標(biāo)題: 求解!!!基于adc0809的電壓表所測(cè)電壓與實(shí)際電壓相差過大 [打印本頁(yè)]
作者: BigWorld    時(shí)間: 2017-5-18 17:49
電路連接沒有問題,就是測(cè)的電壓與實(shí)際電壓差太多了,求高手指教!!是不是程序有問題
(VREF+)=5V;
(VREF-)=0V;
這是程序
                                         adc0809數(shù)字電壓表
#include<reg52.h> //包含頭文件,一般情況不需要改動(dòng),頭文件包含特殊功能寄存器的定義
#include<intrins.h>
sbit RS = P1^0;   //定義端口
sbit RW = P1^1;
sbit EN = P1^2;
sbit DU = P2^6;
sbit WE = P2^7;
sbit CLK=P2^0;
sbit ST=P2^3;
sbit ALE=P2^7;
sbit OE=P2^5;
sbit EOC=P2^4;
sbit ADDA=P1^5;
sbit ADDB=P1^6;
sbit ADDC=P1^7;
unsigned char AD_DATA[1];
unsigned int h_date;
void keyscan();
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
void cmg88()//關(guān)數(shù)碼管,點(diǎn)陣函數(shù)
DU=1;
P0=0X00;
DU=0;
uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無(wú)返回值
unsigned char 是定義無(wú)符號(hào)字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時(shí)請(qǐng)使用匯編,大致延時(shí)
長(zhǎng)度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
             延時(shí)函數(shù)
void DelayMs(unsigned char t)
while(t--)
     //大致延時(shí)1mS
     DelayUs2x(245);
         DelayUs2x(245);
              判忙函數(shù)
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
              寫入命令函數(shù)
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
              寫入數(shù)據(jù)函數(shù)
void LCD_Write_Data(unsigned char Data)
while(LCD_Check_Busy()); //忙等待
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
                清屏函數(shù)
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
              寫入字符串函數(shù)
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
         LCD_Write_Com(0x80 + x);     //表示第一行
        LCD_Write_Com(0xC0 + x);      //表示第二行
while (*s)
LCD_Write_Data( *s);
s ++;
              寫入字符函數(shù)
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
              初始化函數(shù)
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*顯示模式設(shè)置*/
   DelayMs(5);
   DelayMs(5);
   DelayMs(5);
   LCD_Write_Com(0x08);    /*顯示關(guān)閉*/
   LCD_Write_Com(0x01);    /*顯示清屏*/
   LCD_Write_Com(0x06);    /*顯示光標(biāo)移動(dòng)設(shè)置*/
   DelayMs(5);
   LCD_Write_Com(0x0C);    /*顯示開及光標(biāo)設(shè)置*/
                    adc0809初始化函數(shù)
void ADC0809_init()   //ADC0809初始化
        TMOD=0x01;
        TH0=(65536-200)/256;
        TL0=(65536-200)%256;
        ET0=1;
        TR0=1;
        EA=1;
        DelayMs(2);
                    adc讀數(shù)據(jù)
unsigned char  Read_AD()  //讀ADC0809數(shù)據(jù)
        unsigned char temp=0;         //存放AD采集的數(shù)據(jù)
        while(EOC==0);        //等待轉(zhuǎn)換完成
                  OE=1;
                 temp=P3;      //讀取數(shù)據(jù)
                 DelayMs(1);
                 OE=0;
                 return temp;
                    500KHz時(shí)鐘頻率
void timer0(void) interrupt 1    //中斷處理函數(shù),產(chǎn)生約500KHz時(shí)鐘供0809工作
        CLK=~CLK;
                    通道選擇
void keyscan()
    ALE=1;  //允許寫入地址
    ADDA=0;
    ADDB=0;
        ADDC=0;
        ALE=0;
                    主函數(shù)
void main(void)
cmg88();//關(guān)數(shù)碼管,點(diǎn)陣函數(shù)
LCD_Init();
LCD_Clear();//清屏
ADC0809_init();
LCD_Write_String(1,0, "AD_Change_V");//在液晶的第一行顯示字符
while (1)
  ST=0 ;
  keyscan();
  ST=1;
  ST=0;
  //keyscan();
  Read_AD();
  AD_DATA[0]=Read_AD();
  h_date=AD_DATA[0]*100;
  // LCD_Write_Char(13,0, h_date);
  LCD_Write_String(0,1, "AD="); //在液晶的第二行第0位開始顯示"AD="
  LCD_Write_Char( 3, 1, AD_DATA[0]/100+0x30); //顯示AD數(shù)據(jù)的百位
  LCD_Write_Char( 4, 1, AD_DATA[0]/10%10+0x30);//顯示AD數(shù)據(jù)的十位
  LCD_Write_Char( 5, 1, AD_DATA[0]%10+0x30);//顯示AD數(shù)據(jù)的各位
  LCD_Write_String(7,1, "Vin="); //在液晶的第二行第8位開始顯示"Vin="
  LCD_Write_Char( 11, 1, AD_DATA[0]/51+0x30);//顯示輸入電壓的整數(shù)位
  LCD_Write_String(12,1, ".");//顯示小數(shù)點(diǎn)
  LCD_Write_Char( 13, 1, h_date/51/10%10+0x30);//顯示輸入電壓小數(shù)后1位
  LCD_Write_Char( 14, 1, h_date/51%10+0x30);//顯示輸入電壓小樹后2位
  LCD_Write_String(15,1, "V");
   DelayMs(100)        ;
作者: 縩漈    時(shí)間: 2017-5-18 19:20
    幫 頂  、
作者: zl2168    時(shí)間: 2017-5-18 20:33
如果電路沒問題,AD轉(zhuǎn)換沒問題,最大可能是數(shù)字量轉(zhuǎn)換顯示環(huán)節(jié)出問題。
作者: 小小號(hào)    時(shí)間: 2017-5-19 21:45
樓主,把仿真截圖發(fā)出來(lái)吧,才好幫你看到對(duì)應(yīng)的引腳接口有沒有問題啊
作者: youlove    時(shí)間: 2017-5-19 23:30
頂一下
作者: zl2168    時(shí)間: 2017-5-20 10:30
在顯示數(shù)轉(zhuǎn)換為顯示數(shù)字子程序中,滿量程A-D值FFH(255)對(duì)應(yīng)UREF+(5V),顯示時(shí)需將A-D值按比例變換:255→500。變換方法為:(A-D值÷255)×500=(A-D值÷51)×100V。
作者: 614600455    時(shí)間: 2017-5-20 20:19
接錯(cuò)了吧
作者: ahshmj    時(shí)間: 2017-5-20 21:36
如果是線性誤差,是正常的。測(cè)得的數(shù)據(jù)需要乘一個(gè)系數(shù)
作者: wxc19960311    時(shí)間: 2017-8-24 10:09
仔細(xì)檢查程序中從0809初始化開始的程序,有沒有錯(cuò)誤,數(shù)據(jù)處理有沒有問題,比如float,字符的定義有沒有錯(cuò)誤
作者: wxc19960311    時(shí)間: 2017-8-24 10:11
對(duì),如果是線性誤差肯定有一個(gè)系數(shù),如果是這樣錯(cuò)誤就在我說(shuō)的08909下來(lái)的數(shù)據(jù)處理那一部分中,加油,祝你好運(yùn)
