新人求問 串口密碼鎖 我寫的單片機程序有問題
身向榆關那畔行
2017-5-8 21:20
題目 串口密碼鎖
基本要求:串口發送正確密碼,單片機會返回ok,并打開鎖(用led亮滅代替),發送錯誤密碼返回error
我照貓畫虎的寫了一串可是不知道哪里有問題
#include "reg52.h"
#include <string.h>
typedef unsigned int u16;
typedef unsigned char u8;
unsigned char mima[]="123456\r",a[10];
unsigned char tab2[]=" the password is corret";
unsigned char tab3[]=" the password is incorret ,please re-enter your password!";
void UsartInit()
SCON=0X50;
TMOD=0X20;
PCON=0X80;
TH1=0XF3;
TL1=0XF3;
ES=1;
EA=1;
TR1=1;
void delay(u16 i)
while(i--);
UsartInit();
while(1);
void send_char(unsigned char c)
{ SBUF=c;
while(TI==0);
TI=0;
void Usart() interrupt 4
u16 i;
for(i=0;a[i]!='\r';i++)
if(RI==1)
a[i]=SBUF;
if(strcmp(a,mima)==0)
send_char(tab2);
send_char(tab3);
RI=0;
HUANGHFS
2017-5-8 22:09
應該是參數傳遞錯誤。
HUANGHFS
2017-5-8 22:10
應該是參數傳遞錯誤。
