number_display = number;
  159. }
  160. }
  161. else
  162. {
  163. key5_flag = 0;
  164. number                 = 0;
  165. }
  166. if(key6 == 0)
  167. {
  168. delay(8);
  169. if((key6 == 0)&&(!key6_flag))
  170. {
  171. key6_flag =  1;
  172. number                = 6;
  173. number_display = number;
  174. }
  175. }
  176. else
  177. {
  178. key6_flag = 0;
  179. number                 = 0;
  180. }
  181. if(key7 == 0)
  182. {
  183. delay(8);
  184. if((key7 == 0)&&(!key7_flag))
  185. {
  186. key7_flag =  1;
  187. number                = 7;
  188. number_display = number;
  189. }
  190. }
  191. else
  192. {
  193. key7_flag = 0;
  194. number                 = 0;
  195. }
  196. if(key8 == 0)
  197. {
  198. delay(8);
  199.        if((key8 == 0)&&(!key8_flag))
  200. {
  201. key8_flag =  1;
  202. number                = 8;
  203. number_display = number;
  204. }
  205. }   else
  206. {
  207. key8_flag = 0;
  208. number                 = 0;
  209. }   if(number_display  != 0)
  210. {
  211. return  1;
  212. }
  213. else
  214. {
  215. return 0;
  216. }
  217. }  //復位鍵掃描函數
  218. void reset_keyscan()
  219. {
  220. if(reset == 0)
  221. {
  222. delay(8);
  223. if((reset==0)&&(!reset_flag))
  224.              {
  225. reset_flag =  1;
  226. number_display = 0;
  227. state =  1;
  228. }
  229. }
  230. else
  231. {
  232. reset_flag = 0;
  233. }
  234. }  //主函數
  235. void main()
  236. {
  237. TMOD=0x01;
  238. TH0=(65536-50000)/256;
  239. TL0=(65536-50000)%256;
  240. EA= 1;
  241. ET0= 1;
  242. TR0=0;
  243. while( 1)
  244. {
  245. if(number_display!=0)
  246. Play(number_display/2);                                 //蜂鳴器發聲
  247. start_stop_keyscan();
  248. reset_keyscan();
  249. while(action)
  250. {
  251. while(!key_scan8())
  252. {
  253. display(number_display,second);
  254. if(second == 0)
  255. ……………………
  256. …………限于本文篇幅 余下代碼請從51黑下載附件…………
8位競賽搶答器課程設計.zip (56.9 KB, 下載次數: 137)
作者: 505631748    時間: 2018-6-27 11:11
很好很好
作者: 星空下你我    時間: 2018-7-6 12:16
沒流程圖啊
作者: 親愛的h    時間: 2018-7-12 23:58
用8.6報錯
作者: boo_ker    時間: 2018-10-21 18:43
流程圖有嗎?
作者: 林鹿    時間: 2019-7-1 19:25
請問這個要怎么復位啊
作者: admin_z    時間: 2019-7-3 12:18
好東西
作者: 野人豬心    時間: 2020-1-7 14:03
這個有流程圖嗎
作者: 寶貝兒111    時間: 2020-1-7 15:09
自己在protues上走了一遍程序,還可以,不錯
作者: 世事有償    時間: 2020-1-7 15:22
可以的,正要做這個
作者: QQ1050409603    時間: 2020-1-7 19:03
好東西
