標(biāo)題: 求c語(yǔ)言編譯成hex,有酬謝 [打印本頁(yè)]
作者: haodiy制作    時(shí)間: 2017-5-13 23:05
求c語(yǔ)言編譯成hex,有酬謝
單片機(jī)型號(hào)是:stc89c52RC,我提供c語(yǔ)音程序,誰(shuí)能幫我編譯。付酬謝也可以,我微信是13977534587,發(fā)紅包感謝!
程序如下:
名稱:電子琴
內(nèi)容:7個(gè)激光束控制7個(gè)音符7個(gè)LED顯示,1個(gè)控制播放音樂,1個(gè)高中低音切換
#include "reg52.h"
#include "intrins.h"
sbit SPK    = P3^4;
sbit LED_L  = P3^7;
sbit LED_M  = P3^6;
sbit LED_H  = P3^5;
sbit KEY    = P3^3;
#define KEYDELAY 20
#define KEY_PORT P2
#define LED_PORT P1
bit FT_1ms,FT_250ms;
bit F_PlaySong,F_PlayTone,F_KeyDelay,F_Tone,F_KeyUp,F_Music_Ide;
unsigned char Freq_H,Freq_L,SongLen,PlayIde,i;
unsigned char KeyBuf,KeySure,KeyDelay_Cnt,Timer1_Cnt,KeyDelay_Cnt1;
unsigned char k,Time,PortTemp;
                         //世上只有媽媽好數(shù)據(jù)表
code unsigned char MUSIC[]={6,2,6,     5,2,2,      3,2,4,    5,2,4,    1,3,4,    6,2,2,    5,2,2,
                            6,2,8,      3,2,4,      5,2,2,    6,2,2,    5,2,4,   3,2,4,    1,2,2,
                            6,1,2,      5,2,2,      3,2,2,    2,2,8,    2,2,6,   3,2,2,    5,2,4,
                            5,2,2,      6,2,2,      3,2,4,    2,2,4,    1,2,8,   5,2,6,    3,2,2,
                            2,2,2,      1,2,2,      6,1,2,   1,2,2,    5,1,12,   0,0,0
/***********************生日快樂**********************/
code unsigned char MUSIC1[]={
                                 5,1,2, 5,1,2, 6,1,4, 5,1,4, 1,2,4, 7,1,8,
                                 5,1,2, 5,1,2, 6,1,4, 5,1,4, 2,2,4, 1,2,8,
                                 5,1,2, 5,1,2, 5,2,4, 3,2,4, 1,2,4, 7,1,4,
                                 6,1,8, 4,2,2, 4,2,2, 3,2,4, 1,2,4, 2,2,4,
                                 1,2,12, 0,0,0};
                         // 音階頻率表 高八位
code unsigned char FREQH[]={
                                0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
                                0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
                                0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
                                0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
                         // 音階頻率表 低八位
code unsigned char FREQL[]={
                                 0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
                                 0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
                                 0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
                                 0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
void TimerInit(void)
    TMOD = 0x11;
    TH1  = (65536 - 1000) / 256;
    TL1  = (65536 - 1000) % 256;
    ET0  = 1;
    ET1  = 1;
    TR0 = 1;
    TR1  = 1;
    EA   = 1;
void ScanKey(void)
    if(F_KeyDelay)
        KeyDelay_Cnt --;
        if(KeyDelay_Cnt == 0)
            F_KeyDelay = 0;
            KeySure = KeyBuf;
            F_KeyUp = 1;
    if(KeyBuf != KEY_PORT)
        KeyBuf = KEY_PORT;
        KeyDelay_Cnt = KEYDELAY;
        F_KeyDelay = 1;
    if(!KEY)
        KeyDelay_Cnt1 --;
        if(KeyDelay_Cnt1 == 0)
            if(F_PlaySong == 0)
                F_Music_Ide = !F_Music_Ide;
                F_PlaySong = 1;
                i = 0;
         KeyDelay_Cnt1 = KEYDELAY;
    if(PlayIde == 1)
        LED_L = 1;
        LED_M = 0;
        LED_H = 1;
    if(PlayIde == 2)
        LED_L = 1;
        LED_M = 1;
        LED_H = 0;
    if(PlayIde == 0)
        LED_L = 0;
        LED_M = 1;
        LED_H = 1;
void main(void)
    TimerInit();
    F_PlayTone = 0;
    PortTemp = 0x7f;
    for(i = 0;i < 7;)
        if(FT_250ms)
            FT_250ms = 0;
            i++;
            PortTemp = _crol_(PortTemp,1);
            LED_PORT= PortTemp;
    for(i = 0;i < 7;)
        if(FT_250ms)
            FT_250ms = 0;
            i++;
            PortTemp = _cror_(PortTemp,1);
            LED_PORT= PortTemp;
    LED_PORT = 0xff;
    i = 0;
        if(FT_1ms)
            FT_1ms = 0;
            WDT_CONTR = 0x38;
            ScanKey();
            if(F_PlaySong)
                if(FT_250ms)
                    FT_250ms = 0;
                    if(Time > 0)
                        Time --;
