GSM/GPRS模塊 SIM發送信息單片機程序
xiaosizhu1995
2017-5-12 19:26
SIM發送信息程序
(65.16 KB, 下載次數: 53)
2017-5-13 03:31 上傳
作者:神秘藏寶室
本例程僅適用于在本店購買GSM/GPRS模塊模塊的用戶使用,鄙視其它店鋪的盜用行為
版權所有,盜版必究!!!
#include "main.h"
#include "uart.h"
//常量
#define Success 1U
#define Failure 0U
//定義變量
unsigned long Time_Cont = 0; //定時器計數器
char phoneNumber[] = "39"; //替換成需要被撥打電話的號碼
char msg[] = ""; //短信內容
//主函數
Uart_Init();
if (sendCommand("AT\r\n", "OK\r\n", 3000, 10) == Success);
else errorLog();
delay_ms(10);
if (sendCommand("AT+CPIN?\r\n", "+CPIN:READY", 1000, 10) == Success);
else errorLog();
delay_ms(10);
if (sendCommand("AT+CREG?\r\n", "+CREG: 1,1", 1000, 10) == Success);
else errorLog();
delay_ms(10);
if (sendCommand("AT+CMGF=0\r\n", "OK\r\n", 1000, 10) == Success);
else errorLog();
delay_ms(10);
if (sendCommand("AT+CSCS=\"GSM\"\r\n", "OK\r\n", 1000, 10) == Success);
else errorLog();
delay_ms(10);
sendMessage(phoneNumber); //發送短信
void sendMessage(char *number)
xdata char send_buf[20] = {0};
memset(send_buf, 0, 20); //清空
strcpy(send_buf, "AT+CMGS=");
strcat(send_buf, number);
strcat(send_buf, "\r\n");
if (sendCommand(send_buf, ">", 3000, 10) == Success);
else errorLog();
SendString("0011000D91683137380502F50008AA180048006F0077002000610072006500200079006F0075003F");
SendData(0x1A);
void phone(char *number)
strcpy(send_buf, "ATD");
strcat(send_buf, ";\r\n");
if (sendCommand(send_buf, "SOUNDER", 10000, 10) == Success);
else errorLog();
void errorLog()
while (1)
if (sendCommand("AT\r\n", "OK", 100, 10) == Success)
soft_reset();
delay_ms(200);
void soft_reset(void) //制造重啟命令
((void (code *) (void)) 0x0000) ();
unsigned int sendCommand(char *Command, char *Response, unsigned long Timeout, unsigned char Retry)
unsigned char n;
CLR_Buf();
for (n = 0; n < Retry; n++)
SendString(Command); //發送GPRS指令
Time_Cont = 0;
while (Time_Cont < Timeout)
delay_ms(100);
Time_Cont += 100;
if (strstr(Rec_Buf, Response) != NULL)
CLR_Buf();
return Success;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
發送短信成功.rar
(60.44 KB, 下載次數: 44)
2017-5-12 19:25 上傳
909169697
2017-7-2 15:09
樓主這個是,只要運行就會發送一次短信的還是什么啊
