標(biāo)題: dht11在lcd1602顯示程序 [打印本頁(yè)]
作者: 顏偉浩 時(shí)間: 2017-5-11 09:06
#include<reg52.h>
#include<intrins.h>
#define Data P0 //數(shù)據(jù)端口
sbit RS=P2^4;
sbit RW=P2^5;
sbit E=P2^6;
sbit DHT=P1^0;
uchar FirstLine[] ="wen:00.00"; //第一行數(shù)據(jù)
uchar SecondLine[]="shi:00.00"; //第二行數(shù)據(jù)
unsigned char shiZ,shiX,wenZ,wenX,check;
unsigned char tr_shiZ,tr_shiX,tr_wenZ,tr_wenX;
unsigned char flag;
unsigned int n=20,m;
void delay_1ms(unsigned int i)
unsigned int j=88;
for(;i>0;i--)
while(j>0)j--;
void delay_10us()
unsigned char i;
i--;
i--;
i--;
i--;
i--;
i--;
/*************溫濕度讀取函數(shù)***************/
char read_data()
unsigned char i,num,temp;
num=0;
for(i=0;i<8;i++)
flag=2;
while((!DHT)&&flag++);
delay_10us();
delay_10us();
delay_10us();
if(DHT==1)
temp=1;
flag=2;
while(DHT&&flag++);
temp=0;
num<<=1;
num|=temp;
return(num);
void delay(uchar ms) // 延時(shí)函數(shù)ms毫秒
uchar i,j;
for(i=ms;i>0;i--)
for(j=100;j>0;j--);
void DelayUs(unsigned char us) //--延時(shí)函數(shù)
unsigned char uscnt;
uscnt=us>>1; /*12MHz頻率*/
while(--uscnt);
void DelayMs(unsigned char ms)
while(--ms)
DelayUs(250);
DelayUs(250);
DelayUs(250);
DelayUs(250);
void lcd_write_com(uchar c) //寫命令
DelayMs(5);//操作前短暫延時(shí),保證信號(hào)穩(wěn)定
E=0;
RS=0;
RW=0;
_nop_();
E=1;
Data=c;
E=0;
void lcd_write_dat(uchar c) //寫數(shù)據(jù)
DelayMs(5); //操作前短暫延時(shí),保證信號(hào)穩(wěn)定
E=0;
RS=1;
RW=0;
_nop_();
E=1;
Data=c;
E=0;
RS=0;
void lcd_init() //LCD初始化
DelayMs(15);
lcd_write_com(0x38); //display mode
lcd_write_com(0x06); //顯示光標(biāo)移動(dòng)位置
lcd_write_com(0x0c); //顯示開及光標(biāo)設(shè)置
lcd_write_com(0x01); //顯示清屏
void ShowChar(uchar pos,uchar c) //顯示單個(gè)字符
unsigned char p;
if (pos>=0x10)
p=pos+0xb0; //是第二行則命令代碼高4位為0xc
p=pos+0x80; //是第二行則命令代碼高4位為0x8
lcd_write_com(p);//寫命令
lcd_write_dat(c); //寫數(shù)據(jù)
void ShowString (uchar line,char *ptr) //顯示字符串
unsigned char l,*p;
p=ptr;
l=line<<4;
while((*p)!='\0')
ShowChar(l++,*(p));
p++;
void disp(void) //主函數(shù)調(diào)用的顯示函數(shù)
ShowString(0,FirstLine);
ShowString(1,SecondLine);
/************初始化及采集程序**************/
void read_init()
DHT=0; //主機(jī)使DHT11低電平并延時(shí)至少18ms
delay_1ms(21);
DHT=1; //主機(jī)置DHT11高電平20~40us,并等待從機(jī)相應(yīng)
delay_10us();
delay_10us();
delay_10us();
delay_10us();
DHT=1;
if(!DHT) //從機(jī)發(fā)出相應(yīng)信號(hào)
flag=2;
flag=2;
while(DHT&&flag++); //開始采集數(shù)據(jù)
tr_shiZ=read_data();//采集濕度整數(shù)部分
tr_shiX=read_data();//采集濕度小數(shù)部分
tr_wenZ=read_data();//采集溫度整數(shù)部分
tr_wenX=read_data();//采集溫度小數(shù)部分
check=read_data(); //采集校驗(yàn)位
DHT=1;
unsigned char temp;
lcd_init();
delay(50);
disp();
read_init();
temp=tr_shiZ+tr_shiX+tr_wenZ+tr_wenX;
if(check==temp)
shiZ=tr_shiZ;
shiX=tr_shiX;
wenZ=tr_wenZ;
wenX=tr_wenX;
FirstLine[4]='0'+wenZ/10;
FirstLine[5]='0'+wenZ%10;
FirstLine[8]='0'+wenX/10;
FirstLine[9]='0'+wenX%10;
SecondLine[4]='0'+shiZ/10;
SecondLine[5]='0'+shiZ%10;
SecondLine[8]='0'+shiX/10;
SecondLine[9]='0'+shiX%10;
作者: a8818075 時(shí)間: 2017-7-30 10:41
你這程序行不行啊
作者: 不傷手的立白 時(shí)間: 2018-1-11 17:15
不顯示,一直00
作者: 黑白子 時(shí)間: 2018-4-20 22:15
不顯示