                        PortTemp = 0x01;
                        F_PlayTone = 1;
                        if(F_Music_Ide)
                            k = MUSIC[i] + 7 * MUSIC[i + 1] - 1;//去音符振蕩頻率所需數(shù)據(jù)
                            PlayIde = MUSIC[i + 1] - 1;
                            PortTemp <<= (MUSIC[i]-1);
                            Time = MUSIC[i+2] - 1;          //節(jié)拍時(shí)長(zhǎng)
                            if(! MUSIC[i])
                                    i = 0;
                                F_PlaySong = 0;
                                LED_PORT = 0xff;
                                F_PlayTone = 0;
                                    SPK = 1;
                                PlayIde = 1;
                                Time = 4;
                            k = MUSIC1[i] + 7 * MUSIC1[i + 1] - 1;//去音符振蕩頻率所需數(shù)據(jù)
                            PlayIde = MUSIC1[i + 1] - 1;
                            PortTemp <<= (MUSIC1[i]-1);
                            Time = MUSIC1[i+2] - 1;          //節(jié)拍時(shí)長(zhǎng)
                            if(! MUSIC1[i])
                                    i = 0;
                                F_PlaySong = 0;
                                LED_PORT = 0xff;
                                F_PlayTone = 0;
                                    SPK = 1;
                                PlayIde = 1;
                                Time = 4;
                        PortTemp = ~PortTemp;
                        LED_PORT = PortTemp;
                        Freq_H = FREQH[k];
                        Freq_L = FREQL[k];
                        i = i + 3;
                switch(KeySure)
                    case 0x81:  F_Tone = 0;F_PlayTone = 1;  Timer1_Cnt = 0;k=0; LED_PORT = 0xfe;
                        break;
                    case 0x41:  F_Tone = 0;F_PlayTone = 1;  Timer1_Cnt = 0;k=1; LED_PORT = 0xfd;
                        break;
                    case 0x21:  F_Tone = 0;F_PlayTone = 1;  Timer1_Cnt = 0;k=2; LED_PORT = 0xfb;
                        break;
                    case 0x11:  F_Tone = 0;F_PlayTone = 1;  Timer1_Cnt = 0;k=3; LED_PORT = 0xf7;
                        break;
                    case 0x09:  F_Tone = 0;F_PlayTone = 1;  Timer1_Cnt = 0;k=4; LED_PORT = 0xef;
                        break;
                    case 0x05:  F_Tone = 0;F_PlayTone = 1;  Timer1_Cnt = 0;k=5; LED_PORT = 0xdf;
                        break;
                    case 0x03:  F_Tone = 0;F_PlayTone = 1;  Timer1_Cnt = 0;k=6; LED_PORT = 0xbf;
                        break;
                    case 0x00:
                                if(F_KeyUp)
                                    F_KeyUp = 0;
                                    PlayIde++;
                                    if(PlayIde == 3)
                                        PlayIde = 0;
                        break;
                    default:
                        break;
                Freq_H = FREQH[(PlayIde * 7) + k];
                Freq_L = FREQL[(PlayIde * 7) + k];
                if(F_Tone)
                    F_Tone = 0;
                    F_PlayTone = 0;
                    SPK = 1;
                    LED_PORT = 0xff;
void Timer1_IRQ(void) interrupt 1
    TH0  = (65536 - 1000) / 256;
    TL0  = (65536 - 1000) % 256;
    FT_1ms = 1;
    Timer1_Cnt ++;
    if(Timer1_Cnt == 125)
        FT_250ms = 1;
        F_Tone = 1;
        Timer1_Cnt = 0;
void Timer0_IRQ(void) interrupt 3
    TH1  = Freq_H;
    TL1  = Freq_L;
    if(F_PlayTone)
        SPK = !SPK;
作者: ning    時(shí)間: 2017-5-14 10:14
你安裝個(gè)KEIL軟件編譯不就完了嗎!
作者: imxuheng    時(shí)間: 2017-5-14 11:00
記得加上sfr WDT_CONTR=0xe1;,
hex文件.zip
1.17 KB, 下載次數(shù): 2
作者: 宮本無三四    時(shí)間: 2017-5-14 11:19
勾選這個(gè),確定,然后編譯
作者: w1179benp    時(shí)間: 2017-5-14 11:32
WDT_CONTR = 0x38;   屏蔽掉這句就可以編譯通過。(看不出賦這個(gè)計(jì)數(shù)地址 干嘛)
作者: 其味無窮    時(shí)間: 2017-5-14 12:58
安裝keil軟件,然后在那里運(yùn)行你的程序,就可以得到hex文件。
作者: 百思不解    時(shí)間: 2017-5-14 16:06
用KEIL編譯
作者: Chinapower    時(shí)間: 2017-5-15 17:32
能寫出這么長(zhǎng)的程序來,我表示不相信不會(huì)生成hex文件
作者: sundfor    時(shí)間: 2017-5-24 21:19
下載個(gè)keil,用keil編譯
