標題: PCF8691-單片機C語言程序 [打印本頁]
作者: 646189878 時間: 2017-4-11 12:54
sbit CLK=P1^1;
sbit SDA=P1^2;
sbit A=P2^0;
sbit M=P2^1;
sbit C=P2^2;
unsigned charnum[10]={0X3f,0X06,0X5b,0X4f,0X66,0X6d,0X7d,0X07,0X7f,0X6f};
//-------------IIC--------------------
void IIC_Delay()
void start()
SDA=1;
IIC_Delay();
CLK=1;
IIC_Delay();
SDA=0;
IIC_Delay();
void stop()
SDA=0;
IIC_Delay();
CLK=1;
IIC_Delay();
SDA=1;
IIC_Delay();
void answer()
CLK=1;
IIC_Delay();
while(SDA==1);
CLK=0;
IIC_Delay();
void write_byte(unsigned char dat)
unsigned char i;
for(i=0;i<8;i++)
dat=dat<<1;
CLK=0;
IIC_Delay();
SDA=CY;
IIC_Delay();
CLK=1;
IIC_Delay();
CLK=0;
IIC_Delay();
SDA=1;
IIC_Delay();
unsigned char read_byte()
unsigned char i,dat;
CLK=0;
IIC_Delay();
SDA=1;
IIC_Delay();
for(i=0;i<8;i++)
CLK=1;
IIC_Delay();
dat=dat<<1;
if(SDA)
dat=dat|0x01;
CLK=0;
IIC_Delay();
return dat;
//-------------IIC A/DD/A-----------------------
void DA_trans(unsigned char dat)
start();
write_byte(0x90);
answer();
write_byte(0x40);
answer();
write_byte(dat);
answer();
stop();
unsigned char AD_trans()
unsigned char dat;
start();
write_byte(0x90);
answer();
write_byte(0x02);
answer();
start();
write_byte(0x91);
answer();
dat=read_byte();
stop();
return dat;
void delay(unsigned char Xms)
unsigned int i,j;
for(i=0;i<Xms;i++)
for(j=0;j<114;j++);
void weixuan(char x,char y,char z)
A=x;
M=y;
C=z;
void Display(unsigned char dat)
weixuan(0,0,0);
P0=num[dat/100];
delay(5);
weixuan(1,0,0);
P0=num[(dat%100)/10];
delay(5);
weixuan(0,1,0);
P0=num[dat%10];
delay(5);
main()
unsigned char dat;
dat=AD_trans();
Display(dat);
PCF8591-單片機C語言程序--ADDA裝換.docx
2017-4-11 12:53 上傳
13.31 KB, 下載次數: 7, 下載積分: 黑幣 -5
