stm32 adc規則組注入組混合轉換 DMA多通道單次轉換 KEIL
百寶
2017-5-9 17:00
(63.75 KB, 下載次數: 127)
2017-5-9 17:44 上傳
stm32單片機源程序:
//通過串口實時打印KEY3 KEY4 電位器的電壓值。
//每個通道采集一次
#include "pbdata.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void USART_Configuration(void);
void ADC1_Configuration(void);
void DMA_Configuration(void);
u16 AD_Value[M]; //用來存放ADC轉換結果,也是DMA的目標地址
u16 AD_3;
int fputc(int ch,FILE *f)
USART_SendData(USART1,(u8)ch);
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
return ch;
int main(void)
RCC_Configuration();
GPIO_Configuration();
USART_Configuration();
NVIC_Configuration();
ADC1_Configuration();
DMA_Configuration();
ADC_SoftwareStartConvCmd(ADC1,ENABLE); //使能軟件啟動功能 單次轉換模式下使用。
delay_us(200); //啟動轉換后,需要等待轉換完成,此處做適當延時。
printf("key3=%f\r\n",AD_Value[0]*3.3/4095);
printf("key4=%f\r\n",AD_Value[1]*3.3/4095);
printf("pot =%f\r\n",AD_3*3.3/4095);
printf("\r\n");
delay_ms(1000);
SystemInit();//72m
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //GPIOA
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); //USART
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //AFIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE); //GPIOC
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); //ADC
RCC_ADCCLKConfig(RCC_PCLK2_Div6); //12M 最大14M
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA傳輸
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;//TX
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;//RX
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3;//ADin: POT K3 K4
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN; //模擬輸入
GPIO_Init(GPIOC,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1;//ADin: sensor1 sensor2 VOC
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;//中斷向量
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //0
NVIC_InitStructure.NVIC_IRQChannel=ADC1_2_IRQn;
USART_InitTypeDef USART_InitStructure;
USART_InitStructure.USART_BaudRate=9600;
USART_InitStructure.USART_WordLength=USART_WordLength_8b;
USART_InitStructure.USART_StopBits=USART_StopBits_1;
USART_InitStructure.USART_Parity=USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
USART_Init(USART1,&USART_InitStructure);
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
USART_Cmd(USART1,ENABLE);
USART_ClearFlag(USART1,USART_FLAG_TC);
ADC_InitTypeDef ADC_InitStructure;
ADC_DeInit(ADC1); //將外設 ADC1 的全部寄存器重設為缺省值
ADC_StructInit(&ADC_InitStructure);
ADC_InitStructure.ADC_Mode=ADC_Mode_Independent; //ADC1 ADC2工作在獨立模式
ADC_InitStructure.ADC_ScanConvMode=ENABLE; //工作在單通道模式(還是掃描模式:多通道模式)
ADC_InitStructure.ADC_ContinuousConvMode=DISABLE; //模數轉換工作在單次模式(還是連續模式)
ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;//轉換由軟件而不是外部觸發啟動
ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; //ADC數據右對齊
ADC_InitStructure.ADC_NbrOfChannel=M; //順序進行轉換的通道數
ADC_Init(ADC1, &ADC_InitStructure); //根據ADC_InitStruct中指定的參數初始化外設ADCx的寄存器
ADC_RegularChannelConfig(ADC1,ADC_Channel_12,1,ADC_SampleTime_239Cycles5);//選擇ADC1通道12-PC2 KEY3
ADC_RegularChannelConfig(ADC1,ADC_Channel_13,2,ADC_SampleTime_239Cycles5);//選擇ADC1通道13-PC3 KEY4
// ADC_RegularChannelConfig(ADC1,ADC_Channel_10,3,ADC_SampleTime_239Cycles5);//選擇ADC1通道10-PC0 POT
ADC_InjectedSequencerLengthConfig(ADC1,1);//設置注入組通道的轉換序列長度
ADC_InjectedChannelConfig(ADC1, ADC_Channel_10, 1,ADC_SampleTime_239Cycles5); //
ADC_SetInjectedOffset(ADC1,ADC_InjectedChannel_1,0); //偏移量影響輸出數據的大小,為2時數據變小。為12位數值
ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None); //由軟件觸發注入組轉換。
ADC_SoftwareStartInjectedConvCmd(ADC1,ENABLE); //使能ADCx 軟件啟動注入組轉換功能 啟動轉換
ADC_AutoInjectedConvCmd(ADC1, ENABLE); //規則組轉換完成,自動轉換注入組使能。
// ADC_ExternalTrigConvCmd(ADC1, DISABLE); //ADC規則組或注入組由外部觸發時使能。
// ADC_ExternalTrigInjectedConvCmd(ADC1,DISABLE); //失能 ADCx 的經外部觸發啟動注入組轉換功能
// ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE); //規則組中斷使能
ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE); //JEOC 注入組中斷屏蔽
// ADC_ClearFlag(ADC1, ADC_FLAG_EOC); //注入組轉換結束標志位 清零
ADC_DMACmd(ADC1, ENABLE); // 開啟ADC的DMA支持(要實現DMA功能,還需獨立配置DMA通道等參數)
ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1
ADC_ResetCalibration(ADC1); //重置校準器
while(ADC_GetResetCalibrationStatus(ADC1)); //獲取校準狀態
ADC_StartCalibration(ADC1); //開始指定ADC的校準狀態
while(ADC_GetCalibrationStatus(ADC1)); //獲取指定ADC的校準程序
ADC_SoftwareStartConvCmd(ADC1,ENABLE); //使能軟件啟動功能 啟動一次轉換,防止主程序調用時沒有ADC值。
DMA_InitTypeDef DMA_InitStructure;
DMA_DeInit(DMA1_Channel1); //將DMA的通道1寄存器重設為缺省值
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR; //DMA外設ADC基地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; //DMA內存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //內存作為數據傳輸的目的地 外設作為數據傳輸的來源
DMA_InitStructure.DMA_BufferSize = M; //DMA通道的DMA緩存的大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外設地址寄存器不變
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //內存地址寄存器遞增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //數據寬度為16位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //數據寬度為16位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循環緩存模式,當傳輸完一次后,重新接著傳送,永不停息。
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x擁有高優先級
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x沒有設置為內存到內存傳輸
…………限于本文篇幅 余下代碼請從51黑下載附件…………
完整代碼下載:
3 規則組轉換 (DMA 多通道單次采集).7z
(190.82 KB, 下載次數: 59)
2021-9-29 03:24 上傳
