標(biāo)題: 有誰幫我看下這個(gè)為啥仿真不出來 [打印本頁]
作者: 秋夏風(fēng)子    時(shí)間: 2017-5-5 10:43
程序如下:
#include <reg51.h>
sbit rs=P3^5;
sbit rw=P3^6;
sbit e=P3^7;
uchar table;
char en;
/*uchar code table1[]="Huan Ying Cheng Zuo";
uchar code table2[]="Li Gong Nan Yuan Dao Le";
uchar code table3[]="Li Gong Xue Yuan Dao Le";
uchar code table4[]="Hua ban Qiao Dao Le";
uchar code table5[]="Xie Xie Cheng Zuo"; */
uchar code table1[]="LCD1206 check ok";
uchar code table2[]="study up";
void delay(uint n)
uint x,y;
for(x=n;x>0;x--)
for(y=110;y>0;y--);
void lcd_wcom(uchar com)
rs=0;
rw=0;
P0=com;
delay(5);
en=1;
en=0;
void lcd_wdat(uchar dat)
rs=1;
rw=0;
P0=dat;
delay(5);
en=1;
en=0;
void lcd_init()
lcd_wcom(0x38);
lcd_wcom(0x0c);
lcd_wcom(0x06);
lcd_wcom(0x01);
uchar n,m=0;
lcd_init();
lcd_wcom(0x80);
for(m=0;m<16;m++)
  lcd_wdat(table1[m]);
  delay(200);
lcd_wcom(0x80+0x44);
for(n=0;n<8;n++)
  lcd_wdat(table2[n]);
  delay(200);
while(1);
作者: 遇見之影    時(shí)間: 2017-5-7 12:41
#include <reg51.h>
#include <intrins.h>
#define lcd_data P0
sbit RS=P2^5;
sbit RW=P2^6;
sbit E=P2^7;
void lcd_w_cmd(unsigned char com);        //寫命令字函數(shù)
void lcd_w_dat(unsigned char dat);         //寫數(shù)據(jù)函數(shù)
unsigned char lcd_r_start();                //讀狀態(tài)函數(shù)
void lcd_int1();                                //LCD初始化函數(shù)
void  delay (uint n)
uint x,y;
for(x=n;x>0;x--)
for(y=110;y>0;y--);
void delay1()
   _nop_();
   _nop_();
   _nop_();
   unsigned char s;
   RW=1;                //RW=1,RS=0,讀LCD狀態(tài)
   delay1();
   RS=0;
   delay1();
   E=1;                        //E端時(shí)序
   delay1();
   s=lcd_data;                //從LCD的數(shù)據(jù)口讀狀態(tài)
   delay1();
   E=0;
   delay1();
   RW=0;
   delay1();
   return(s);                //返回讀取的LCD狀態(tài)字
//函數(shù)名:lcd_w_cmd
//函數(shù)功能:寫命令字
//形式參數(shù):命令字已存入com單元中
//返回值:無
   unsigned char i;
   do {                        // 查LCD忙操作
      i=lcd_r_start();        // 調(diào)用讀狀態(tài)字函數(shù)
      i=i&0x80;                // 與操作屏蔽掉低7位
      delay(2);
      } while(i!=0);        // LCD忙,繼續(xù)查詢,否則退出循環(huán)
          RW=0;
          delay1();
          RS=0;                        // RW=1,RS=0,寫LCD命令字
          delay1();
          E=1;                        //E端時(shí)序
          delay1();
          lcd_data=com;                //將com中的命令字寫入LCD數(shù)據(jù)口
          delay1();
          E=0;
          delay1();
          RW=1;
          delay(255);
//函數(shù)名:lcd_w_dat
//函數(shù)功能:寫數(shù)據(jù)
//形式參數(shù):數(shù)據(jù)已存入dat單元中
//返回值:無
   unsigned char i;
   do {                        // 查忙操作
      delay(2);
   RW=0;
   delay1();
   RS=1;                // RW=1,RS=0,寫LCD命令字
   delay1();
   E=1;                        // E端時(shí)序
   delay1();
   lcd_data=dat;                // 將dat中的顯示數(shù)據(jù)寫入LCD數(shù)據(jù)口
   delay1();
   E=0;
   delay1();
   RW=1;
   delay(255);
void lcd_init()
   lcd_w_cmd(0x38);        // 設(shè)置工作方式
   lcd_w_cmd(0x0c);        // 設(shè)置光標(biāo)
   lcd_w_cmd(0x01);        // 清屏
   lcd_w_cmd(0x06);        // 設(shè)置輸入方式
   lcd_w_cmd(0x80);        // 設(shè)置初始顯示位置
uchar n,m=0;
lcd_init();
lcd_w_cmd(0x80);
for(m=0;m<16;m++)
  lcd_w_dat(table1[m]);
  delay(200);
lcd_w_cmd(0xC4);
for(n=0;n<8;n++)
lcd_w_dat(table2[n]);
  delay(200);
程序附上,你可以看看。我只改變了,使能端,你可以改。
你的主程序不應(yīng)該寫while(1);等待,還有你1602的各個(gè)函數(shù)有誤
作者: zl2168    時(shí)間: 2017-5-7 20:19
本帖最后由 zl2168 于 2017-5-7 20:38 編輯
實(shí)例67  LCD1602顯示屏顯示
本例編制的LCD 1602顯示程序標(biāo)準(zhǔn)化程度很好,若要顯示其他字符,只需給數(shù)組x[16]、y[16]重新賦值即可。
Proteus仿真一下,確認(rèn)有效。
實(shí)例61 LCD1602顯示屏顯示.rar (49.26 KB, 下載次數(shù): 4)
以上摘自張志良編著《80C51單片機(jī)仿真設(shè)計(jì)實(shí)例教程——基于Keil CProteus》清華大學(xué)出版社ISBN 978-7-302-41682-1
。書中電路和程序設(shè)計(jì)有詳細(xì)說明,程序語句條條有注解。
仿真電路和Hex文件能在清華出版社網(wǎng)站免費(fèi)下載,程序源代碼只能到書上看了。到圖書館借,或到新華書店翻閱,或到網(wǎng)上書店打折購買。
作者: 3760609865    時(shí)間: 2017-5-8 01:11
謝謝分享,我下個(gè)學(xué)習(xí)一下。
作者: 某只愛二哈的喵    時(shí)間: 2017-5-8 09:19
