標題: [求助]新手求助DS1302 [打印本頁]
作者: kkssmm    時間: 2010-8-12 16:50
標題: [求助]新手求助DS1302
#include <reg52.h>
sbit lcde_1602=P2^7;
sbit rs_1602=P2^6;
sbit rw_1602=P2^5;
sbit sclk=P3^6;
sbit rst=P3^5;
sbit io=P3^4;
uchar code shu[]="Data:20  -  -  Time:  :  :  ";
uchar code dat[6]={10,11,12,23,59,50};//年月日時分秒
uchar i,j;
void delay(uint);
void write_com_1602(uchar);
void write_dat_1602(uchar);
void init_1602();
void write_byte_1302(uchar);
uchar read_byte_1302();
void write1302(uchar,uchar);
uchar read1302(uchar);
void write_byte_1302(uchar dat)      //dat 為BCD碼
    uchar i;
//    x=dat/10;
//    y=dat%10;
//    dat=((dat/10)<<4)|(dat%10);
    for(i=0;i<8;i++)
        io=dat&0x01;
        dat>>=1;
        sclk=0;
        delay(5);
        sclk=1;
//    sclk=0;
    uchar i,dat=0x00;
    for(i=0;i<8;i++)
        dat>>=1;
        if(io)
        dat=dat|0x80;
        sclk=1;
        delay(5);
        sclk=0;
    return ((dat/16)*10+dat%16); //讀出的BCD碼轉換成DEC輸出
void write1302(uchar add,uchar dat)     //dat為10進制
    rst=0;
    delay(2);
    sclk=0;
    delay(2);
    rst=1;
    delay(2);
    write_byte_1302(add);
    dat=(((dat/10)<<4)|(dat%10)); //dat轉換成BCD
    write_byte_1302(dat);
    delay(2);
    rst=0;
uchar read1302(uchar add)
    uchar temp;
    rst=0;
    delay(2);
    sclk=0;
    delay(2);
    rst=1;
    delay(2);
    temp=read_byte_1302();
    delay(2);
    rst=0;
    return temp;
void write_com_1602(uchar com)
    rs_1602=0;
    rw_1602=0;
    P0=com;
    delay(5);
    lcde_1602=0;
    delay(5);
    lcde_1602=1;
void write_dat_1602(uchar dat)
    rs_1602=1;
    rw_1602=0;
    P0=dat;
    delay(5);
    lcde_1602=0;
    delay(5);
    lcde_1602=1;
void init_1602()
    write_com_1602(0x38);
//    write_com_1602(0x01);
    write_com_1602(0x0e);
    write_com_1602(0x06);
void delay(uint t)
    for(;t>0;t--);
void main(void)
    init_1602();
    write_com_1602(0x80);
    for(i=0;i<15;i++)
    write_dat_1602(shu);
    write_com_1602(0xc0);
    for(i=15;i<28;i++)
    write1302(0x8e,0x00);
    write1302(0x8c,dat[0]);
    write1302(0x88,dat[1]);
    write1302(0x86,dat[2]);
    write1302(0x84,dat[3]);
    write1302(0x82,dat[4]);
    write1302(0x80,dat[5]);
    write1302(0x8e,0x80);
    j=read1302(0x8d);
    write_com_1602(0x87);
    write_dat_1602(j/10+0x30);
    write_dat_1602(j%10+0x30);
    j=read1302(0x89);
    write_com_1602(0x8a);
    j=read1302(0x87);
    write_com_1602(0x8d);
    j=read1302(0x85);
    write_com_1602(0xc5);
    j=read1302(0x83);
    write_com_1602(0xc8);
    j=read1302(0x81);
    write_com_1602(0xcb);
請問大蝦,輸出為什么會不對呢?
謝謝了
作者: admin    時間: 2010-8-12 17:31
你輸出的是什么?
作者: kkssmm    時間: 2010-8-12 17:37
一開始是:
Data:2021-23-27
Time:47:;3::1
然后秒位開始無序跳變
